Electrical Universal ScanGaugeII XGuage Thread
ScanGuageII Initial Settings for R56 (may work for others)
ENGINE SIZE: 1.6L
MORE>SETUP>ENGINE>1.6 LITERS >SET
TANK SIZE: 13Gal
MORE>SETUP>FUEL>TANK SIZE>13 GALLONS >SET
FUEL: GAS (should be default and not need to be changed)
MORE>SETUP>FUEL>TYPE>GAS
COM MODE: CANSF (should default to this and not need to be changed)
MORE>MORE>MODE>CANSF >FORCE
PIDS: ALL (should be default and not need to be changed)
MORE>MORE>MODE>PIDS>ALL >SAVE
FUEL CONSUMPTION CALIBRATION: 10% (yours may vary. use this if you don't want to do the fillup thing)
MORE>FILLUP>10.0% >DONE (increase the gals until it reads 10.0%)
COLOR: RED (closest match to stock gauge lighting)
MORE>DISPLAY>MORE>COLOR>RED
UPDATE RATE:FAST (default is Normal, but CANSF can use Fast)
MORE>MORE>RATE>FAST
ENGINE SIZE: 1.6L
TANK SIZE: 13Gal
MORE>MORE>RATE>FAST
XGAUGES for R56 (CANSF) (may work for others)
BOOST (w/o MAP)
TXD: 07DF010B
RXF: 0441850B0000
RXD: 2808
MTH: 00910064FFxx
NAM:BST or PSI
Where FFxx from MTH will fit one of the following offsets:
14.0 -- FF74
14.1 -- FF73
14.2 -- FF72
14.3 -- FF71
14.4 -- FF70
14.5 -- FF6F
14.6 -- FF6E
14.7 -- FF6D
14.8 -- FF6C
14.9 -- FF6B
15.0 -- FF6A
Best way to guess your offset would be to first display MAP on the scangauage, and while the car is in neutral, press the start button but without the clutch pedal depressed. What this will do is initiate the engine electronics without starting the vehicle. Next, take whatever MAP number the Scangauge displays and complete the MTH xGauge.
WideBand Air Fuel Ratio
TXD: 07DF0134
RXF: 04414534
RXD: 2808
MTH: 05B900800000
NAM: AFR
Or you can use the General CANSF:
TXD: 07DF0144
RXF: 04414544
RXD: 2808
MTH: 05B900800000
NAM: AFR
HorsePower
TXD:00
RXF:400080000000
RXD: 0000
MTH: 000A00170000
NAM: HP or HPR
Air Temp *F (ambient)
TXD: 07DF0146
RXF: 04410546
RXD: 2808
MTH: 00090005FFD8
NAM: AIR
Fuel Level (%)
TXD: 07DF012F
RXF: 0441052F
RXD: 2808
MTH: 006400FF0000
NAM: FLV OR FUL
Catalyst Temp *F
TXD: 07DF013C
TXF: 0441053C
TXD: 2810
MTH: 00010005FFD8
NAM: fCA or CAT
BOOST (w/o MAP)
TXD: 07DF010B
RXF: 0441850B0000
RXD: 2808
MTH: 00910064FFxx
NAM:BST or PSI
14.0 -- FF74
14.1 -- FF73
14.2 -- FF72
14.3 -- FF71
14.4 -- FF70
14.5 -- FF6F
14.6 -- FF6E
14.7 -- FF6D
14.8 -- FF6C
14.9 -- FF6B
15.0 -- FF6A
TXD: 07DF0134
RXF: 04414534
RXD: 2808
MTH: 05B900800000
NAM: AFR
TXD: 07DF0144
RXF: 04414544
RXD: 2808
MTH: 05B900800000
NAM: AFR
HorsePower
TXD:00
RXF:400080000000
RXD: 0000
MTH: 000A00170000
NAM: HP or HPR
TXD: 07DF0146
RXF: 04410546
RXD: 2808
MTH: 00090005FFD8
NAM: AIR
Fuel Level (%)
TXD: 07DF012F
RXF: 0441052F
RXD: 2808
MTH: 006400FF0000
NAM: FLV OR FUL
Catalyst Temp *F
TXD: 07DF013C
TXF: 0441053C
TXD: 2810
MTH: 00010005FFD8
NAM: fCA or CAT
how accurate is the fuel level percentage? If would be nice to have a read out that is linear.
