Electrical NCSExpert DIY(do it yourself)
#76
PS: SO I WAS CHECKING THE SPREADSHEET REVISIONS AND I SEE SOME PPL ERASING DESCRIPTIONS AND FORMULA STRINGS -I HAVE ASKED BEFORE NOT TO EDIT RANDOMLY THE SPREADSHEET ESPECIALLY IF IT IS NOT TO EDIT SOMETHING USEFUL
LATEST PERSON IS SMARCO111, I DONT KNOW IF YOU DID IT ON PURPOSE BUT YOU ERASED STUFF ON THE SPREADSHEET AND LEFT IT BLANK.
IT IS NOT COOL TO SEE STUFF GOING MISSING FOR NO REASON, I WILL KEEP ON EYE ON THIS MORE CLOSELY NOW.
I REALLY DONT WANT TO LOCK THE SPREADSHEET FROM EDITING AS I WANT PPL TO BE ABLE TO ADD THEIR DISCOVERIES.
PLEASE BE CAREFUL ...[/QUOTE]
GETCKO
I'm Sorry!! I'm smarco111..... i really did not do it on purpose I did not even notice that I had left something in blank until today reading this thread...
I did add some X on the 2010 year that where missing and I got them to work...i did it so that people could know that they worked on a 2010... It was all done in good faith. I just don't want to be causing any problems to anyone I'm sorry and I wont be touching anything from now on!
GETCKO
#77
#79
Gonzo asked me about a change I didn't know was needed after we got done coding today. Maybe you guys can help. Can you make a 2007 r56 do the one touch roll up/down on the windows? If so anyone know the command?
Also, on the 2007 R56, after telling the SPEG module that there was an alarm the heartbeat started working right away.
I have the same on my 2011 R60, but no Heartbeat, do I need to make the change on the KOMBI also?
#80
Help!!!
Calling all coders! I blew it. I took a phone call in the middle of coding(DOH!) and didn't save my trace file correctly. Long story short......if any of you are working with an R60 I need a trace file for the KOMBI module. Any help is appreciated!!
EDIT: False alarm. I had the right file.
#81
on
The great thing about tracefile modification is that if you screw something up, you can "default" the module back to original settings. Just program the module with the tracefile modification option in the profile editor turned off!
#84
I have a C-Man S and would like to know if it is possible to have something other than car speed showing from the center window in the tach. Specifically, I would like to show time and perhaps temperature instead of speed.
I can't swear to this, but it seems that I could define what appeared in this window in my 2008 MC, but I cannot with the Countryman.
Many thanks,
John Richard
Many thanks,
John Richard
#85
on
Yes, you maybe able to change the digital speed permanent setting to not active in the KOMBI module. If it works you will see the Time and Temp in the upper window as long as you are showing avg mpg, instant mpg, avg speed, or miles remaining. There should still be the speed option as well (then you will the temp in the lower window).
#86
if you click on File - Revision History - you can restore older versions.
Yep! You want to follow the same process after you modify the Vehicle Order (however, programming the entire car is a preferred option after a VO change)
#87
on
As a side note, the Vehicle Order defines what the tracefile settings will be. So when I installed the bluetooth system, I was able to test the bluetooth by enabling in the Rad2 module tracefile. Then when I was confident it was working I then made the change permanent by modifying the VO strings and then defaulting the RAD2 module (which then made the voice control active as well).
#88
Has there been a change for the "heartbeat" mod for the alarm? In the spreadsheet it is now just listed as SPEG, DWA_VERBAUT. I thought there was another file you had to change.
I haven't done it yet, but this would be my next mod.
FWIW, I had a BMW tech guy come by to look into the noise coming from my car. It was the fan-rattling noise that came about after I started coding. He says it is rather easy to code and rather safe. Just as long as you are not totally negligent. He also was mentioning another program besides NCS. I'll try to get more information about it when I see him again.
#91
#92
#93
If it is when you are trying to read or code a module that it *possible* that the datens could be out of date - but it seems unlikely. Do you have this problem with every module, or just some?
#94
From the possible mod tab, VIDEO_DENY is located in the DSC module as of 2011 model using v41 datens. LEGAL_DISCL is also located in this module. NCD Dummy has trouble translating the daten for this module, so I've guessed that the setting should be changed to deny_never from deny_slow_key for VIDEO_DENY.
I don't yet know if I've been able to change these settings. I get an error every time I try to read or update the module. The error pops up right when a control message pops up on the LCD screen about trouble with the ABS, presumably when the module reboots.
#96
Ya, that's kind of what I was going for purely as an experiment. I really haven't run into great need to display video on the LCD whilst driving. I was trying simply to see if I could. Suffice to say, this and the LEGAL_DISCL setting do not seem to have had any appreciable effect.
#98
One touch windows up
Can you update the excel sheet with the following. This allows the one touch windows up feature which was not included in at least the 2007 models. Tested and confirms works, only caveat is ignition needs to be on.
FH_MAUT_ZU_AKTIV_FAT
FH_MAUT_ZU_AKTIV_BFT
change from nicht_aktiv to aktiv ( in FRM )
#99
Hey guys,
Just getting into the programming and I found the cable etc. through the site in post #1 but it also has software on it; BMW INPA K+CAn... Anyone knows what it is?! The site shows;
Features
- read and delete errors
- adaptations
- driver programming
- applu coding
- and others...
Sooo, can we use it for something or is that covered by the NCS program as well?!
Features
- adaptations
- applu coding
- and others...
#100
