How To R50 Drivetrain :: Getrag 6-Speed Swap - Full How-To
Old 04-09-2009, 06:32 AM
jbkone's Avatar
jbkone
jbkone is offline
What about the special tools? The dealer wanted well over $500 just for the 4 tools mentioned in the guide. Anyone have some I can borrow? Are they necessary? I mean, is there a different way to align the clutch instead of their $165 alignment tool?
I've never done any of this before and just find it odd that I'd need a special tool to align a clutch - doesn't it just fit?
Anyway... anyone have the tools they got for their project? Wanna loan them out? I'd pay shipping obviously.
  #52
Old 09-08-2009, 10:26 AM
rimplestultskin's Avatar
rimplestultskin
rimplestultskin is offline
know i'm really late to this party, but this is a good guide. anyone have any idea how feasible it is to swap out an ecotronic for a getrag? love my CVT, but in about four years, i will need modding potential, and a getrag manual is just better to mod with than a ZF CVT. not to mention this swap won't cost me much more than a new CVT, god forbid i pwn mine in the next few years (it has over 100k miles on it), if it's at all reasonably possible.
  #53
Old 10-23-2009, 03:25 AM
chrisfrom619's Avatar
chrisfrom619
chrisfrom619 is offline
Hi everyone,
I have a 2004 mini cooper I'm not planning on racing my mini but sometimes I have a heavy right foot. Right now I have a shattered tranny due to running over a large pot hole now I'm leaning toward the 6 speed conversion due to its durability my question is do I need to buy a aftermarket clutch and flywheel to do this swap or I can pretty much use whatever parts that will come out of cooper S. I have about 4k in funds is that sufficient enough to do the swap? I live about 2 minutes from the junkyard here in San Diego CA. Thanks in advance.
  #54
Old 10-23-2009, 04:12 AM
cristo's Avatar
cristo
cristo is offline
Alliance Member
You can use the MCS oem clutch and flywheel, but it's kinda heavy for a
cooper (28# vs 18# for MC oem flywheel), so I'd suggest an aftermarket flywheel/clutch.
  #55
Old 10-23-2009, 08:22 AM
chrisfrom619
That makes a lot of sense 10# will rob a lot of power on a stock motor do you recommend after market that's affordable?
  #56
Old 10-23-2009, 12:12 PM
cristo's Avatar
cristo
cristo is offline
Alliance Member
I believe a lot of people use Clutchmaster (fx100 or fx200) clutch and lighter
flywheel. I think they're about $900-$1000 for both from several NAM vendors.
  #57
Old 10-23-2009, 12:23 PM
chrisfrom619
Old 10-27-2009, 11:37 AM
jbkone's Avatar
jbkone
jbkone is offline
$4000 should be enough to do it all. You should be able to get a clutch/fly for less than $900... I think I spent close to $500 for both (Spec brand) from Outmotoring (I think).
And I've got the OEM ones from an S if you decide you want to use them.
  #59
Old 10-27-2009, 11:43 AM
WayMotorWorks's Avatar
WayMotorWorks
WayMotorWorks is offline
Vendor
Yes I'd suggest getting the lightweight flywheel clutch kit. Since you have a cooper anything to help it rev better is good.
Also I have a 04 Cooper S I'm parting out if someone needs conversion parts. Including trans and motor.
HOTCHKIS | DDM | CRAVEN | AKRAPOVIC | NM ENGINEERING | MEGAN | FORGE | IE | OS GIKEN | POWERFLEX and more
  #60
Old 12-27-2009, 08:43 PM
soccerbummer1104's Avatar
soccerbummer1104
soccerbummer1104 is offline
rev better is an understatement. When i got in my car with the lightweight flywheel and the FX200 kit, and the engine revved. I literallly stopped and went WTF?!?!?!? and revved it for liek 20 seconds
up and down
up and down
and i was just perplexed at it.
ITS AMAZING!
just wish i had had the money for the quaife...
  #61
Old 06-03-2010, 09:55 PM
CathyUK's Avatar
CathyUK
CathyUK is offline
My 2002 justa has the 5 speed Midland that is now making noises like something is about to blow. It has always felt like it should have another gear for freeway cruising. A year or two on from the start of this thread is the general opinion still that it is worth upgrading to the 6 speed getrag?
  #62
Old 06-03-2010, 10:12 PM
MINIdriver85's Avatar
MINIdriver85
MINIdriver85 is offline
Well I dunno about the general opinion but imho it is definitely worth it, especially if you can find a restyling 6 speed, which has shorter gears. I'm planning to start searching the needed parts for the swap after the summer.
