OS Giken clutch vs stock JCW clutch
Unless you plan on tracking the car, I’d stick with the stock clutch assy.
Mark
OS Giken makes a GT version for people that are doing more street driving than track driving.
I am thinking about doing the OS GT clutch and diff again in the spring.
Hopefully some others will chime in as I know there are 3 or 4 people here on NAM with OS clutches and or diffs.
Hopefully some other will chime in as I know there are 3 or 4 people here on NAM with OS clutches and or diffs.
Same with the LSD, if I wasn’t going to the track, I wouldn’t install it. Though I have both, neither is worth the money spent if your car is a 99% street car IMO.
Mark
Mark
If you’re going to buy a “street” version, then I’d stick with the factory clutch... I guess it depends how much track time your doing.
Mark
Mark
I bought the OS locking diff. What is the reason you do not recommend it? As in what issues are there in normal street driving? I probably won't track the car but I'm looking for traction on both wheels. They spin easily because of the torque. Especially around turns.
Ray
Perhaps I should have clarified a bit. If you’re an aggressive driver (on the street or track) and want the extra performance, then by all means, go for it.
The point that I was trying to make is it is more of a “track/severe performance” item than in comparison than someone throwing a wing on their car... at least it looks cool....lol.
If you have a use for it, you’ll love it but for the people that are installing it just for the heck of it, I’d say save your money.
Hope that helps...
Mark
For those who have the OS Giken LSD, how often do you guys change the tranny fluid anyways?
I had the ATS Carbon LSD on my RSX Type S before and I was told by my mechanic that I have to change tranny fluid every 3 months or 2000 miles, so I am wondering if they same maintenance schedule should be applied to the OS Giken LSD as well! Please advise!
Anyone willing to share their experience?
Orange, hey its not you man. MINI is having a real problem with the clutch assemblies on our cars. so in response they switched to a self adjusting clutch and changed the fulcrum point. engagement is much quicker but it should prolong the life..... hopefully, the real problem tends to be the loose nut behind the wheel :-)
BTW have you ever had a problem with the install of your osgiken? after install the engine will not rotate by hand. I blame my self for not checking the second the flywheel was installed, but ive put so many clutches in these cars I just assumed that everything would be ok. any info would be great
Yup, click on my link in my signature. When we installed the clutch, I installed everything back together (completely reinstalled the engine) only to pull it back out because it turns out the flywheel is a few mm’s thinner and the stock bolts bottom out thus locking up the engine.
Read the link, you’ll see what I mean.
HTH’s,
Mark
HTH’s,
Mark
HTH’s,
Mark
HTH’s,
Mark
Ray
Ray
BTW I'm in Downers Grove, IL USA
