Electrical What does this do?
Old 08-28-2016, 04:14 PM
honderpilot's Avatar
honderpilot
honderpilot is offline
What does this do?
What does PIN number 3 do on the MAF sensor? I'm missing it, need it replaced but until then... What does this affect?
Old 08-29-2016, 07:27 AM
MiniToBe's Avatar
MiniToBe
MiniToBe is offline
what year and model you have? also, what is the issue with your MAF that prompted you to replace the plug?
Old 08-29-2016, 12:41 PM
honderpilot
2014 f56s I got three error codes on a CEL related to the MAF and I'm trying to diagnose the problem
Old 08-29-2016, 01:35 PM
MiniToBe's Avatar
MiniToBe
MiniToBe is offline
What are the two plugs you have? I suppose one goes to the MAF and the other? Can you type out the codes for us?
Old 08-29-2016, 02:00 PM
honderpilot
Other one plugs into the map sensor. Here are the codes I got :
P0100
P112F
P12A4
Old 08-29-2016, 02:53 PM
MiniToBe's Avatar
MiniToBe
MiniToBe is offline
The MAP and MAF are different. If you still under warranty, can you go to the "sdealer" and have them fix it?
You can also do a small experiment ;-) clear the codes and un plug the MAF and see what codes come up. Clear the codes and Do the same with the MAP. Clear codes and Do the same with both unplugged, and see what codes come up. make sure first that the air pipes are tight and air isnt leaking in any where.
Old 08-29-2016, 03:10 PM
honderpilot
That's what I think I'm going to do. Thanks.
Old 09-05-2016, 04:22 PM
honderpilot
Codes cleared and CEL is still gone with 20miles on the car so far. Will keep an eye on it for now but still unsure if I broke the MAF sensor as seen above lol
Old 09-05-2016, 07:59 PM
MiniToBe's Avatar
MiniToBe
MiniToBe is offline
That's good news...
JaysinStrife
06-24-2016 01:37 PM
pielord12348
06-22-2016 10:33 PM
madminii
12
06-15-2016 11:50 AM
DontCountToday
06-15-2016 12:11 AM
renchjeep
06-01-2016 08:25 PM
Quick Reply: Electrical What does this do?