The Cat temperatures... I know a lot of cars have temp readings on their cats but this scan gauge code is just a derivation of other measurable stuff to calculate a temperature range for the cats (similar to boost)? And which cat are we talking about, DP or the 2nd unmonitored one.
Lastly, what purpose does knowing cat temperatures provide? I know they have to be a certain temperature before they become efficient but is there another reason?
on
Has anyone had any luck with the fuel level displaying when set up as above? It's the only one I've programmed that isn't working. The display stays blank.
Edit: Not sure what I did but it works for me now. I'm going to see if I can start mapping the % vs. actual amount vs. "carrots" to see what %/amount of fuel is associated with each "carrot" on the OEM guage. Who said life is boring?
Any threads on R53 sg2 information? Is it possible to get a PSI or Boost reading instead of MAP? I have mine set for CAI temp, Water Temp, RPM and MAP.
Could anyone explain what these numbers mean or where they should typically be???
What should the water temp be before the car is "ready" to go ?
My map is usually in the 6 to 14 range. When I go fast it will go up to about 28. Good? Bad?
How much above ambient temperature is considered heat soaked? I don't think I can get it there off the track?
Thanks to any constructive replies!!!!
I am trying to obtain the CANSF codes for oil pressure in psi. My 2011 MC has an oil pressure sensor and I would like to add an oil pressure XGauge on my Scangauge II. I requested the oil pressure codes for a Mini Cooper from Scangauge and was told they don't have it. I have been scanning the internet and the closest I have found is the CANSF codes for oil temperature. My Bentley manual doesn't indicate any oil temperature sensor for the 2011 MC. I would appreciate any help in finding the codes for oil pressure. The following are the CANSF codes I found for oil temerature:
TXD: 07E0221310
RXF:046245130610
RXD:3010
MTH:00090005F060
TXD: 07E0221310
RXF:046245130610
RXD:3010
MTH:00090005F060
Note that the initial interrogation TXD is 10 digits here, while all the other Xgauge codes for the MINI have 8 digits. Don't really know what that means.
Good thread...
Have a problem that a ScanGage that I used on my '07 S doesn't read the same on my 2012 S. On the '07 on MAP it would read absolute pressure; in other words, at idle it would read about 3-5 psia and at boost about 24 to 27.5 (over boost). Now on the 2012 it reads 13.9 to 14.5 psia and then at boost 24 to about 27.5. So it seems that it is now reading the boost without the MAP (as post #3 says you can do).
Does anyone know how to set it so it will read MAP on the 2012 like it did on my '07? Or do I need to go back to ScanGage for some sort of update?
ScanGauge Mount
I thought that people might be interested in the mount that I made for my scangauge for my 2012 MCS. It is 3/4" angle aluminum. The right side rests on the steering column and the left side has a piece pop rivited to it so it match the curve of the side vent. It is Velcro'ed in place using the automotive selfstick for plastic. That is really important as that is made for the heat, the other will come un-stuck. I coated the aluminum with black plastic-cote (spelling?) so it blends in.
In response to your first question, check out SBARTON's third post. Standing on this earth at sea level we are under approx. 14.7 psi of pressure. If you turn on your ignition without the engine running, the MAP should measure that 14.x pressure just from the atmosphere. Boost will be whatever is above that number ( 20.7-14.7=6.0 psi boost), vacuum is whatever is below that number.
ScanGauge mount
Here are a few more pictures of the mount I made for my ScanGauge. From my previous post - It is 3/4" angle aluminum. The right side rests on the steering column and the left side has a piece pop rivited to it so it match the curve of the side vent. It is Velcro'ed in place using the automotive selfstick version for plastic. That is really important as that is made for the heat, the other will come un-stuck. I coated the aluminum with black plastic-cote (spelling?) so it blends in.
I didn't think of that. The new engines regulate air at the valves instead of the throttle body. So no more vacuum readings!
