MINI Cooper MINI Cooper specs
MINI Cooper MINI Cooper Forums MINI Cooper Pictures
Mark Forums Read MINI Cooper radio MINI Cooper latest news
Go Back   North American Motoring > 1st Generation MINIs > JCW Garage > GP Talk (2006)
Sign in using an external account
Register Forgot Password?
Welcome to North American Motoring !
Welcome to North American Motoring,
» Latest Main Topics
Go to first new post Show us your mods!
by ADAM244
19 Replies, 1,174 Views
Advertisement
Thread Tools Search this Thread
Old 07-10-2009, 11:42 PM
AutobahnRat AutobahnRat is offline
Gallery
Making The Ultimate GP
Hello guys, I got a few questions about the 2006 GP I'm from istanbul turkey, I am wondering if the chrono package can be retrofitted to the GP or if the lc display in the rpm gauge on top of steering column can display the speed....
also can you retrofit OEM bi-xenon's to the gp? what functional aerodynamic enchancements can be done to it? also how much horsepower can I get outta the stock blower, with 0.5mm over bore pistons (would I need machining of sleeves?) and carillo rods, schrick cam, new heads and intake manifold, and throttle body (I cantfind a throttle body on sale ever...)
will I tap 250 or 260 whp?, Im trying to build the best all rounder...sorry for speaking ignorant. I just think the GP is ultimate platform to start with
Old 07-11-2009, 12:21 AM
desmo desmo is offline
Send a message via Yahoo to desmo
Gallery
Tach - Zenon lights
Hi,
The digital display on the tach does display the speed as well as average fuel consumption, avg. speed, temperture, miles left on remaining fuel.
As far as the zenon headlights, thats a little harder. on U.S. cars there is an automatic leveling system, but the wiring doesn't seem to be in the wiring harness on the GP. European R53's have a manual leveling system with the switch low on the dash. The Euro shelf has a cut out for the switch. Personally I believe it would be easier to wire the European leveling system, rather than trying to wire the two leveling switches of the U.S. cars (one on the left front suspension and the other on the left rear suspension.
Sorry, can't really help you on the aerodynamic or performance mods.
Cheers,
Steven Tyler
Old 07-11-2009, 12:25 AM
Gallery
thanks for quick response, what about aftermarket projector headlamps....designed for r53's without factory xenons?, (so I dont get my mothers ears ringing from oncoming drivers)
Old 07-11-2009, 12:48 AM
rkw rkw is offline
Gallery
Quote:
Chrono pack can be retrofitted to any MINI (1st gen). However you would lose the GP grey dial speedometer, which is one of the special and unique things about a GP. You can install aftermarket gauges if you wanted more gauges.
Old 07-11-2009, 12:54 AM
Gallery
no its not that its just that center dash mounted speedo is disorientating for me
Old 07-11-2009, 01:10 AM
rkw rkw is offline
Gallery
I'm surprised that your car won't do it. When you click on the button on the turn stalk, what are the different functions that it displays?
Old 07-11-2009, 01:34 AM
Gallery
Quote:
I dont have a gp YET,im researching about it haha
Old 07-11-2009, 06:10 AM
anasumme's Avatar
anasumme anasumme is offline
Gallery
GP Questions
Thanks for posting the questions about the Xenons and Chrono package, I was thinking the same thing!
Old 07-11-2009, 11:36 PM
howsoonisnow1985's Avatar
howsoonisnow1985 howsoonisnow1985 is offline
7th Gear
Gallery
"Ultimate GP" is a point of veiw, cause I think GP was designed to drop weight from MCS so aditional stuff like xenons will add the weight back on plus its a super PITA. As for gauges, I put the oem additional column gauges on and after couple of months put them back on the marketplace, the reason is the gauges looked horrible in mismatched light grey while GPs were a lumenescent black. I tried several vendors from nam to match them I tried proffessional gauge restorers, with no luck to match them. So, I imagine the Chrono pak would be the same deal. AS for the xtra HP I'd go with a RMW Head, Cam and Header or 2.0 Stroker GP, cause it looks like a stock GP under the bonnet. And you can throw the stock GP engine parts in a bin in the garage.
