Mini Basket Case - Bought without an inspection in AUS
Hey gang, here's the back story. 2 weeks ago I bought a 2004 Facelift MY05 Mini Cooper Sport R53 sight unseen from a Honda dealer in Sydney. I was planning to upgrade it all anyway slowly.
So, I take it to have a roadworthy vehicle inspection and before I can even get it on the road the Mechano has discovered:
So, I sourced:
Front/Rear Brembo Rotors and Akebono Pads - $600AUD
The mechano is going to source the gaskets and hoses but also discovered:
I already started buying and sourcing some Mods that I want done when the other stuff needs to be done and need to decide on how to lower it, either with Eibach springs or AP Coilovers.
List of Mods that I want done with the clutch replacement:
It's like an episode of Overhaulin' that's going way over budget. My budget for upgrades is $4500 and just getting it on the road is going to eat $1000 bucks into my budget.
What should I do here gang? Otherwise, it's a beauty inside and out. It's got the Chrono pack, Panoramic sunroof and Leather Seats. I won't even be able to do any cosmetic mods like a JCW front grill and Carbon Fiber details.
- Front Disc Rotors Undersized
- Rear Disc Rotors Undersized
- Engine Oil Leaks (Gaskets)
- Power Steering Leaks (Hoses)
So, I sourced:
- front shocks and Castor Bushings need replacing
- Fan Housing Part No 17117541092
- Clutch Flywheel Rattle (I discovered this before I bought it)
- Alta 15% Pulley with colder plugs and belt w/ puller tool AND I got a seperate Alta puller tool
- JCW Exhaust or other comparable Aftermarket Exhaust
- JCW or Alta CAI (whichever is loudest with a foam filter
- Nology Plug Wires and Ignition Coil
- Lowered with Eibach Springs or AP Coilovers (do they make coilovers for the R53?)
- Craven Speed Adjustable Short Shifter w/ Whalen **** and E-Brake
- Stubby 4.7in Carbon Fiber Antenna
It's one thing to start buying things that the car needs and another to buy what you want! I would take care of the needs first and later on build up to the upgrades. You will certainly never run out of mods that you will want to do because they are endless...the minute you think your done there are more. Besides you never know what will come out of the blue that will need attention...take it all in stride and don't try to rebuild the entire car. Just my two cents...
+1 on buying the things you NEED first, then when it is affordable getting the things you want...
Get it roadworthy and up and driving, then after getting the feel for it on the road maybe the aftermarket suspension MODs can wait a little later, this could keep as much as $1800-2200 in your budget. As well as the JCW exhaust (if the current one is still serviceable and trouble free) the exhaust could save you $850-1000 for now.
Keeping as much as $3200.00 upfront you can focus on getting the car back on the road and enjoying it, then tackle the suspension and exhaust in six or eight months.
Motor on!
Motor on!
++1 on need before want. You gotta have the car safe and sound first - that's paramount. Mods can wait. Besides, doing all your mods up front kind of short changes the process. Get the car squared away and back on the road, and then add your mods one or two at a time. Then you get to enjoy the "new" all over again each time!
I'm looking at this thing with the glass half full. I want to upgrade everything anyway so to me, it's a blank canvas.
What's the best lowering option? I don't want it lowered to the max but lowered enough for daily driving but still looking good. Do I get springs or coilovers and what's the best options for both springs and coilovers?
