GP 2 Dyno numbers
Old 08-26-2014, 03:01 AM
AbsoluteAuto's Avatar
AbsoluteAuto
AbsoluteAuto is offline
GP 2 Dyno numbers
Hi Guys
Just dynoed my GP2
Car has full bolt ons (intercoole, Exhaust, Catless Downpipe, k&N panel filter, Forge BOV, Charge Hose, JB+ @50%)
It made 271 BHP and 377 NM
A bit disappointed in the results, since i saw mariokarts gp doing 300bhp
Dyno was done with shitty third world country 91octane fuel, in 30C+ weather
Are these dyno numbers inline with what to expect?or is there any improvements to be had(boost leak test etc?)
Old 08-26-2014, 06:21 PM
e92oholic's Avatar
e92oholic
e92oholic is offline
Why only 50 % of the tune? Jack that **** up to 100 and let her rip!
Old 08-26-2014, 06:45 PM
AbsoluteAuto
Seems a bit dangerous to crank it up to 100% with 91 oct dont you think?Maybe terry can chime in
Old 08-26-2014, 07:00 PM
RobMuntean's Avatar
RobMuntean
RobMuntean is offline
Don't do it unless you have meth, 100 octane, or E85 there.
Old 08-27-2014, 05:34 AM
Grizld700's Avatar
Grizld700
Grizld700 is offline
Originally Posted by AbsoluteAuto
....Dyno was done with shitty third world country 91octane fuel, in 30C+ weather...
I'm assuming this isn't literal in that you are in a third world country, but where are you located? Do they use the same (R+M)/2 octane rating method? What fuel brand are you using. The type and brand of fuel can make a big difference.
Old 09-02-2014, 08:43 AM
AbsoluteAuto
Yes it is literal
I am in indomesia, fuel brand is local (pertamina pertamax plus)
Alternative is shell Vpower
Both 95 ron or 91 aki in us
Old 09-02-2014, 09:32 AM
Grizld700's Avatar
Grizld700
Considering where you are and with MarioKart using Ethonal blend, your numbers would seem appropriate for your modifications. Fuel is a larger factor than most people think.
Old 09-02-2014, 03:43 PM
AbsoluteAuto
Hm, i did try to out the jb at 75 for 2 dyno runs, hp did not increase, only torque did tho
Logs seem great, afr at 11.2 and no timing pulls
Old 09-03-2014, 05:44 AM
Grizld700's Avatar
Grizld700
Now, I'm not expert on the JB, but even if you it up to 75, wouldn't you still need to give the car time to adjust to the new parameters? I don't think its like an instant power kn0b.
Old 09-03-2014, 10:02 AM
MarioKart's Avatar
MarioKart
MarioKart is offline
Vendor
My numbers were 250whp and 275wtq with a blend of 91 and 100, which came out to me 98octane. It was a nice cool day at sea level. The dyne numbers you got, were they at the wheels or are the numbers converted to crank power. If you yes, what transmission % loss did you use. I need to take my car to the same dyne, under the same conditions, to see way my Manic Map C will get me.
Do you know what your AFR, Timing, boost, RPM and gear your car was dyno'd
BTW, I did have my JB+ at 100%, but that doesn't necessary mean the car makes more power at 100%. I have seen Mini's make more power on 60% than 80%, the dial to me, is more of frequency adjustment for your particular car.
Alpha Motoring
09-07-2020 07:34 PM
pglgp1292
08-09-2017 12:45 PM
NYMADMINI
12-14-2016 02:33 PM
monkiboy
10-16-2015 09:58 AM
gnhovis
09-28-2015 10:56 AM
Quick Reply: GP 2 Dyno numbers
