Electrical Tricking the Clutch Sensor?
Hi all,
Searched the forums, didn't find anything relevant to my situation. Just wondering if anyone knows of a way to trick the clutch sensor into thinking the clutch is depressed? I created my own clutch stop which eliminates all of the extra travel in the clutch; however, now my Mini doesn't want to start. I've played around with different lengths for the clutch stop and unless the clutch is depressed almost all the way to the floor, it won't start. Stupid clutch sensor! I have a 2012 MCS (R58). Thanks in advance!
Curt
Curt
Would like to try the switch
Cristo, I tried a regular magnet. No luck. I may see if I can find a stronger magnet tomorrow and give that a shot.
Dan, your idea is exactly what I was thinking. Tried to find more information but only found a thread on a VW forum from 2007. I’m not an electrician (aka electricity savvy). I’ve wired LED flush mount turn signals on my R6 and spliced wires together, which is about as far as my experience goes. I understand the concept of a switch but I’m not sure where the wire needs to make contact. Could you explain in layman’s terms how to accomplish the switch? Thanks!
Magnet was a No-Go
For those that may interested in trying a magnet...it didn't work on my 2012 R58S. The attached image indicates where I placed the magnet. I used a fairly strong magnet.
Has anyone tried a switch and did it work? How do I go about making the switch to disable the clutch sensor?
Someone needs to get a hold of one of the sensors from a salvage yard and get a handle on the design. Seems like one could remove spring depress it and plug it in and put off to side out of the way. In the pic is that the sensor or the rod to clutch master cylinder. Are they all integrated into one unit? I see the return spring.
Sensible?
Sensible?
09-17-2015 09:27 AM
