MINI Cooper MINI Cooper specs
MINI Cooper MINI Cooper Forums MINI Cooper Pictures
Mark Forums Read MINI Cooper radio MINI Cooper latest news
Go Back   North American Motoring > 2nd Generation MINIs > JCW Garage > Factory JCW Talk (2009+)
Sign in using an external account
Register Forgot Password?
Welcome to North American Motoring !
Welcome to North American Motoring,
» Latest Main Topics
Advertisement
Thread Tools Search this Thread
Old 07-17-2009, 10:07 AM
Darth_Mini Darth_Mini is offline
Gallery
Impressions at 900miles... WTF torque steer!
We purchased our 09 JCW 'vert and have been steadly putting miles on it. Bought it mainly for the wifey, but I drive it on any chance I can.
One thing that takes getting used to is the torque steer. Mini needs to fix this and I'm not sure why the didn't. The e-diff is crap as far as I can see. This car needs a real LSD OR a better solution (ie. see Cosworth Focus RS).
Well other than that, it's all miles of smiles
Old 07-17-2009, 12:30 PM
mansize's Avatar
mansize mansize is offline
Gallery
My '09 MCS has the factory mechanical LSD, and I am starting to wonder if an open differential may have been the better choice for a daily driver.
What I am having trouble coming to grips with (bit of a pun there ) is what I call torque/bump steer, where under moderate acceleration through a corner, when you hit a pothole or surface change the steering wheel is quite unsettled. There just seems to be less margin for error if you are expecting to be able to trace your path with confidence, like I could regularly do with my R50 Cooper. (granted that was a lot less torque to deal with...)
I have added the JCW rear swaybar, and will take a hard look at the TSW X-brace, which is reputed to help with the torque steer, and is especially recommended for convertibles to add some chassis stiffness.
'04 R50 Cooper CR/W, JCW Sound Kit (sold to Son, still in family!)
'09 R56 Cooper S BRG/W, LSD, Enkei RS+M, JCW Rear Swaybar, ChromeLine, Brushed Alloy, BT/USB, Black'ette (new MINI obsession)
Old 07-17-2009, 03:37 PM
DNadar DNadar is offline
Gallery
I kinda like the torque steer. Especially when i fight the steering wheel through a corner :D
09 JCW - Exhaust Depot Manaflow DP Back~Ghetto K&N Intake~17x7 Tenzo R Type M~NM Engineering Springs
Old 07-17-2009, 04:43 PM
wandrur's Avatar
wandrur wandrur is offline
Moderator
Send a message via AIM to wandrur Send a message via Yahoo to wandrur
Gallery
My '09 S is like that, too. Makes driving on anything but a completely flat and straight road an adventure, and there are so many flat and straight roads in Colorado. Mechanical LSD here, too. Ah, well.
Interesting info on the swaybar and x-brace. Might have to look into those.
Silence
Something about silence makes me sick
'Cause silence can be violent sorta like a slit wrist...
---Rage Against the Machine, "Fistful of Steel"
http://i260.photobucket.com/albums/ii32/tcarpenter2007/Fist.png
Old 07-17-2009, 05:15 PM
AutoXCooper.com's Avatar
AutoXCooper.com AutoXCooper.com is offline
Location: Car Nut Since 1987, Owner Since Fall 2005, Vendor Since Fall 2007
Gallery
Many MINI Owners have reported that the TSW XBrace helps with torque steer.
Old 07-17-2009, 05:19 PM
spinned's Avatar
spinned spinned is offline
Gallery
I have the ALta 22mm rear swar bar and adjustable end links and control arms. I don't feel any torque steer and I have even auto crossed the car. I have a 2009 JCW.
http://www.flickr.com/photos/spinned/4270862644/
Old 07-18-2009, 08:02 AM
etalj etalj is offline
Gallery
Apparently the best mod for r56 torque steer issue is lowering. Also TSW brace. Jcw could really do with some help on the bump steering and torque steering. Will be lowering and installing Alta PSRS to stop bump steering completely (I hope)
Factory built 08/08 MINI JCW: JCW Aerokit, M7 C-Wing, Bilstein PSS10, Vorshlag camber plates, RennSport Racing Rear Upper and Lower Control Arms, Howerton Engineering HFS-3 w/ Race Tank, Whiteline 20mm RSB, RMW Tune, Dunlop Direzza Star Spec Z1, DoS CAI, Evolve FMIC, BSH OCC + Dual Boost Port, NM SSK, etalj-spec torque arm ;), Goodridge SS Brake Lines, Endless RF-650 fluid, Carbotech XP12s, ALTA PSRS, Powergrid adjustable endlinks, Challenge Decals
Old 07-18-2009, 04:18 PM
Gallery
Thanks for the info on the TSW Brace! This is very similar to one I had on my old E36 M3.
