Electrical NCS Expert error help
Hi folks mini cooper non s 2007, im using eidibas 7.3 inpa 5.02 and isda d which all work fine and can connect and read error codes,when using NCS expert i can read the chassis ok but when i try to code my airbag or dsc module i get an error "Datatransmission to Interface Disturbed" im trying to reset them to defaults using the SG_CODIERN cmd as they were messed up after a failed ecu swap we put the old ecu back in and lost the DSC and Airbag coding, the cable is on com port 1 with a kcan cable with pins 7+8 desoldered the obd.ini is set to match any ideas.....
hi thx for the reply yes the latency is set to 1 ok and its using com port 1 strange thing is i managed to code the airbags ok just seem to get this error with the DSC unit which was my original DSC unit that was coded to the ECU i only lost the coding after trying another ECU in the car when i connected the old ECU up the DSC/ABS light was lit.........ISTA D is saying it needs coded........
How did you update the datens exactly? I've found that I have had intermittent luck with just doing file copies. I've been using the BMW Coding Tool to do my updates and i seem to not get the random errors dealing with different modules.
http://www.bmwcoding.com/showthread....MW-Coding-Tool
hi thx man tried using the bmw coding tool to update the datens still the same,im getting the error "no response from control unit" now....cant understand this as in NCS it can read the ecu to get chassis info OK.......also INPA and RHEINGOLD all work perfectly crazy......trying so hard to avoid the stealers .....any advice guys....
BTW: you'll likely have the same problem with the ULF (Bluetooth) module.
aye i read a few other posts saying that too man,is there any other sofware i could use to code this damm DSC module,i dont understand why it needs to be recoded it was the original one from the car that was already coded all i did was change the ECU,CAS,and Body modules and start the car i then removed them and re installed all the originals then this error came up......trying to avoid going to the stealers at all costs
dutchhome
09-30-2015 07:17 AM
