Electrical Coding with Carly "BMWhat" app
Just finished, for now, coding my countryman with my iPhone and Carly app. The wifi obd plug was $98 on eBay and app $45. I could have payed less but Amazon doesn't accept paypals. A NAM member let me know about the app and it works perfect. I don't have to be a computer programmer or know German. I wanted to post this for members that don't know about this like myself. It works great! No laptop! Just plug in the wifi connector, open the app and code away! It even diagnoses engine, register new batteries and more. Carly says they are working on more coding now and will be updateing the app. Check it out at www.mycarly.com. Start up cost isn't as cheap as using a laptop but it's sooo easy and convenient to use.
Interesting; a few questions:
1. All you had to buy was the actual app and the obd/wifi adapter?
2. Do you have a link to the adapter you purchased? (any reason why you went with a $98 version? I see much less expensive ones on ebay?
3. Once youre connected to wifi and have the app open, was it difficult to get the app to connect to the car?
Thanks!
Thanks!
Thanks!
Thanks!
#2 I bought the adapter they recommended on www.mycarly.com for my phone. They have a iPhone and android version. I used eBay because PayPal is great at handling disputes if the item doesn't work.
#3 Its as easy as connecting to the Carly wifi adapter in wifi settings, and opening the app and pressing connect for the app to connect to the car throught wifi. It's a bmw compatible app, but bmw makes mini coopers so r60/ countryman is on the list of cars to choose.
So far I've coded my fog lights to stay on with my brights, unlocking by doors fog lights fade on 40 seconds, trunk button turns low beams on 40 seconds/ long press is panic alarm, deactivated all the bulb checks for all bulbs, hold lock button rolls up windows and closes sunroof. Tons of stuff to change and they say more to come with updates. I'm very happy because if you have read the coding thread here, it's intimidating. Datens, files modules, folders, German, it's just to much for me to comfortably do confidently.
Go to www.mycarly.com and find out more. Then use your computer to buy the adapter from wherever you want. That's what I did.
Did you have to do anything as far as updating the obdlink? Or will the Carly lite edition not recognize that coding is even possible, mine says it cannot find any ecu's. Just want to verify that everything is working sound before I drop the 45$ for the full Carly edition
I'd iike one that works with Bluetooth and iOS as I'm trying to stay away from WiFi based products. I'm pretty sure you loose your Internet connection when connected via WiFi.
Thanks!
Thanks!
Thanks!
That said, the generic wifi dongle I have is a pain in the ***. Takes a while to boot, usually takes a couple tries to join its network. I use it only for Carly; I use an Automatic.com dongle for DashCommand, Harry's LapTimer and the Automatic app.
I also have a generic Bluetooth dongle that requires an iOS jailbreak and RoqyBT to use, but it's not a stable connection and Carly flat refuses to use it. Given the iffy quality of that connection I don't blame Carly for refusing to use it.
That is a long way of saying go ahead, pick up a $15 wifi dongle, it'll work fine with Carly and your iPhone will still connect to the Internet. Just be patient with the cheapie dongles.
Thanks bratling! Could you check to see if the dash.by app works with your cheap WiFi ODB-II device? Would you recommend the
Has anyone had any experience with the Carista ODB-II device and/or app with a MINI Countryman?
Amazon.com: Veepeak Mini WiFi OBD2 OBDII Scanner Scan Tool Adapter with Power Switch Check Engine Light Diagnostic Trouble Code Reader for iOS iPhone iPad and Android: Automotive
Carly quit working now:(
Well after months of using this app it now says "critical error" so coding doesn't work anymore. So if you waste your money like I did just be aware, it may only work temperarily if at all. Carly says its a common problem. So personally I'm not sure what to make of a app that may or may not work, or just quit working. So buyer beware!!!!!!
i have been using Carly/android/bluetooth for an out 3 years now
That's strange? They told me sometimes this happens and there is nothing they can do about it. I have continued to try from time to time and see if it works out the issue on it own, but it hasn't. No updates have addressed the problem so I guess I'm screwed. Only idea I can come up with is replacing the module that is not working. But I believe that isn't just a plug and play situation. The car work flawless other than not being able to code.
unrelated i guess but i'll add to the thread carly does not work with odblink products.
https://www.scantool.net/obdlink-lxb...58JxoCHIXw_wcB
the adapter works with other android apps, just not carly/bmwhat.
Well I've been using it about a year now and yes I did buy the dongle from them and I paid for the app. I have an I phone 6S plus and so far programmed on my lights radio side mirrors blinkers things of that nature. I have not ran into any issues as of yet the set up is easy to use and they are active in updating the program.
First, very sorry for my bad english - living in Austria and figured this forum is way more valuable than any other german forum I found
I´m currently trying to get my audio from analog to digital in my recently bought R60 (3/2016) so I can just put in my lightning cable without any aux cable (I do have the iPhone 7) and still being able to have audio
While trying NCS expert I always received an error that I couldn´t identify while reading the ECU.
So I thought I want to give iCarly a try. Looking at their homepage and going through the modules they list on the homepage I can´t see any media control that lets me change audio from analog to digital.
Also when talking to the support he just laughed at me that I can´t change any analog signal into a digital one.
Well I read from tons of people being successful using NCS so I wondered if someone already using iCarly could confirm if this option is available/ not available ?
