Way Motor Works GP2 Build
#52
We've also installed a Forge Intercooler with NM Discharge pipe. I can feel a good improvement and response. I've been logging the intake temps and I can get them down to 2 deg over ambient while cruising now, and when I see that I can punch the gas and enjoy the car pulling to redline.
Right now I'm playing with a couple different intakes and will report when I'm finished.
If so any warranty issues?
Thanks!
#53
We've also installed a Forge Intercooler with NM Discharge pipe. I can feel a good improvement and response. I've been logging the intake temps and I can get them down to 2 deg over ambient while cruising now, and when I see that I can punch the gas and enjoy the car pulling to redline. Right now I'm playing with a couple different intakes and will report when I'm finished.
What intake did you end up with?
#55
Yes I can definitely feel the difference with the intercooler.
I haven't done much to the car with the cold winter here as logging temps is better with more reasonable temps. I have a couple different intake options here that I'm going to try. I'll update more when I get stuff installed and tested.
#60
#61
I asked that too. Evidently the steering wheel controls plug into the turn signal/wiper control module. The module on our GPs doesn't have a place to receive the steering wheel controls.
#63
Ok thanks for the info. Looks like i will order the whole package as it to me is worth having the volume control. Now i just have to ask the dealer if they even know how to program it.cheers
#66
Way, can you please confirm that all I need to activate the rear fog light would be replacing the center toggle switch panel along with a new toggle switch? Then the dealer can just program it to work? Cuz somehow, I have been told that my car doesn't have wiring for the rear fog light behind the toggle switch panel. Please advise. Thanks.
#71
hey way, figure out how to get that area apart? I gotta stuff the denison in there and every time I've looked, it looks like -way- too much disassembly...there's gotta be an easy way.
#72
Yes I got it in and working
No cutting was required, but did have to special mount a couple nuts to get it all working. I'm putting together a kit for people to install it, but it's over $200 in parts so far.
