Electrical Factory Driving Lights Rewire
I'm curious if anyone's ever rewired their official MINI driving lights. As they're installed and wired now, they only work with the high beams on. I'd like to use them at any time without the high beams. I've got the installation guide with the wiring diagram as well as the Bentley manual. It doesn't look like it'd be much to wire it up (I'm an aircraft electrician by trade).
Any thoughts?
Wingnut
Any thoughts?
Wingnut
It is a real hassle to turn off both a set of driving lights and to drop the high beams quickly in an oncoming car situation, long time to take your eyes off the road. Leaving your main headlights on low beam while you have the driving lights on does simplify the situation but you lose the effect of having all available light on the road. On my off road 4x4's this never became an issue because there are no oncoming drivers out in the boonies.
I hooked aftermarket lights up direct to give me control like you are asking, but didn't like the "dance" to turn them off quickly so I patched into the high beam wire near the headlight for the switch. Your OEM ones of course, are already wired and you can clearly see after removing the switch panel where to snip and run an additional wire from that to power. I recommend you don't, it really is a PITA to operate on a regular basis. I think you will become annoyed with the process and switch it back within a few weeks.
Your results may vary, but if you are out on flat road interstates that might work for you, but muscle memory is not quick enough on mountain roads at speed. For that extra second plus it takes you have just blinded somebody heading right for you. The big PIAA 520 driving lights pack a lot of light so I have to be prudent when I use them, fortunately I do drive in very remote areas where there are many critters at night so I can use them.
That would certainly work but I'd suggest using a circuit that's only hot when the ignition is ON (lest you inadvertently leave your lights on and drain the battery). Cigarette lighter?
always on switched means always on and controlled by the ignition switch ... aka, ignition off = circuit off
as compared to an 'always on'
if you go back to the earliest Mini there were two fuses ... two circuits
always on
and switched
sorry if I confused you with classic speak.
yes, the cig' lighter is a workable spot ... or radio illumination (already used by the GEN1 factory kit ... for what?)
what won't work is a circuit that's switched and sometimes on .... only when the computer is sending power to that device . . . like the fog lights
always on
and switched
Hi fellas. I'm currently in the process of wiring up 2 extra hella running lights and 2 piaa fog lights. I'll probably just tap into the high beam light for the hellas and the low beam for the fog lights - just a few inches before the plug on the driver side headlight. (i will be using relays as to not pull too many amps through the light wiring
I DO want the option of having them OFF at my discretion however.
The question is- what's the easiest (and good) way to get my switches through the firewall?
i tried fishing the switch wires through the wiring hole just above where the clutch lever would be (I have an automatic) without success. it was very snug.
Then i notices a small grommet about the size of a quarter near the wiring harness hole. It looks like it's where the clutch linkage would pass through.
Any problems with just poking my wires through that grommet?
thanks in advance for the tips!
yeah. it looks dry. i'll give it a try. I'll just drill a hole through the grommet just big enough to get wires though then maybe put a dab a silicone on it for good measure.
seems like the simplest way to get through for sure.
wiring from Engine compartment to interior
I am not happy with my power source for my lights. Right now it is connected directly to the battery and I have to remember to turn them off manually. Let me know how you are powering your lights. I think you mentioned one wire run off the low beam wire and one of the high beam wire with a relay. If you need pics of what I did on the firewall I can take them.
Hi fellas. I'm currently in the process of wiring up 2 extra hella running lights and 2 piaa fog lights. I'll probably just tap into the high beam light for the hellas and the low beam for the fog lights - just a few inches before the plug on the driver side headlight. (i will be using relays as to not pull too many amps through the light wiring I DO want the option of having them OFF at my discretion however.
07-16-2020 12:54 PM
Wohnson89
06-10-2020 04:53 AM
12-23-2015 10:36 AM
ryGuyMCS
10-20-2015 02:24 PM
JHolland
08-13-2015 10:47 PM
