Electrical Countryman-Specific Coding - R60 Guide
#1201
#1202
Other bulb check abbreviations:
KALTUEBERWACHUNG_AL : cold testing bulbs in low beam
KALTUEBERWACHUNG_BL : " " " " brake light
KALTUEBERWACHUNG_BLK_HI :" " " " turn signal rear
KALTUEBERWACHUNG_BLK_VO :" " " " turn signal front
KALTUEBERWACHUNG_BL_MI : " " " " brake light
KALTUEBERWACHUNG_FL : " " " " high beam
KALTUEBERWACHUNG_KZL : " " " " number plate
KALTUEBERWACHUNG_KZL_LI :" " " "
KALTUEBERWACHUNG_NSW : " " " " foglights
KALTUEBERWACHUNG_NSL : " " " " rear foglights
KALTUEBERWACHUNG_RL : " " " " reversing light
KALTUEBERWACHUNG_SL_LHI :" " " " parking light(left)
KALTUEBERWACHUNG_SL_RHI :" " " " parking light(right)
Actual wording for setting may vary slightly.
There is a "translations.csv" file buried in the NCS Expert file tree. Very helpful.
#1203
Thanks cerenkov.
I'm not sure why, but my FRM file doesn't have those lines???!?
I was able to find them in an old error FRM file (meaning an attempted FRM download that I opened in texteditor before I got "coding ended" from NCSEXPERT. So I think has all modules not just the FRM, but I could be wrong).
I guess one question is how big should the FRM file be? I think 24kb.
This is what I have in the FRM file (24kb) I just downloaded from the car
This is what I can see in the old FRM error file (119kb)
So you can see the lines you referenced are there right in between the V_S_HI_KRV & NACHL_RKW in my "error" file but not in the FRM I just downloaded.
Any thoughts? Could it be in another module?
Should I add those lines back in to my newly download FRM?
Code:
V_S_HI_KRV wert_01 NACHL_RKW wert_01
Code:
V_S_HI_KRV wert_01 KALTUEBERWACHUNG_SL_V aktiv KALTUEBERWACHUNG_BLK_V aktiv KALTUEBERWACHUNG_BLK_H aktiv WARMUEBERWACHUNG_SL_V aktiv KALTUEBERW_RL_BL_1 aktiv KALTUEBERW_RL_BL_2 nicht_aktiv WARMUEBERWACHUNG_BLK_V aktiv NACHL_RKW wert_01
#1205
I printed out all the steps, I have two types of cables, and i still get the same error and can go no farther with the programing/reading process. does anyone know why?
error- VIN is faulty
COAPI-2020:ECU does not answer IFH-0009: No response from controlunit CASPLUS some more stuff..
I have troed to enter the vin manually and get same faulty error
2016 countryman/S ALL4 ANYONE??
#1208
Well I tried adding the below lines suggested by cerenkov, no luck.
It actually looked like the CRM wouldn't accept the change. I would get 'code ended' every time from NCSExpert, so I know it wrote to the car. But it always failed to disable the bulb warning. I would then read the FRM again and the 4 lines I added were not present. I tried multiple times.
Oddly they were not in my FRM file from the start.
Any other ideas on how to disable the side marker bulb checks?
I'm not sure what I'm doing wrong here. I've coded many other things on my car without issue with NCSExpert.
Can anyone share their R56 FRM file for me to compare to?
Code:
V_S_HI_KRV wert_01 KALTUEBERWACHUNG_SL_V nicht_aktiv WARMUEBERWACHUNG_SL_V nicht_aktiv NACHL_RKW wert_01
#1210
I've tried DATENS v57.2 and cannot read the VIN or anything else since I got a new KOMBI module last year and the dealership wiped everything away during the module install and H/K radio replacement.
Only thing that works is the verification step "Launch INPA and verify that it reads Battery: ON and Ignition: ON".
I had similar issues with more than one car after update.
I realized that my cable (auto-detects if it is KCAN or DCAN) don't work that way anymore. i put a switch on it to enable/disable bridge between pins 7&8.
#1213
Cooper Countryman/S ALL4 2016 programing error??
So i have purchased a new laptop for this so i have nothing else interfering. And it works much better now.. I can load the FG,NRCL,and CHASSIS
BUT: I get a FA not type #0715 error
When I try to load FA manually it asked me the attribute: Anyone know what i should enter there?
The list starte like this..
#0715
$205
$210
$249 and so on?
Hey anyone ever get this?
#0715
$205
$210
$249 and so on?
#1215
#1216
I managed to get all this working yesterday and coded my Bi-Xenon retrofit in about 10 minutes using the v58 datens. I'm a 15 year veteran of IT and it was scary and intimidating, but once you figure it out, it's not all that hard.
I didn't have any trouble using the most recent tools on Windows 10 64-bit with this cable:
#1217
Amazon.com: PeleusTech INPA K+CAN K+DCAN Car Diagnostic Tool Cable OBD USB Interface for BMW R56 E87 E93 E70: Automotive
#1218
Super curious how you did this, I've been trying on a windows 7 laptop with this exact cable and can't seem to make it work. I get to the test suite and it tells me that The Battery is on but not the ignition no matter what I do. I haven't tried the latest files yet, but the ones that came with the setup instructions, do I maybe need to try the latest versions? I'm also a Software developer by trade so I know my way around a PC fairly well and am a little baffled. Searching for the errors I find only references to people who have made their own cables and have it wrong, which isn't super useful.
I followed the guide found via this thread for BMW Coding Tool 2.12:
http://www.e90post.com/forums/showthread.php?t=1204192
I didn't actually use the Coding Tool, I used straight NCSExpert4_x64 and NCSDummy, but I did follow his guide for setting everything up.
#1219
no answer from ECU
help.
ERROR! Modul: LFCDHDIA.CPP (A_E65CAS.IPS/IPO), Proc: CDHapiResultText, LineNr: 01, ErrorNr: 2020
COAPI-2020: no answer from ECU
IFH-0009: NO RESPONSE FROM CONTROLUNIT
>> ERROR! Modul: COAPI2.CPP, Proc: coapiRunCabd, LineNr: 06, ErrorNr: 2020
FGNR_LESEN
>> ERROR! Modul: COAPI.CPP, Proc: coapiReadFgNr, LineNr: 04, ErrorNr: 2020
FGNR_LESEN: A_E65CAS
FGNR_LESEN
#1220
Hi guys, new member here, great threat. Learned quite few things however I'm having a problem connecting to the ECU of MY 2012 Contryman. It's one of those $20 cables from Ebay and I'm thinking that I've got a faulty or incomparable cable. It has a white board and pins 7 and 8 are not connected as can see bellow.
I've install the drivers and the software following the steps in the guide and everything looks fine until connecting to the car. At first when I connect it the red light on the cable itself comes on and when I try INPA it says the ignition is off although it's on on the car. Then couple of minutes later the light on the cable goes off and when trying INPA again it reads battery and ignition just fine. But then NCS is giving me a faulty VIN error.
Any ideas? Is it the cable or something I'm doing wrong with the installation ?
By the way anyone one in North Atlanta area done some coding ?
#1223
2013 R61 Paceman
#1224
#1225
The same state both.
