Electrical The [Complete] NCS Expert DIY
  #76
Old 02-15-2012, 10:41 PM
quality_sound's Avatar
quality_sound
quality_sound is offline
NCS Expert. I THINK I found a copy on bmwcoding.com but I'm not entirely sure since the file name is "inpa k+can.rar"
If you have it and could upload it it would be great.
Thanks.
  #77
Old 02-15-2012, 10:43 PM
NintenTom's Avatar
NintenTom
NintenTom is offline
Thanks.
That should be the correct one. What version is it?
  #78
Old 02-15-2012, 10:46 PM
quality_sound
No clue yet. It's still downloading. German internet isn't exactly fast so it'll be another hour or so before I know.
  #79
Old 02-15-2012, 10:52 PM
NintenTom's Avatar
NintenTom
Hmm all I could find on my desktop was ediabias 7.2. Link to download is below:
http://www.mirrorcreator.com/files/6..._2_0.rar_links
  #80
Old 04-03-2012, 12:45 PM
z3bum's Avatar
z3bum
z3bum is offline
Fyi, there is a ton of information on the web about using NCSEpert, INPA and what cable is needed, etc.
Here are some recommended sites, along with the site I bought my cable from. I have not had a chance to read any MINIs yet, just BMWs, (1 and 3 series so far) but if you follow the directions carefully, you should be able to get the software working.
A couple things to note...
INPA, EDIABAS, NCSExpert and NCSDummy run only in 32 bit Windows.
BMW GT1, DIS run in Unix. Hence folks installing VMWare on windows and running them in a window.
For general coding, like fiddling with lighting, key/fob/roof stuff, BC in dash computer, etc, you would use NCSExpert. INPA is used to diagnose issues, and EDIABAS is a communications app that enables everything and runs in the background.
Here are some links for installation files, instructions and coding information. As you all get successful codes working on MINIs post them here on NAM and the other sites so folks can find out. Once I get access to some MINIs, I will do the same.
Installation and operation of the various BMW coding applications
http://bmwcoders.com/
Info on available codes for MINI and BMW
http://www.bmwcoding.com/forum.php
Cable you need. This one has been tested by lots of folks, including myself. It does take about six weeks to ship to the USA, but it works. Plus you need about six weeks of reading and application installation time to get everything working! (Well, maybe not quite that long)
http://www.one-stop-electronics.com/...&product_id=16
  #81
Old 07-21-2012, 12:11 PM
hooray4kurt's Avatar
hooray4kurt
hooray4kurt is offline
I need help coding out the bulb checks for my LED lights... are there any people local to the sf bay area?
  #82
Old 07-21-2012, 12:20 PM
NintenTom's Avatar
NintenTom
Check the Google docs out. I disabled my led bulb errors (interior and exterior) by turning off most of the FRM modules by trial and error.
  #83
Old 07-21-2012, 12:44 PM
hooray4kurt
thanks for the heads up tom i checked it out but it looks like ill need a PC and a dcan cable :(( i have neither (apple fanboy)
  #84
Old 10-24-2012, 11:38 AM
ragingMINI's Avatar
ragingMINI
ragingMINI is offline
I can confirm that it's doable with a MacBook Pro and VMWare Fusion.
  #85
Old 11-13-2012, 03:47 PM
Jmaxxz's Avatar
Jmaxxz
Jmaxxz is offline
I have a 2012 Mini Cooper Hardtop, and after following the guide I am still having issues. In INPA my computer detects when I turn on and shut off my car, however when I fire up ncs expert load up the profile and pick the r56 chassis I get the following 2 errors:
'vin is faulty'
COAPI-2020: no answer from ECU
IFH-0009 NO RESPONSE FROM CONTROL UNIT
I am using the v45 dates, and ediabias 7.2. Any help would be greatly appreciated.
  #86
Old 11-13-2012, 10:09 PM
calforhelp's Avatar
calforhelp
calforhelp is offline
So I've been able to code the comfort close sunroof option on a few cars but I've gotten the request to do this on a 2013 R57 convertible. So does anyone know if it's possible to close the sunroof portion of the R57 with the key fob the same way you'd close the R56 sunroof?
I'd think it'd be the same code but I'm not sure.
