Electrical Adding a Second Back Up Light
Old 07-27-2014, 08:01 AM
cactusjk's Avatar
cactusjk
cactusjk is offline
Thanks for the picture! I guess the tabs Gil is talking about are the small ones around the outside edge.
Originally Posted by rkw
The two things sticking out in back.
Reach under the bumper and squeeze the tabs towards the center while pushing the lamp out. It will be obvious when you obtain the replacement lamp and look at it.
  #27
Old 07-28-2014, 07:13 AM
ECSTuning is online now
Received 1,964 Likes on 1,764 Posts
Originally Posted by rckrzy1
Does the clubman in EU have the reverse light on opposite side of US ? If so how about that part number or getting them for us ?
Replied with a PM, also so we don't mix the Cubman with these other JCW R56 R57 , R58 R59 body kits.
  #28
Old 07-28-2014, 08:43 AM
Gil-galad's Avatar
Gil-galad
Gil-galad is offline
Correct. On my MINI, those two larger tabs are completely non-functional. They're just hanging out there in mid-air.
  #29
Old 07-28-2014, 10:37 AM
cactusjk's Avatar
cactusjk
cactusjk is offline
I guess I am leaning towards trying it. I assume the 13 R56 aero bumper is the same as the coupe.
Not sure what actually holds the light in if those two large clips are not engaged. Doesn't look like there are many posts on this replacement...
  #30
Old 07-28-2014, 11:42 AM
Its it. The Rear Air discharge is the same , only difference is the with PDC and without PDC. This one is without and does not have that little hole for the sensor above the opening. Those inner tabs don't have a use as of with this application.
The rear left ( driver side ) additional back up light.
And the discharge ( NON PDC )
You can see they are just held with the tabs.
  #31
Old 07-28-2014, 11:50 AM
cactusjk's Avatar
cactusjk
cactusjk is offline
Thanks. Any recommendations from ECS on the best way to replace the drivers side backup light without damaging the black vent surround?
  #32
Old 07-28-2014, 12:01 PM
Reach up behind it push out the back ( from under the rear bumper ) , Reach other hand around the front to hold it when it comes out , so it does not drop and break.
  #33
Old 07-28-2014, 12:16 PM
cactusjk's Avatar
cactusjk
cactusjk is offline
My JCW bumper is completely enclosed behind the wheel?
  #34
Old 07-28-2014, 12:20 PM
Sorry , do you have the JCW GP 2 diffuser in the way. You should be able to reach up behind that bumper, not near the rear wheel well. But towards the exhaust, then up.
  #35
Old 07-28-2014, 12:28 PM
cactusjk's Avatar
cactusjk
cactusjk is offline
I do have the GP2 diffuser. I will try that. Just don't want to search the black surround with those tabs Gil mentions.
  #36
Old 07-29-2014, 06:58 AM
You are welcome, I thought I remember you having it. . Yea the GP2 diffuser does take up a little bit of the access from the muffler side to the rear fog / backup light. But wow does it look great when installed.
http://www.ecstuning.com/Search/SiteSearch/51747330558KT/
Thanks.
  #37
Old 07-30-2014, 02:06 PM
cactusjk's Avatar
cactusjk
cactusjk is offline
Gil- Do you have specifics on where it get the LEDs and holders including part numbers?
  #38
Old 07-30-2014, 07:27 PM
Gil-galad's Avatar
Gil-galad
Both were eBay purchases. See these links:
http://www.ebay.com/itm/111113572825?_trksid=p2059210.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
http://www.ebay.com/itm/300976043632?_trksid=p2059210.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
There are probably a few alternative sources out there too.
  #39
Old 07-31-2014, 02:59 AM
cactusjk's Avatar
cactusjk
cactusjk is offline
Thanks Gil!
  #40
Old 07-31-2014, 10:02 AM
cactusjk's Avatar
cactusjk
cactusjk is offline
Can someone confirm the drivers side reverse light part number for a 2013 R56 JCW?
  #41
Old 07-31-2014, 10:41 AM
Here is both just encase. Its also further up in this thread on the first page.
Back Up Lamp - Right ( Passenger side ) Part # 63247241802
http://www.ecstuning.com/Search/SiteSearch/63247241802/
Back Up Lamp - Left ( driver side ) Part # 63247241801 ** The part you are looking for to match the right side.
http://www.ecstuning.com/Search/SiteSearch/63247241801/
  #42
Old 07-31-2014, 06:10 PM
cactusjk's Avatar
cactusjk
cactusjk is offline
Thanks! Assume based on what Gil said that you use a plastic trim removal tool on the top of the lens to pry it out first. Tape off near where the tiny tabs are on the lens to make sure they don't mark the black outer trim.
  #43
Old 08-01-2014, 05:47 AM
Yep.
Trim tool here is you need it. I popped them out the back kind of way. Just have to watch so you don't scratch the frame. Its all your technique.
http://www.ecstuning.com/Search/SiteSearch/Schwaben_Trim_Tool/
Post up when you get the mod done.
  #44
Old 08-01-2014, 09:08 AM
Gil-galad's Avatar
Gil-galad
A few other helpful hints if you take on this mod:
1. Make sure you get a good, watertight seal on the LED socket, either using a silicone sealant or copious amounts of liquid tape. Any little gap will allow road spray moisture to get into the lens, obviously leading to other potential problems.
2. Test the LED rear fog lights before reinstalling the lenses into the bumper cover. If the polarity is reversed (i.e, the bulb is flipped in the socket) the bulb won't illuminate.
(For one that I had inadvertently reversed, I found it easier to just switch the wire leads leading to the socket. The alternative is to unseal and take out the LED socket so you can flip the bulb around, right after you've just done the work of sealing it up).
3. Take it easy when you twist the LED sockets into place. If you use too much force you can snap off the little retaining tabs on the socket. Since they're cheap, I recommend ordering a couple of extras just in case.
Good luck!
  #45
Old 08-01-2014, 10:23 AM
cactusjk's Avatar
cactusjk
cactusjk is offline
Really appreciate all the recommendations! Assume these LEDs are very long lasting so we will not have to replace.
  #46
Old 09-05-2014, 12:51 PM
vistaracer's Avatar
vistaracer
vistaracer is offline
I put two small LED Cree lights (1.2 watt each) in the black plastic piece on each side of the license plate on the back of my Clubman, and wired it to the wires for the normal back up light, so they come on when I put it in reverse. It works great, but I keep getting the light bulb icon on the tach display. Is that something I should be concerned about or just ignore?
  #47
Old 12-09-2014, 06:16 PM
6thGear's Avatar
6thGear
6thGear is offline
please PM me with the same info.
  #48
Old 12-19-2014, 12:33 PM
6th gear, just saw this, PM me what you are looking to do additional, if anything .
07-16-2020 12:54 PM
surfblue
10-24-2018 01:20 AM
Zettinger
08-25-2015 04:04 PM
Colt45Magnus
08-12-2015 06:43 AM
Dashdog
08-10-2015 06:17 AM
Quick Reply: Electrical Adding a Second Back Up Light
