Dme issue
Old 08-27-2014, 07:24 PM
JCWKART's Avatar
JCWKART
JCWKART is offline
Has anyone in this forum had a issue with with there DME? A few weeks ago about 4 minutes after leaving work on my drive home my car goes into limp mode, I pulled over and plugged in my access port to see what's up. A must of had 10 codes came up, a few had to do with the map sensor. I took it to my trusty mini shop and they came back to me that it's the DME, the owner is a good friend of mine so I don't think he would bs me. He also said it's a common issue with BMW's, just wondering if anyone else has had this issue before. I'm about to fix and get rid of this car
Old 08-28-2014, 06:57 PM
Drivehard's Avatar
Drivehard
Drivehard is offline
Might it be the oil sensor wicking issue that may have damaged your dme ?
Sent from my iPad using NAMotoring
Old 08-28-2014, 07:36 PM
JCWKART's Avatar
JCWKART
JCWKART is offline
Not sure but we did fine a blown fuse that fixed about 5-6 codes that had to do with the map sensor, now there's a few old codes left. I'll post what they are tomorrow
Old 08-28-2014, 08:41 PM
Indimanic's Avatar
Indimanic
Indimanic is offline
Wicking is not uncommon for todays ECM vehicles. My experience was with Mercedes and Bentley. Any control unit connected to a sensor with oil one side can suffer this effect if the sensor starts to leak into the plug.
Can you tell what sensor failed or what the source of the oil was; trans or engine?
Old 08-28-2014, 09:16 PM
JCWKART's Avatar
JCWKART
JCWKART is offline
I will post more details tomorrow
Old 09-04-2014, 04:54 PM
Drivehard's Avatar
Drivehard
Details?
Old 09-04-2014, 05:04 PM
JCWKART's Avatar
JCWKART
JCWKART is offline
Sorry, were changing the motor harness. He narrowed it down to a short
Old 09-04-2014, 05:46 PM
jkapinos's Avatar
jkapinos
jkapinos is offline
So no oil at the oil solenoid?. My cars DME was going crazy until I replaced the solenoid valve and cleaned up the wiring harness with electric contact cleaner. Been running great for the last 5,000 miles.
Old 09-04-2014, 05:51 PM
JCWKART's Avatar
JCWKART
JCWKART is offline
Do u have pictures?
Old 09-05-2014, 02:05 PM
jkapinos's Avatar
jkapinos
jkapinos is offline
Yes. Top photo solenoid valve with exterior wire full of oil. Also valve was very loose and parts could be spun easy. Bottom photo is MINI's fix wire I did not use. My car is an early 2013 and they released a updated valve 3 months after my build date.
Old 11-03-2014, 03:56 PM
Indimanic's Avatar
Indimanic
What does that solenoid do? Is it located under the intake manifold?
My has gone kooky going full rich at WOT.
Old 11-03-2014, 04:27 PM
jkapinos's Avatar
jkapinos
jkapinos is offline
No the solenoid is in the oil pan and part of the oil pump.
Old 11-03-2014, 04:34 PM
cerenkov's Avatar
cerenkov
cerenkov is offline
Can you describe this and does it do it on the stock map?
Old 11-03-2014, 04:38 PM
JCWKART's Avatar
JCWKART
JCWKART is offline
Just to give a update on my 09 jcw, we changed out the oil soaked harness and the problem went away
Old 01-01-2015, 05:36 PM
sgscomps's Avatar
sgscomps
sgscomps is offline
The solenoid valve and oil soaked wiring harness is part of a recall. Dealers call it an oil leaker. You could of had it fixed under the recall at no charge.
Old 01-01-2015, 06:07 PM
JCWKART's Avatar
JCWKART
JCWKART is offline
Doubt it, I have a mini tech that works on my car that would have told me unless ur last name is Cooper and u know more then him?
Old 01-01-2015, 06:59 PM
cerenkov's Avatar
cerenkov
cerenkov is offline
I do believe that there is a something on it either a TSB, campaign or a full recall.
Old 01-01-2015, 07:09 PM
JCWKART's Avatar
JCWKART
JCWKART is offline
Maybe something is in the works but I know there isn't a recall on the issue I had unless the poster right before me just issued it in the last month
Old 01-01-2015, 07:33 PM
cerenkov's Avatar
cerenkov
cerenkov is offline
It might not be a true recall but it maybe a TSB or a campaign where MINI will cover the cost IF you ask or complain enough.
I've seen reports of this problem on this forum but the cars might have still been under warranty.
It might be worth looking into MINI could issue you a refund or partial refund.
Old 01-01-2015, 07:42 PM
JCWKART's Avatar
JCWKART
JCWKART is offline
I will definitely look into it, Thanx for the info
Getrieben
09-21-2023 03:31 PM
rtk90
08-29-2019 09:08 AM
Mini Koopa
R55 :: Clubman Talk (2008+)
09-08-2015 02:58 PM
Getrieben
08-15-2015 09:09 PM
flredmini
08-12-2015 06:35 PM
Quick Reply: Dme issue