  #87
Old 12-22-2012, 08:02 AM
pureinstinct93's Avatar
pureinstinct93
pureinstinct93 is offline
Does anyone have any mirror/alternate links to the OP's links which appear to be dead?
  #88
Old 01-02-2013, 06:26 AM
john171's Avatar
john171
john171 is offline
Am getting ready to try it using Bootcamp and Win 7, just ordered the cable, which means I have six weeks to get all the reading done! Will post results for both Bootcamp and coding
  #89
Old 01-06-2013, 11:34 PM
DeadEnd's Avatar
DeadEnd
DeadEnd is offline
R59 NCS Expert Coding
Hi, has anyone successfully coded through NCS Expert to the 2012 Mini R59 Roadster? Will BMW Standard Tools v2.11 suffice? Looking for some friendly advice. Thanks.
  #90
Old 03-11-2013, 07:18 AM
fxmartin's Avatar
fxmartin
fxmartin is offline
Hi, i'm realy interested about the guide and the R56 Codes Spreadsheet but the link doesn't work anymore. Does someone can upload it again ?
Thanks for all and have a good day
  #91
Old 03-25-2013, 03:35 PM
m100's Avatar
m100
m100 is offline
Look at the first post in the thread. The link in this text: Jbourne's R56 Spreadsheet
  #92
Old 03-26-2013, 12:35 PM
fxmartin's Avatar
fxmartin
fxmartin is offline
Hi,
Thanks for your answer, i miss this link.. i'm sorry for this mistake !
Thank you very much and have a good day
  #93
Old 08-20-2013, 09:16 PM
OreoPanda's Avatar
OreoPanda
OreoPanda is offline
hello all, first off thanks to those who have done a ton of leg work for us all. I have installed everything and purchased the correct cable off of amazon for $30! once I recurved the cable I tested inpa and everything was on. then I opened ediabas and noticed it's in German even though I selected English. I was able to read a trace file but i would like to be able to see what I actually clicking on, any help would be great.
  #94
Old 10-15-2013, 05:16 PM
davidh2davidh2's Avatar
davidh2davidh2
davidh2davidh2 is offline
Yes, alot of this install is in English, the tabs at the bottom, the menu's, but the results come back in partial German.
Also, Does anyone know of a listing for the error codes for an R56. I'm getting 5D8C, 5E05,
and a general error, ERROR_ECU_SERVICE_NOT_SUPPORTED
Old 10-17-2013, 11:03 AM
1drummer's Avatar
1drummer
1drummer is offline
I have a 2007 MCS and would like to install NCS Expert along with purchase the right cable and make changes. I have tried to download the program, but it keeps giving me an error when it goes to the site for download. Can you get me to a good site along with where I can get a good cable?
Richard
  #96
Old 10-23-2013, 03:21 PM
Comasynthesis's Avatar
Comasynthesis
Comasynthesis is offline
Links fixed. OP updated.
  #97
Old 11-13-2013, 07:25 AM
TampaMCS's Avatar
TampaMCS
TampaMCS is offline
Not exactly. The module for sunroof cars is SHD, while the Convertible is CVM if I recall from working on mine the other night. There is an option I found and set on mine for comfort closing the top, but I cannot get it to actually work (either that or I don't know the correct keyfob sequences). If you figure it out please post back here.
I've also had issues getting the side windows to one touch up. My car is a 5/13 build R57 and I have been using the 49.4 datens, and BMW tools 2.12.
  #98
Old 11-13-2013, 12:18 PM
TampaMCS's Avatar
TampaMCS
TampaMCS is offline
Did some digging around some other forums. One guy was able to get his e93 to do it, and another had it working but had taken the car in for service and they flashed his modules. After flashing, he put the same codes in and he lost the functionality.
  #99
Old 12-03-2013, 12:31 PM
RYOAK5150's Avatar
RYOAK5150
RYOAK5150 is offline
Can anyone assist in the set up of WinKFP? Everything else has been working for me, I just now started with WinKFP and can't get the ZUSB to load any data as found in my initial post below. Id appreciate it!
Need WinKFP Data Files
  #100
Old 12-04-2013, 05:12 AM
RYOAK5150's Avatar
RYOAK5150
No one?? Theres got to be someone who successfully used/uses WinKFP...
Quick Reply: Electrical The [Complete] NCS Expert DIY
