F55/F56 Lowering Springs? Be Sure to Cut Your ‘Bump Stops’
I purchased my F56 S back in late 2014. Back then there were few manufacturers of lowering springs for the F56. H&R was one of them. In the instructions there was no mention of bump stops or cutting them. After having them installed it was apparent that the car was riding very rough and harsh. I tried to live with it for several months but it was awful. Let me mention that I like my cars to have a firm/stiff ride, but this was too much. I started hearing that the NM springs rode smooth and that others had switched from H&R to NM for this reason. But in reading through the NM instructions I noted that NM stated that it was very important to cut the bump stops and it got me thinking. Maybe I should try cutting the bump stop to see if it helps. It made a huge difference. What was harsh and bouncy is now smooth and compliant. I should also mention that the car has EDC (electronic dampers). It even allowed the car to sit lower now that it wasn’t sitting on the bump stops. I would say it is about ½” lower now, and rides much much better, and looks much better also. It is a PITA to cut them in the car but worth it. Attached is a picture of the cutoff pieces of the bump stop. Also attached a copy of the NM instructions for reference.
Hoopty
Hoopty
Hmmm. Interesting. I didn't get any instructions with my NM springs. I had mine installed by an experienced Mini/BMW tech and don't remember him cutting the bump stops. I was watching the entire procedure. Mine rides smoothly and I haven't noticed it to be overly harsh, but I have the Sport Suspension so that may be the difference.
nice tip hoopty.. reminds me back in 98 with my first car. I paid a "tuning" shop to install lowering springs on my civic.. the ride was so bad and noisy - but I always though that was the sacrifice i had to make for lowering... I only found out about the mistake when I bought coilovers a year later that my friend installed in his garage! he noticed my bumpstops were not cut and I was riding on them the whole time with the lowering springs!
this is a grey area. while yes, cutting your bumpstops with lowering springs is ideal, the shocks/struts were not designed to travel more than the bumpstop itself...you'll only increase the chance of blowing one of them or speeding up their lifespan until they eventually blow.
i have NM Springs and expect the harsh ride. maybe i don't get it as rough as you. in either case, good luck with the new setup.
Also that bump stop is to try to absorb energy in a last ditch effort to stop it from all being sent into the chassis itself. If your lowering springs are so low that you ride at the bump stops, you're way too low, and you have no suspension compression travel left. That'll absolutely destroy a chassis in reasonably short order. If this is a normal thing people do, I'm guessing these cars are known for having badly deformed/bent/broken strut mounts on the chsasis?
I know lower 'feels' better, but suspension travel is important - a car with no suspension travel and a suspension that doesn't dampen is slow, no two ways about it. The one with functional travel wins. Can't imagine what bumps feel like on the street like that. Must be jarring, and probably sounds like slamming a door.
I found this from H&R's site..
http://www.hrsprings.com/technical/m..._jounce_bumper
Heres another link from H&Rs site which shows the various cars (the f56 is not on here) but shows that cutting the bumpstops is necessary
That being said, my car is in the shop now getting H&R springs, so a modest drop of 1.1".. so IDK if trimming the bumpstops or not will matter...
that being said, I sent the techs both the NM install sheet which shows the cutting and the H&R article.. I'll leave it in their capable hands.. really excited to see the finished product
