MINI Cooper MINI Cooper specs
MINI Cooper MINI Cooper Forums MINI Cooper Pictures
Mark Forums Read MINI Cooper radio MINI Cooper latest news
Go Back   North American Motoring > 1st Generation MINIs > Modifications > Electrical
Sign in using an external account
Register Forgot Password?
Welcome to North American Motoring !
Welcome to North American Motoring,
» Latest Main Topics
Advertisement
Thread Tools Search this Thread
Old 01-07-2007, 12:07 PM
agile_moments agile_moments is offline
Gallery
what can I use to wrap/hide wires?
I just ran some wiring up either side of the engine bay, and up to the headlight area on the hood, so each side of my engine bay has one black, one red wire going up it. What can I use to wrap these wires in to make them not so noticeable? I don't want to use wire loom, I don't like the way it looks and it's only two wires on each side, so it's a bit unnecessary, what else can I do? I've thought of wrapping the wires in electrical tape, but that's a good bit of tape for that. Anything else I can do?
Old 01-07-2007, 12:39 PM
Foxtrot_Xray Foxtrot_Xray is offline
Send a message via ICQ to Foxtrot_Xray Send a message via AIM to Foxtrot_Xray Send a message via Yahoo to Foxtrot_Xray Send a message via Skype™ to Foxtrot_Xray
Gallery
I'd vote for tape. It's what I did for all of my rally lights, and it holds well against water and such..
Other than that.. replacing the red wire with another black one, and just zip-tying them?
Me.
# of Mile Markers Metered: 240,000
Old 01-07-2007, 05:39 PM
Mugami Mugami is offline
Coordinator :: River City Minis
Gallery
I vote tape as well but i got sneaky on mine do to not liking it to be seen that easily as well.. I took some duct tape that was wide enough to flat tape the wires straight on the engine bay. This was about half width of normal Duct tape. Then Painted the tape the tape the same color as the engine bay. Then applied the tape to the wires and enginebay.
Old 01-08-2007, 06:25 AM
THE ITCH THE ITCH is offline
Gallery
See post #7 and #5 for different options in the thread below
http://www.northamericanmotoring.com...ad.php?t=87623
Steve
Old 01-08-2007, 08:12 AM
Partsman Partsman is offline
Legion_of_Doom
Gallery
You could use some regular vacuum line, 5/32" will fit 2 wires inside it. Just slice it down one side and use it as loom.
Old 01-08-2007, 10:36 AM
Greatbear's Avatar
Greatbear Greatbear is offline
Moderator :: Performance Mods
Send a message via Yahoo to Greatbear
Gallery
I loom added wiring with electrical tape in most cases. It looks stock, protects the wiring and it's cheap enough. In areas that could see abrasion, I overlay either the black, convoluted slitted plastic tubing, vacuum line or mesh sleeving. Where a small, single wire has to make a solo journey in an engine compartment or other area exposed to maintenance, road spray, heat and/or debris, I will usually add a layer of shrink tubing to beef up the single strand.
http://home.comcast.net/~greatbear/gbnamsig4.jpg
JCW Intake|15% Alta|Milltek Catback|17x7.5 SSR Comps|215/45-17 GS-D3s|Much More
MMC #28|Motoring ID RAGE666
Old 01-08-2007, 12:32 PM
kenchan's Avatar
kenchan kenchan is offline
Gallery
i use wirewraps too (or looms), zip ties, black e-tape. looks stock and
protects from heat, weather, abrasions.
ive never had any issues with wiring ive done. probably because
99% of the time i use solder instead of taps.
Old 01-08-2007, 09:24 PM
Gallery
thats my other issue, I'm not too savvy with my soldering iron, so I havent been able to use it on my car wiring yet. The last things I used it on were my guitars about two years ago.
Old 01-09-2007, 05:39 AM
DixonL2 DixonL2 is offline
Gallery
Wrap it in something to protect it - you don't want shorts. Soldering isn't too hard if you've got a 100w or better soldering iron/gun. Those smaller ones aren't worth it. Heat the part AND the wire, make sure the solder melts on the part/wire (not on the gun tip), and shrink tube (preferred) or tape/wrap when you're done. When I've taped a joint, I use Scotch 33+ tape (the best IMHO) and then a small ziptie around the tape so it doesn't unravel. That 33+ has held for years in un-ziptied joints in engine compartments, so it's good stuff.
Tape's cheap (~$3/roll for 33+) and it's not too bad to spiral wrap a wire or three to protect it.
Official 2011 PittStopMINI SOB (Secretary Of the Board), 2009-2010 president http://pittstopmini.org
"I can do my own oil changes, change a tire, and can put together Ikea furniture. Should I try this on my own?"
Old 01-09-2007, 05:52 AM
BFG9000's Avatar
BFG9000 BFG9000 is offline
Gallery
Plastic loom comes in extremely small diameters that can just barely hold two wires. IMHO this is the most "factory" looking way to do it. Looks great with shrink tubing at the ends. And I always use T-Taps with no problems (Not ScotchLoks!).
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
MINI CooperMINI Cooper PrivacyMINI Cooper Terms of UseMINI Cooper Guidelines MINI Cooper Advertising The North American MINI Cooper Community
  MINI Cooper news, forums, FAQs, and reviews for enthusiasts and owners of the North American MINI Cooper
 Copyright © 2002-2008 North American Motoring. All Rights Reserved.     Powered by vBulletin and vBulletin Plugins by Drive Thru Online, Inc.
North American Motoring is an independently operated web site supporting MINI owners and enthusiastsworldwide. As such it has no official relationship with MINI USA, BMW AG, or BMW of North America.All original artwork and design is Copyright © 2002-2004 North American Motoring.
Admin Account Passwords
Search Engine Friendly URLs by vBSEO 3.5.2