  #63
Old 06-04-2010, 05:56 AM
jbkone's Avatar
jbkone
jbkone is offline
It is absolutely worth it. I did my own labor though so that helped. I figured I'd put in a transmission that wouldn't ever break again. Another Midlands... who knows how long it will last - I think I was lucky it lasted 113K. It was hard to swallow, but in the end I'm glad I did it. I'd like the shorter gears of the later Getrag, but I also really like the lower RPM at speed of the older ones.
  #64
Old 09-12-2010, 03:53 PM
truckinalong's Avatar
truckinalong
truckinalong is offline
OK, so I have a r50 with approx. 80k miles. Bought it off my uncle knowing that the cvt tranny would need to be addressed. I searched for other automatic trannys with the similiar mounts but had no luck. Here's my question, I want to know if I can swap out my cvt for a manual tranny and if so how much the cost will be. The way i see it, a new cvt is about 8k and will definitely not last. If the swap is less or equal to 8k seems like it would be worth it for a more reliable transmission that will last longer. Please point me in the right direction, I won't be doing the work myself so of course it's going to cost me but I need to know which option is the best. Thanks
  #65
Old 09-15-2010, 06:19 AM
jbkone's Avatar
jbkone
jbkone is offline
First, you'd need the transmission and all accessories. Figure maybe 2-4000 for those parts (not new). Then you'll need a clutch pedal and stuff. I have no idea how you'd do all that.
Good luck. Sorry I can't be more help. Def post back if you get more info.
  #66
Old 11-01-2010, 07:47 AM
mini845's Avatar
mini845
mini845 is offline
does anybody have this pdf they could send me? the link is broken for the original!
SunBird (10-19-2019)
  #67
Old 11-01-2010, 08:13 AM
cristo's Avatar
cristo
cristo is offline
Alliance Member
pm sent.
  #68
Old 11-02-2010, 02:37 PM
jbkone's Avatar
jbkone
jbkone is offline
NOOOOOOOooooooo!!!!!!!
Interesting, the URL int he 1st post resolves to WayMotorWorks now. I wonder if it's just a broken link or if it's just not avail anymore?
  #69
Old 11-07-2010, 12:22 PM
monkeyhobo's Avatar
monkeyhobo
monkeyhobo is offline
Could you also send me that PDF? I'd appreciate it.
  #70
Old 11-29-2010, 03:51 AM
Mr.electric's Avatar
Mr.electric
Mr.electric is offline
I could use the guide aswell. I am a professional mechanic just getting started on mini. I'm doing an 04 Cooper s clutch. I wouldn't mind specializing in Mini since there are so many here in the sf bay area. So far I'm just getting started. I am pulling engine/ trans together instead of taking trans alone. Seems easier than dropping the sub frame and dealing with the steering rack.
Got the Valeo clutch kit and flywheel.
I'll update with some pics tomorrow.
Please pm me the guide thank you very much.
  #71
Old 11-29-2010, 08:50 AM
Mr.electric
Here is a pic of the power train ready to drop
Attached Thumbnails R50 Drivetrain :: Getrag 6-Speed Swap - Full How-To-photo.jpg
  #72
Old 11-29-2010, 08:52 AM
Mr.electric
Ok thats better
Attached Thumbnails R50 Drivetrain :: Getrag 6-Speed Swap - Full How-To-photo1.jpg
  #73
Old 12-02-2010, 02:41 AM
MC2402's Avatar
MC2402
MC2402 is offline
Have any of you guys had problems inserting the drivers side axle shaft (half shaf) Im having a hard time getting the Shaft inserted past the C-Clip
  #74
Old 12-03-2010, 06:12 PM
cristo's Avatar
cristo
cristo is offline
Alliance Member
Originally Posted by kurvhugr
Hey Scott. Do you know the weight difference between the Midlands 5 and the Getrag 6? Also, I assume you don't miss the dual-mass flywheel even though this is an S transmission, true?
According to pelicanparts, the Getrag 5-speed is 73.7#,
the Getrag 6-speed is 104.5#, but couldn't find a weight
for the Midlands to compare - not sure if this is shipping
weight or actual weight.
According to my old outdated ETK, the Midlands is 33.5 kg
which is also 73.7#, but couldn't find weights for the
Getrags there.
  #75
Old 12-04-2010, 01:31 PM
cristo's Avatar
cristo
cristo is offline
Alliance Member
Found weights on all of them on one site: www.penskeparts.com
Getrag 6 speed 105.82#
Getrag 5 speed 73.85#
Midlands 5 speed 72.75#
Quick Reply: How To R50 Drivetrain :: Getrag 6-Speed Swap - Full How-To
