How To How To: Blackout Grille Trim/JCW Grille
Old 06-10-2007, 09:05 PM
Mach V Dan's Avatar
Mach V Dan
Mach V Dan is offline
Job: Convert the stock MCS chrome grille surround to the black version, like the JCW aero kit has. Optional: Swap the stock MCS plastic mesh grille with the almost-identical-but-sutbly-different JCW grille. (The JCW version has a coarser pitch of the grille openings. It's also made of a softer material, although that probably doesn't matter much...)
Before:
After:
This is mostly to educate those who wonder how hard this swap is. The answer is, it's almost laughably easy. You could do it in ten minutes. Sorry, I don't have pics of each step, but I don't think you'll need them.
Tools you'll need:
- Small Phillips screwdriver
- Small flat-blade screwdriver
Parts you'll need (available HERE, among other places...):
- Upper and lower JCW-style black grille surrounds
- (Option) JCW mesh grille
How To Install:
Upper Surround
- Open the bonnet (hood)
- Remove four Phillips-head screws that secure the upper grille surround to the bonnet. Wiggle the surround loose.
- Wipe the bottom edge of your bonnet clean of all the hood-goo that inevitably has dripped down from inside the bonnet.
- Press the new surround into place.
- Replace the four screws. Do NOT overtighten!
Lower Surround Removal
- With the bonnet open, reach behind each corner of the grille to find a little plastic tab that retains the corners of the grille surround. Pull on the tab while gently pulling the grille surround on that side. Repeat for other side. The just tug the surround loose.
- Wipe away hood-goo.
JCW Grille
- Use the flat-bladed screwdriver to pry up the center of the push-fasteners at the top of the grille. Once the center of the fastener is maybe 3/8" extended, you can wiggle the fastener loose.
- With the lower surround removed, you'll see four little sideways tabs poking out from the bottom of the grille. Push these sideways -- I think each one pushes towards the center of the grille, although it's not in front of me. The grille will pop loose.
- While the grille is off, wipe away still more hood goo.
- Install the new grille by carefully fitting into place and pushing to secure the four lower tabs.
- Reinstall the push fasteners. Make sure the fastener center post is still extended before you try to insert the fastener in the hole, or it'll jam without going in.
Lower grille surround re-install
- Carefully line up all the futzy little tabs, and press the surround into place.
Done!
--Dan
Mach V
FastMINI.net
Old 06-15-2007, 05:22 PM
hailpurdue's Avatar
hailpurdue
hailpurdue is offline
Would these pieces fit a non-s?
Old 06-15-2007, 06:04 PM
rkw's Avatar
rkw
rkw is offline
There is a non-S version of the JCW grill available.
Old 06-15-2007, 07:47 PM
hailpurdue's Avatar
hailpurdue
Right, I meant specifically on the fast mini website. I figured I'd ask here because I haven't had the best of luck contacting vendors around here with questions.
Old 06-16-2007, 09:40 AM
JohnnyF's Avatar
JohnnyF
JohnnyF is offline
Thanks for the write-up, Dan. I was looking at those on your site and wondered what was involved.
Old 06-16-2007, 10:38 AM
alalo's Avatar
alalo
alalo is offline
Nice looking and very easy mod
Dan, thanks for the write up .
I really like the clean look of the blackened grill.
It took me less than 10 minutes to install mine, here is a pic of the end result. (I'll take better pics this weekend).
Attached Thumbnails How To: Blackout Grille Trim/JCW Grille-dsc00184.jpg
Old 06-23-2007, 09:33 PM
OutMotoring's Avatar
OutMotoring
OutMotoring is offline
Vendor - 15 Years
Have had the JCW grill trim on since late April...love it:
http://www.outmotoring.com/mini-coop...rill_trim.html
Aaron@OutMotoring "info@outmotoring.com"
865-223-6335
OutMotoring.com: Home of the finest MINI and Aston Martin Parts + Accessories.
