retrofit a NAV into a GP and Multi function steering wheel
on
just wondering if anyone has retrofit a NAV into a GP.
I know the steering wheel can be retrofitted with the multi functional steering wheel, but does it need re-programming from the dealer or can the programming done with the OBDII ?
This will give you an idea of the scope of work for retrofitting Nav. Details will be different for a GP because the author did the work on a 2009 MINI, and the GP would use the newer infotainment system that was updated in 2011.
https://www.northamericanmotoring.co...-to-guide.html
The dealer does programming through the OBD port as well. If you want to do the programming yourself, you need to become proficient with NCS Expert software. Start here:
https://www.northamericanmotoring.co...beginners.html
07-16-2020 12:54 PM
12-23-2015 10:36 AM
nomar116
08-21-2015 04:36 PM
nomar116
08-14-2015 04:54 PM
