A few weeks ago the temp on the OBC showed -40 degrees and it was determined that there was a problem with the ambient temp sensor.
I stopped by the local dealership to buy a replacement but it cannot be installed because the female module that's attached to the wiring harness has been worn away due to dragging on the roadway.
(I have an Aero bumper and apparently there isn't anywhere for the ambient temp sensor to "snap" to, and it somehow cam loose and was dragging on the roadway.)
I need to know if anyone has had to replace the female module/harness and if it's pretty straightforward or challenging.
I do have soldering skills...
I'm picking up the female module/harness later today.
Thanks in advance!
Erika
Became a proud 1st time MINI owner on 01/13/07!!!
'06 HB/W, #1, #2, #3, #4 (Prod. date: 10/20/06)
Thanks in advance!
Erika
Erika,
Easy job splice in your two wires and you should be good to go.
__________________ 2 X Perma Grin tools & MidCal MINI's Dad(Navy 8300 MCPO)-2008 MCS DS/B, JCW Wing, Aero, Scoop, mirrors. (M7)Heatshield, USB, USS, Super AGS and Shift Knob. Marshall's Boost/Vac, H2O, Volt, Oil Pres. Gauges, BSH Catch can/DBP, TSW Springs, Helix Control arms, Go-Mini brake pulsar & no hole's plate, Borla Tour Exhaust. Custom MODS done by SRTech @ Custom Mini Shop 559-320-0004
