Electrical LED Bulbs
#203
LED Bulbs
i bought the carly app ... mycarly.com
it lets you code out the bulb checks by choosing from a menu ... no "coding" at all
in fact all of the coding options are available in carly and all are picked from a menu ... much easier than NCS
also does battery registration
also reads/resets CELs, including the mini specific codes and gives plain language discriptions
also resets service reminders
and more
and more
#204
and more
and more
#206
#207
So I decided to screw the damn NCS (no one with experience with me) and went all canbus on the outside and I'm really happy with my bulbs. The things are built like tanks... Interior brightness is INSANE right now... No error codes as of now... Been a few weeks... but anyone else experiencing the front map LEDs not turning truly off? They are always on (even with the car shut off) in a very very dim mode...
#208
I'm overwhelmed with all the terminology and options to get reliable bright white license plate lights with no errors. I like the simplicity of the Carly option, but if I'm looking at the products correctly, it looks like you need a $59 app and a $35 adapter (~$100 total after tax in texas). While it looks like a cool app, I'll probably use it once, and only once (doubt I'll be coding more than the lights, or using diagnostics).
I think I have the ability to go the other route (laptop + usb cable + software), but I can't find a simplified guide. The knowledge required to do this with confidence exists in 20+ forum postings, some of which might contain old or conflicting information.
#209
#210
#211
#212
Also, I have a Paceman and I cannot get ANY 1156 LED bulb to work in the rears.
I did see "LED TURN SIGNALS" in NCS - wondering if that needs to be activated for LED rear indicators to work. They just dont light up at all in the back. The brakes do, but I can't find a good enough bulb that throws the light in the correct places. The paceman has a weird reflector setup.
#213
Had the same issue on my r61 front map lights, rear map lights were OK. So I just left all map lights halogen. Shrug. They don't come on anyways when the doors open.
#214
i checked that ALL the bulbs were completely off at night in my garage with lights out
i also have the ZIZA license plate LEDs ... perfect match to the xenon headlights
10-01-2015 12:13 PM
09-30-2015 11:39 AM
09-29-2015 12:17 PM
09-29-2015 12:16 PM
09-29-2015 12:11 PM
