How To DIY Requests....
#102
#104
#106
on
Start by removing the belt then raise your front end and support with jack stands.
Remove your right inner fender liner.
From inside underneith you will be able to access the bolts (13mm if i remember correctly)that hold the tensioner assembly on. Remove them and work the tensioner out from the bottom. It takes a lot of wiggling but it will come out.
Re-installation is opposite of removal.
* A ratcheting open/closed end wrench makes this job a lot easier!
#107
#109
Ok, I got them off.
Hey guys. I'm new here and Started to replace my clutch and found that my lower outer balljoints are bad. I can't find a writeup anywhere that says how to remove these. I unbolted the two bolts. But they just wont budge. Is there a DIY on this anywhere? I searched everywhere.
Thanks in advance
Thanks in advance
#111
#113
on
How to remove the steering stops/limiters that MINI installs when you get 18" wheels.
I'm swapping my 18s for some 17s and I would love to improve the turning radius while I'm at it. Even just a picture or two pointing out where they're located and exactly which part they are would be a huge help!
#116
retrofit kit 32 10 6 777 974
http://s3.motoringfile.com/wp-conten...ering_stop.pdf
Do note ; this is for a Gen2 (R56) version not a Gen1 (R53)
#117
on
This will point you in the right direction:
#120
-Jorge
888.280.7799 | 6am - 5pm PST
#121
#122
#124
Dashboard LED replacement 1st generation Mini
This thread is for first generation mini's (up to 2006)
I've spent many hours over the past few days looking and have seen some amazing interior lighting, but VERY few part numbers so that I can order the LEDs and install them myself. In fact the only part numbers I found were from over ten years ago...
If you live in the UK you are in luck because there is NewMINIStuff.com for parts and essentialmini.co.uk where someone named Si seems to do an excellent and rather inexpensive for people, and I found several other resources as well for those in the UK.
I however live in the US, so all of what I found that currently sell stuff is useless to me.
Here are some great pictured instructions on how to take the tachometer and speedometer apart to install the new LEDs and gage faces: search at northamericanmotoring.com for interior-exterior-replacing-speedo-and-tach-gauge-faces-with-pics
There seems to be two suppliers of the gage faces 1. Factory stye with different colors: detroittuned.com 2. and a clean variation: outmotoring.com also in diferent colors.
So two questions
1.) Does anyone know of any other Gage face suppliers?
2.) Does anyone know which LED part numbers would fit for the surface mount LEDs for under the dash, as well as LEDs that can be used for the bulbs inside the cabin (Overhead lights etc).
Thank you
So two questions
Thank you