Shop online at www.OutMotoring.com
Free Shipping on most orders over $195 Click HERE
Old 07-26-2010, 02:20 PM
basil49's Avatar
basil49
basil49 is offline
bump
I know it's been two years since this thread was last posted-to, but: these instructions are still good!
R56 upper black grille surround: part number 51 13 0 417 135
R56 lower black grille surround: part number 51 13 0 442 011
A pair of pliers to squeeze the upper-surround center clips gently helps remove the old one
from the hood more quickly than just prying on it -- FYI.
Old 01-11-2011, 07:40 PM
dez's Avatar
dez
dez is offline
For those of you that had an easy time with this... how hard did you have to pull the lower grill surround? I had the clips realeased on either side and i could not get it to pry away from the grill. I was pulling firmly, but it felt if i had pulled much harder something could break.
Has anything changed with this with the 2011 refresh?
Any insight would be greatly appreciated.
Old 02-28-2012, 03:30 PM
jordan.burks's Avatar
jordan.burks
jordan.burks is offline
thank you for this post! i know its pretty old but i just recently got my mini and i bought the black grill and this was exactly what i needed to install it. thank you!
Old 02-28-2012, 06:01 PM
Sbray's Avatar
Sbray
Sbray is offline
Why spend 120 on the grill? I bought adhesion promoter, krylon plastics paint, clear coat, and 120 grit sand paper. About 20 bucks and a few hours later I have blacked out all but the belt line. It's held up excellent and looks much more ascetically pleasing to me.
Old 04-07-2012, 12:52 PM
MinMin2010's Avatar
MinMin2010
MinMin2010 is offline
These were excellent instructions. I just changed out my grille trim following the instructions to the tee. I could not have been any easier. Thanks for sharing.
Before:
After:
Old 04-07-2012, 05:55 PM
Mini///M's Avatar
Mini///M
Mini///M is offline
Very nice.
IN CASE ANYONE IS INTERESTED IN A TRADE. I am willing to trade my OEM black JCW surround trim for your OEM chrome JCW surround trim. I am in Westchester County, NY. Only makes sense to do it local. I am trying out a different look.
Old 08-19-2012, 03:37 PM
MrRaD's Avatar
MrRaD
MrRaD is offline
Originally Posted by Mini///M
Very nice.
pm'd i know its been a few months
Old 10-02-2012, 06:14 PM
Griffin-doug's Avatar
Griffin-doug
Griffin-doug is offline
Are you still willing to swap?
Old 10-02-2012, 07:58 PM
Melangell's Avatar
Melangell
Melangell is offline
I ordered my S this way... and it came this way.
Old 10-03-2012, 07:52 AM
MrRaD's Avatar
MrRaD
MrRaD is offline
I would swap if you want to. Or you can have both pieces for $30. I ended up getting the jcw aero kit.
Let me know
Old 02-09-2013, 10:23 AM
Rich2279's Avatar
Rich2279
Rich2279 is offline
Love the looks of your car. When you used the 120 grit; did you have to sand all of the chrome off?
Old 02-09-2013, 10:42 AM
Rich2279's Avatar
Rich2279
Rich2279 is offline
double post
Old 10-28-2016, 07:29 AM
Bnourai's Avatar
Bnourai
Bnourai is offline
I know this is a Old post but i am looking for a set of 2009 cooper s grill trim mold in matte black if anyone knows where I may be able to get one please let me know.
Thanks in advance.
Ben
Old 12-07-2016, 01:19 PM
bugeye1031's Avatar
bugeye1031
bugeye1031 is offline
Moderator
Thanks in advance.
Ben
Ben-
You might consider wrapping yours in flat black vinyl....I haven't done it personally, but I've heard that it's not too hard. Amazon sells 3M 1080 in matte black....
vulkandino
10-31-2015 08:29 PM
09-29-2015 12:17 PM
09-29-2015 12:16 PM
09-29-2015 12:11 PM
BendersMINI
09-27-2015 07:02 PM
Quick Reply: How To How To: Blackout Grille Trim/JCW Grille