2006 MINI Cooper JCW GP0019
RMW tune & cams*17% pulley*ITG filter*Brisk plugs*H-Sport Comp RSB*KMac camber plates*resonator delete*TSW studs/jack pads*H&R 5mm spacer*CT AX6 pads*Motul RBF600*RedLine*15x7 Motegi TrakLites2*Nitto NT01 205/50-15
BRG/W 2003 MINI Cooper S R.I.P. Sheila
Old 08-04-2009, 12:47 PM
iwantoneofthose iwantoneofthose is offline
Location: formerly a grass shack in Hawaii, now N. Phoenix, AZ
Gallery
Quote:
Originally Posted by desmo View Post
Hi,
Cheers,
Steven Tyler
thanks for the info on the xenon's!
btw, got ducati?
Old 08-04-2009, 01:49 PM
quikmni quikmni is offline
Gallery
For the headlights, I switched to Osram Rallye 65W bulbs in the low and high beam locations. They work good without switching to HID. They look to be on sale for $20 each at the folowing link:
http://store.candlepower.com/h7bulbs.html
2006 MCS JCW GP #1405: Adj Front Camber Plates, 19mm Rear Sway Bar, MM Front Lower Brace, Milltek Cat-Back, TCE 13" Front/11.75" Rear BBK, 15mm Spacers, Wheel Studs, JCM Modified Intake, MM Filter, Gauges
Old 08-05-2009, 09:46 AM
Luys's Avatar
Luys Luys is offline
Gallery
You can fit the OEM bi-xenon's on the gp easily, I saw one in Istanbul that has the OEM bi-xenon.
Mini Cooper S JCW 06'
Old 08-05-2009, 10:29 AM
7th Gear
Gallery
Hey Quick which Brisk plugs did you get for the GP and what did you gap them at?
I switched to Phillip Rallye 80W bulbs also in hi and lows, and at night I practically have to drive with my highs on so I can switch back to lows when a car goes by. Otherwise, cars going by engage their High Beams on me while I have my low beams on. I also have a Hella 100W set I have not installed yet, til these burnout.
Quote:
Not in US
Old 08-05-2009, 12:01 PM
Gallery
For the GP, I ordered Brisk DR12S plugs but I have not installed them yet. I plan to gap at 0.026 which is what Alta states is proper. From Brisk technical data it looks like Brisk specs the gap at 0.4-0.9mm which is equivalent to 0.016-0.035". Looks like 0.026 is right in the middle of the Brisk spec.
Old 08-06-2009, 02:46 AM
7th Gear
Gallery
Brisk
Cool, I was a bit confused which to get I noticed reyphile got different DR12SY ones and there was like 5 different versions of the 12s.
Old 08-06-2009, 06:20 PM
Gallery
From the brisk technical pages, I believe the official designation is DR12YS.
D is the shell dimensions (plug shape). R is interference suppression (resistor). 12 is the heat range. Y stands for projected insulator tip. S is for Silver electrode.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
MINI CooperMINI Cooper PrivacyMINI Cooper Terms of UseMINI Cooper Guidelines MINI Cooper Advertising The North American MINI Cooper Community
  MINI Cooper news, forums, FAQs, and reviews for enthusiasts and owners of the North American MINI Cooper
 Copyright © 2002-2008 North American Motoring. All Rights Reserved.     Powered by vBulletin and vBulletin Plugins by Drive Thru Online, Inc.
North American Motoring is an independently operated web site supporting MINI owners and enthusiastsworldwide. As such it has no official relationship with MINI USA, BMW AG, or BMW of North America.All original artwork and design is Copyright © 2002-2004 North American Motoring.
Admin Account Passwords
Search Engine Friendly URLs by vBSEO 3.5.2
