R56 Auto-up Windows
R56 Auto-up Windows
My sister bought a MINI about a week ago and so I hopped in it to do a test drive (and compare it to mine )...
One of the things I had noticed is that she had auto-up windows... Her car is a 2008, and mine is a 2007. :(
I've been across all kinds of forums (mostly this one) seeing different answers. The most I have seen have been...
I've tested the first method, and it didn't seem to work. However, my passenger side window's motor is a tad slower than the driver window, but I have no idea if that has anything to do with it.
Here are my questions:
Thanks in advance.
- Fob in, roll windows down, fob out. Fob in, roll windows up, fob out.
- Code the vehicle to allow these and other features (not sure how to do).
- What is the simplest way to allow this feature?
- If you have the answer, could you describe in detail how to do so?
Thanks in advance.
Also try the procedure in this thread: https://www.northamericanmotoring.co...ml#post3372843
By programming, I mean using NCS Expert which takes effort and technical expertise to set up and carries some risk if you do something wrong. You'll get a flood of information if you search the forum for "NCS Expert", but you can start here: https://www.northamericanmotoring.co...beginners.html. Some MINI/BMW specialty repair shops may be set up to do programming. Otherwise, go to a dealership.
edit: changed link
edit: changed link
edit: changed link
edit: changed link
07-16-2020 12:54 PM
cub4bearindiana
06-30-2016 06:11 AM
12-23-2015 10:36 AM
