Just get a hood scoop from dealer in Thunder Blue, cause then if you want to sell the car you still have oe part. Cause I know if I was in the market for GP I would NOT buy one with decal missing.
__________________ 2006 MINI Cooper JCW GP0019
RMW tune & cams*17% pulley*ITG filter*Brisk plugs*H-Sport Comp RSB*KMac camber plates*resonator delete*TSW studs/jack pads*H&R 5mm spacer*CT AX6 pads*Motul RBF600*RedLine*15x7 Motegi TrakLites2*Nitto NT01 205/50-15 BRG/W 2003 MINI Cooper S R.I.P. Sheila
My decal is faded/blemished. MINI says they won't replace unless it coming off but on further look it may be starting to peel away. Anyone had smilar blemish issues with the decal?
iflyMINI GP1292 - SOLD Summer 2011 to a great dude in Maine!! ENJOY
Both of ours are fine.
'06 MCS JCW SB/S w/silver arches & Aero, Compass Rose roof graphic, Bilstein Pss9 coil overs, Alta sway bar, JCW strut bar, Powerflex bushings
'06 JCWGP1274 (no description required, he's my bad boy :)
My GP decal has blemishes on it. Looks almost like hard water spots but it is not. The spots will not clean off and my guess is they are under the surface so not cleanable.
2006 MCS JCW GP #1405: Adj Front Camber Plates, 19mm Rear Sway Bar, MM Front Lower Brace, Milltek Cat-Back, TCE 13" Front/11.75" Rear BBK, 15mm Spacers, Wheel Studs, JCM Modified Intake, MM Filter, Gauges
I pulled my bonnet decals. The decal around the scoop was lifting at both ends where they met at the bottom of the scoop. The scoop black out was so faded you couldn’t even read the GP any more. I had a local shop make a GP decal for the scoop and left it like that.
