Electrical Interior Dash Light Change?
Old 02-17-2010, 12:40 AM
Wooley's Avatar
Wooley
Wooley is offline
I was wondering if anyone has changed their interior dash light color from the orange to anything different? I haven't found anything on it how much it would be to change and how long of a process it is. If you have any information on this it would be appreciated.
Wooley
Old 02-17-2010, 04:32 AM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
-=gRaY rAvEn=- is offline
Moderator
This is a mod on my list of to-do's. One has to remove the various lighted components from the dash and center stack, open them up and then with a variable voltage soldering iron, unsolder the old led's from each circuit board and replace them with these:
http://www.oznium.com/plcc-2
It is a bit tedious to do, but the results are absolutely stunning.
Old 02-17-2010, 09:29 AM
Puma|Mini's Avatar
Puma|Mini
Puma|Mini is offline
There's a thread on it on m|u. I'll look it up and get back to you.
Old 02-17-2010, 09:44 AM
Puma|Mini's Avatar
Puma|Mini
Old 02-17-2010, 02:04 PM
NightFlyR's Avatar
NightFlyR
NightFlyR is offline
I have the blue also and love it
Old 02-17-2010, 02:11 PM
Wooley's Avatar
Wooley
Wooley is offline
Is there any way someone could write up a guide on how to change these out?
Old 02-17-2010, 03:09 PM
rkw's Avatar
rkw
rkw is offline
The topic is covered in these threads (and a few others):
https://www.northamericanmotoring.co...backdrops.html
https://www.northamericanmotoring.co...eedo-tach.html
The concept is simple -- take the components apart and replace the LEDs. You can do it yourself if you have good soldering skills and experience with surface mount technology. If you don't have experience working with surface mount electronics, you might want to find somebody to do it for you. There are consequences $$$$ if you mess up the circuit board.
Old 02-17-2010, 07:51 PM
Wooley's Avatar
Wooley
Wooley is offline
The more I look at this the more I think this could be out of my hands. I am trying to find somone I guess who could do this in the Virgina/DC/Maryland Area if anyone knows any shops that do this.
Old 02-23-2010, 11:18 PM
Haseo461x's Avatar
Haseo461x
Haseo461x is offline
how hard is this to do?
Old 02-24-2010, 01:21 AM
rkw's Avatar
rkw
rkw is offline
The main question is whether you have experience soldering surface mount electronics and confident about your skills. It is not difficult to remove and disassemble the speedo and tach to access the circuit boards. If you are good at soldering SMT, it would be straightforward to replace about 25 LEDs on the circuit boards. If you are not experienced soldering SMT, I wouldn't try to train yourself directly on these boards . Practice on something else until you are confident you won't mess it up.
Old 08-12-2014, 02:12 PM
RiceMini's Avatar
RiceMini
RiceMini is offline
Wouldnt changing the leds change the overall circuitry of the board itself? Since different color leds have different voltage drops. So wouldnt you have to add or remove some resistors to accomodate for this?
Old 08-15-2014, 03:43 AM
chris.j.lamb's Avatar
chris.j.lamb
chris.j.lamb is offline
possibly
Old 10-17-2014, 08:50 PM
Catalyst105's Avatar
Catalyst105
Catalyst105 is offline
My fiance just got a 2007 mini and I intend on replacing all of the LEDs in the gauges and dash. I've replaced the LEDs in 3 motorcycles gauge clusters, my old Volkswagon GTI, and current Toyota Tundra. This mod is not difficult or tedious as long as you have soldering skills which isn't even a big deal as long as you practice before you do the real thing. Watch some youtube videos and practice on an old broken device with a circuit board. Seriously it's not a big deal. My experience is that it is harder and more tedious to disassemble everything to get to the circuit boards. Replacing the LEDs is actually easy and fast once you get into a rhythm. My Tundra had 50 something LEDs and the actual replacing process took about an hour. It took longer getting everything apart and back together. This mod is a more intimidating mod than it is difficult.
Old 10-17-2014, 08:53 PM
Catalyst105
Oh, and as long as you replace the existing LEDs with the same type of LED it will not affect voltage. You are just changing one color for another. I'll do a write up and post it with pics when I do it in the next few weeks or so.
Old 03-29-2015, 11:05 AM
Suprememrvn's Avatar
Suprememrvn
Suprememrvn is offline
What's the led build size for the r56? Thanks
07-16-2020 12:54 PM
sprp85
08-22-2015 06:16 AM
FLYM1N1
08-16-2015 01:17 PM
skippermini
08-12-2015 10:05 PM
xpunisherx
08-10-2015 10:50 PM
Quick Reply: Electrical Interior Dash Light Change?