Old 07-18-2009, 05:06 PM
Minitauro Minitauro is offline
Gallery
Coilovers + swaybar will dial out 90% of that torque steer.
2009 JCW BRG/WHT
Mods: KW V1 Coilovers, Alta lower control arms, Alta 19mm swaybar, Alta 2" shorty antenna, JCW drilled/slotted front rotors, JCW Brake Duct Kit and new-style splitters, driving lights, JCW Carbon/Alcantara Shifter and E-brake w/Alcantara boots. Future mods: Downpipe (vendor tbd) Forge FMIC, JCW Alcantara wheel
Old 07-19-2009, 11:11 AM
Bullitt44 Bullitt44 is offline
"Bullitt"
Gallery
I have done numerous track days on my JCW this year. Learn how to manage the throttle and you will be happier. I recently installed koni yellows and stiffer springs along with a 19mm rear bar which also helped the cause.
09 JCW HT Dark Grey/Black
Old 07-19-2009, 12:39 PM
ronnie948 ronnie948 is online now
Gallery
Garage
Torque steer not that bad
I have a 2009 JCW and find the torque steer not bad at all. Torque steer is just a fact with a front wheel drive car and something to get familiar with. The more power the engine puts out the more you will notice the torque steer. I like the front wheel drive power pulling me through the corners. I guess it is really a learning thing that you have to experience after getting out of a rear wheel drive car. I don't even notice it anymore after getting used to it.
Ronnie948
2009 JCW
RONNIE948
Daytona Beach, Florida
Old 07-19-2009, 02:24 PM
TheBigNewt TheBigNewt is offline
Gallery
Technically speaking torque steer only occurs when you are accelerating straight ahead. Most of us use the term to describe the fwd car's behavior while accelerating in turns however. As for the "bump steer" phenomenon tires make the most difference there imo. Swaybar probably doesn't.
April 07:MCS SS/B/Tuscan Beige/Cream colorline interior/Manual/Conv Pkg/Premium Pkg/17" Flame Spoke/LSD/Chrome Line/English Oak/Xenon/HiFi/Anthracite Headliner. African Blackwood/Amboyna burl inlay shift knob and ebrake handle by Robin Casady (see my gallery) 19mm H-sport rear asb, Bridgestone Potenza G019 Grid non-RF tires. HTC Incredible phone.
Old 07-19-2009, 06:10 PM
mansize's Avatar
Gallery
Quote:
I hear what you're saying, but I have reasonably sticky RE-01R tires and can't keep them planted while turning under power and encountering a bumpy surface. The JCW rear bar was a simple cost effective upgrade similar to the change I made on my R50 Cooper, going from the stock MC bar to the MCS bar - I am not expecting relief from the bump steer, so will have to pony up for another solution, hopefully the Xbrace helps. The PSRS system looks to be beyond my mechanical inclination, and alternatively a lot of shop hours at a competent garage.
Old 07-20-2009, 11:00 AM
Gallery
Phsically what happens is that when the loaded up outside tire encounters bumps on the road it wants to hop up and down (d'oh) just like it does going straight ahead. But because the weight of the car is pushing it to the outside the tire/axle moves laterally and lands back on the ground. Etc. The only thing you can do is make the tire not hop up when it bumps. A softer tire (non RF), less pressure, or a softer spring or damper would help. Unfortunately those things tend to hurt hard cornering (except the change to a nonRF tire) and encourage understeer. The swaybar probably won't make much difference in wheel hop. It's a difficult problem to solve without affecting other aspects of handling. That's why I said optimal tires are the simplest.
Old 07-20-2009, 12:00 PM
spinned's Avatar
Gallery
Just fyi... I do not have the TSW Xbrace, so I am not speeking from experience, but I did read some where on NAM that someone was selling theirs because it will scrape bottom if your car is lowered. So those that are considering this might do a little more research.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
MINI CooperMINI Cooper PrivacyMINI Cooper Terms of UseMINI Cooper Guidelines MINI Cooper Advertising The North American MINI Cooper Community
  MINI Cooper news, forums, FAQs, and reviews for enthusiasts and owners of the North American MINI Cooper
 Copyright © 2002-2008 North American Motoring. All Rights Reserved.     Powered by vBulletin and vBulletin Plugins by Drive Thru Online, Inc.
North American Motoring is an independently operated web site supporting MINI owners and enthusiastsworldwide. As such it has no official relationship with MINI USA, BMW AG, or BMW of North America.All original artwork and design is Copyright © 2002-2004 North American Motoring.
Admin Account Passwords
Search Engine Friendly URLs by vBSEO 3.5.2
