Your thoughts on towing a small travel trailer with a MINI?
Hi - I'm looking at buying this small travel trailer to pull behind my 2010 non-S 6 speed (supposedly rated in EU to tow 1440 lbs; 2000 lb Curt hitch and 4 pin wiring installed and ready to pull). I would love to hear your thoughts and opinions of towing this 1000 - 1200 lb travel trailer as this would be my first towing experience. We would stay mainly on the east coast and SE US - VA, WV, PA, MD, NC, GA, etc. CO and large mountains aren't likely.
What do you think?
Photos and Info
Thanks in advance!
What do you think?
Photos and Info
Thanks in advance!
http://www.minitears.com/
Or check out Zyamfier's teardrop on his gallery page at
https://www.northamericanmotoring.co...y.php/cat/1138
I'll bet if you PM'd him he would talk you thru a few ideas.
Yetti - I don't know about the tongue weight but I believe 10% is the general rule, so probably 100-120 (upwards of 140 with gear which I can pack near the rear to lessen the tongue weight). If it sounds like it might work, I was planning to take a bath scale to measure that, and take it to Southern States to have them weigh it on their truck scale and verify the weight.
JAB - why, because of wind resistance, or another reason?
Brick - I wish I could get into teardrops - they're so cute but I really like being able to stand up and have more space inside. I'd love to rent one to try it out.
Besides - what about the towmini? http://towmini.com/
Check this video out...sure this is an S but it's also a larger trailer...
Towing with my MINI -- inclines?
I've been toying with the idea of towing my dirtbike with my MINI. My dirtbike is less than 250 lbs and I'm sure the trailer I get will be less then 350 lbs as well.
However, I know for sure that most of the places I'll be towing to include long mountain roads with some sustained inclines/climbing and I'm curious if this will become an issue?
I'm already a bit hesitant to tow the motorcycle, but I've read that many people even haul bigger trailers. However, I'm afraid how the inclines/climbing will treat it.
on
1 Post
Towing with a MINI
If you are going to be on the East coast in WVA, VA, PA, etc. then you are going to have mountains to drive over. I have towed a lot and you would need trailer brakes for the extra weight of stopping. I once towed a Corvair with another Corvair (same weight) and in an industrial park on a Sunday morning, a street light changed and I slammed on the brakes and slid thru the intersection before coming to a halt. Luckily no traffic but I learned my lesson. Wind resistance will be your biggest problem and seeing around the trailer with your mirrors will be limited without long side mirros.
I'ts not so much can i tow this trailer but can i stop safely. Towing a small utility trailer with a couple bags of bark mulch is one thing but a small camper towed by a MINI is not a good idea. I do plan on towing with my MINI, i am going to use a Home Depot utility trailer thats about 42in x42in and very light. Just need it for the occasional bag of bark mulch.
09R56
11-16-2022 10:49 AM
Interior/Exterior DEPO/Helix Projector Headlights Installed
Alkaidovich
01-30-2021 01:35 AM
07-16-2020 12:54 PM
bc219
08-10-2015 11:22 AM
