OS Giken clutch vs stock JCW clutch
#51
#52
on
Sorry for a bit of Frankenstein. Didn't see an answer to this one so thought I'd toss one in for any others looking for info.
From what I've seen so far stock is around 40 lbs, the GT is around 30 lbs, and the STR is roughly 24-26 lbs.
Anyone have any further issues with these slipping or having other issues sooner than they should? Any who put it on when this thread was active have issues by now?
#53
It's been a couple years since I sold my JCW. It was rebuilt and modified to around 300hp. Had no problems at all with slipping or reliability. I couple drop it 5000 from a stop in 2nd gear and just smoke up the tires. What I didn't like about the clutch is it engaged at an odd point making it very easy to stall the engine. You more or less HAVE to be on the throttle an accelerating or it would stall. I know this sounds like normal clutch operation. However for me the OS clutch was very difficult to drive in traffic. One of the reasons I got rid of the car. As far as the weight of the pedal I didn't have a problem with it.
#54
on
Did you get the STR or GT from Way? Thanks for the update. It's sounding like the OS Giken will probably be my 3rd choice behind either Clutch Masters or JM Turbo, pending reading more reviews on those two.
#55
on
I installed the GT about 9K ago. My original clutch started to go with about 65K. Once I got the tranny off I discovered the tranny seal was leaking and got oil on the clutch. So I replaced the seal and put the GT in. Everything is still working great. I would definitely recommend it.
#56
#57
I have about 50K miles on a GT, with no problems, other than a lot of chatter and a noisy throwout bearing. It's been a noisy clutch since the install and hasn't affected the performance or usability.
The pedal weight is easy and feels pretty natural. It is a bit of a pain in traffic and finding the sweet spot between stalling it or spinning tire is tough to find when starting in first, but you get used to it.
This mini is my wife's and it has a dealer installed JCW package, which included tuning. It's never been tracked just abused by my wife every day and the clutch has held up well, which is more than I can say to the limited (30k) life of the OEM clutch.
07-16-2020 12:54 PM
gmonde
09-08-2015 06:37 AM
Powershift
08-16-2015 05:14 PM
Minibeagle
08-13-2015 10:00 AM
