Electrical Close Windows & Sunroof with the remote, yes you can
#276
One more to add to the list:
In the RAD2 module change VOL_TEL_MAX_RAD from "wert_0" to "wert_01" to allow to you turn up the volume higher when using the bluetooth handsfree for telephone calls.
I sometimes found that I couldn't get the callers volume high enough during a call, and this setting definitely helps. Watch out though - you don't want to damage a speaker if someone yells into the phone when you have your volume at max.
aabcds (06-06-2020)
#278
I have an '09 R55 S, which cable is the correct cable to purchase? Also would that cable be usable for a '12 R60 S?
http://www.ecutool.com/BMW-INPA-KCAN_1939.html
But it says for BMWs 1998-2008.
#279
1. It looks like it is being sold by someone that is selling other similar products, as opposed to those eBay sellers who sell cables, iPhone covers, everything under the sun.
2. Description looks OK.
However you need to check the seller out more to be more certain.
Ask them non leading questions such as what R56 year models will it work with? rather than asking if it will work on a 2009 R56? Ask if it will work with a SAAB 92? If answer is yes, forget them.
Ask them what support is offered it the system doesn't work and if the system doesn't work how will you convince them that the cable is faulty and how will they rectify the situation.
It's hard enough to get a Mini coding system working without having to deal with knowing whether the cable works or not. So finding a seller that understands the issues is very important.
#280
#281
Sun Roof Close using key fob
I attended a rally in Las Vegas and there was a person who had all the equipment. It was great, I had a few things programed. Recently, I took my car into the dealer for a brake light problem and they deleted all my programs. So now I'm looking for someone in Southern CA that is knowledgeable about this. Does anyone have any information?
#282
#284
Hi folks,
Sorry if this is already mentioned here but is there a way to enable remote fob closing of the R57 (LCI) convertible roof and windows? I enabled everything related I could find in CAS and CVM but it's not going up.
I did however successfully change the CHAMP2's speaker setup setting from hifi to stereo after retrofitting the HU. Hifi sounds awful if you don't have the sound pack...
AUDIO_SYSTEM_CIC
HIFI -> Stereo
Cheers,
H
AUDIO_SYSTEM_CIC
HIFI -> Stereo
Cheers,
H
#286
It does not. Either way, just don't stick your hand through the window when it's closing! It's slow enough!
#288
That's basically it. Although there was a huge issue with the pinch protection in older (07 ~ 09) cars since in some instances the protection would trigger when the sunroof was extremely hot!
#289
Wait wait what's this? I may have experienced this a few days ago which I attributed to age of the car (09), but tell more?
#291
Apparently, my little MINI is far more capable of changing things than I ever thought! Anyone in SoCal with the proper comp and cables to make my R56 do things like keep the fogs on with high beams? Default to fogs on without having to switch them on upon restart? Maybe make the red lights in the rear bumper cover (next to the reversing lights) come on when I hit the brakes? I am computer illiterate, so would be willing to pay for these services. Bring your laptop, your cables, program my MINI.
#292
Anyone in the PHX area got a comp and cable, and the inclination to help out?
I'd like, if it's possible, to have the sunroof on my '03 R53 not slide back when opening the windows with the key or remote. If it could just pop the back up, but not slide back, that would be optimal, but if not, if it could just not respond to the window opening command, that'd be great. I'd like to plug the sunroof motor back in so I could pop the back up, but it binds about 1/3 the way back when sliding back, so it'd be nice if I could avoid it doing that via the remote or key when opening the windows....
C ya,
Dutch
C ya,
Dutch
#294
#295
folding mirrors
Strobeyprobey,
I am trying to find codes to re-animate the exterior mirrors .
They used to fold up on door lock. The Nav screen ask if I wanted to reset,
unfortunately I said yes. Nowthey do not fold from fob.
Any info is helpful . Working on getting cables.
Thank you,
2008 S type MFG date 02/20/2008
Probally an R56 , but to new to me to know.
Thank you,
Navigation & Audio HK Replacement With New Components
Filmy
15
06-06-2023 06:27 AM
