Aftermarket windshield washer nozzles??
Love the Mini.......can't stand the windshield washer nozzles. Two streams that always seem to either plug up or spray in the wrong direction. I'm tired of cleaning and adjusting.
Many cars today have nozzles that spray a nice wide swath instead of two narrow streams. Does anyone know of an improved aftermarket nozzle? Do the newer Mini's have decent nozzles I can retro-fit? Mine is an '05 Copper S.
on
For mine I've found that little short bursts work better than a long stream - it spritzes lower on the windshield and then the wipers push it to the upper half. Haven't had a plugging issue before but I use mine a lot. Maybe there's a different washer fluid that could help keep them from gumming up?
There are other threads that cover this topic that may have a definitive answer on a vehicle that has a nozzle that will fit on the MINI. On my 2002 I would pull down on the windshield wiper stalk to activate the fast wipers then pull back on the stalk to activate the spray. That way the wipers did not run to the point of working on a dry windshield. They would stop immediately when I let the stalk go. Not sure if it works the same way on my new to me 2006.
This is the type of nozzle I'm looking for. No adjusting, no clogging. They are so good at wetting the entire area I figured some aftermarket company must have produced them for other cars. They work far better than the more common dual stream sprayer. Thanks for the lead. I'll see if they can be adapted. But I"m still wondering if anyone else has already tackled this issue?
That's what I'm looking for.......a fan spray nozzle. I've done an internet search but have come up empty for anything that fits a mini.
Some tinkering and frankensteining might get you what you want. Start with stock ones here:
http://www.ecstuning.com/Mini-2002-C...Hood/ES170302/
Then find the type of spray you want from a different car like the Jeep Compass. The nozzle internal is what determines your spray. You could even just remove the nozzle end and try to flatten it. For $11 a piece it's fairly cheap to toy with.
I didn't want to go messing around with them and screw them up, so I figured I'd ask someone first. I have the heated nozzles, and don't want to find out how much they cost the hard way!
No Problem Psquared! My nozzles are heated (cold weather pkg) and I've had no problems. A small straigt pin would probably be better to use than the straightened paper clip...not as obtrusive? I've only adjusted mine once and have found a pretty good position for getting the spray correct in relation to the wipers. Oh, but to have a fan spray nozzle though......
Parts stores have universal nozzles that have a fan spray pattern. they have a fitting that points straight down and a plastic nut to secure them so they will fit most anything. Only question is whether or not you can adapt them to fit under the hood of the mini and can you adapt the hose connection (never really looked at mine)
Here's one at Autozone http://www.autozone.com/autozone/acc...er=525520_0_0_
If anyone decides to be the guinea pig please let us know the end result. I have hated the nozzles on this car from day one but I have just put up with it so far. Most cars/trucks in the world have washer nozzles that spray in a fan pattern. Mini and BMW are the weird ones.
