MINI Cooper MINI Cooper specs
MINI Cooper MINI Cooper Forums MINI Cooper Pictures
Mark Forums Read MINI Cooper radio MINI Cooper latest news
Go Back   North American Motoring > 2nd Generation MINIs > Modifications > Electrical
Sign in using an external account
Register Forgot Password?
Welcome to North American Motoring !
Welcome to North American Motoring,
» Latest Main Topics
Advertisement
Thread Tools Search this Thread
Old 10-10-2009, 09:08 AM
DMBFan2's Avatar
DMBFan2 DMBFan2 is offline
Gallery
programmable flasher/brake lights
I want to install a Custom LED Programmable Flasher Relay
( http://www.customled.com/products/fl...clrelaypro.wmv)
into my 03s but I do not know which wire is for the brakes/turn signals or the best location to set it up. Anyone have ideas?
I tried the http://www.mcaw.info/wds/mini/us/r50/index.htm site but I kept getting a "Parsing Error" and it will not load correctly.
Thanks in advance for your help!
Old 10-10-2009, 10:30 AM
Dr Obnxs's Avatar
Dr Obnxs Dr Obnxs is offline
Vendor
Gallery
Here you go...
Center brake light - Black/yellow
Left Brake Light - Black/Green
Right Brake Light - Black/Blue
Turn indicator rear right - Blue/Brown
Turn indicator rear left - Blue/green
That do it?
Matt
ps, that video is really annoying! ;)
FES Auto= Worlds Best Shiftlight-Ian Cull Auto-Up-Auto Sportplus - R52 Top Commander
but wait, there's more! InvisiLens - Bav Tech SW - High Current Relay Module-
'02 CR/W S, Bunch of fun mods... '08 NFR/S Clubbie, close to bone-stock...
Dr Obnxs' Musings: a blog about cars, energy, technology and more....
Old 10-10-2009, 10:53 AM
DMBFan2's Avatar
Gallery
I am trying to add it to my LED 3rd brake light which is Brown (assuming its a power lead) and Black/yellow (assuming this is the ground). The wires on the programmable LED is Red, White and Black. Red is power (obviously) White is intermittent power and black of course is ground. The problem I am having is that I have tried every combination I can think of and the programmable led is not working. Just regular brake lights come on. Here is a picture to help (or confuse things).
Old 10-10-2009, 11:09 AM
Dr Obnxs's Avatar
Vendor
Gallery
Brown is ground
everywhere on the Mini. That should solve the problem. Hook the black wire to the brown, the black/yellow to the intermittant (control) wire, and dig up power from somewhere. Then you should be good to go!
Matt
Old 10-10-2009, 11:23 AM
DMBFan2's Avatar
Gallery
Brown is ground? Huh...I guess that's a European thing. Made the switch and am looking for power from somewhere. Any thoughts? I was hoping to hook the red to black/yellow coming from the vehicle, the white to the black/yellow going to the LED.
Thanks again for your help. I have been on the internet for an hour looking for a wiring diagram. That is probably the hardest thing to find.
Old 10-10-2009, 11:32 AM
Dr Obnxs's Avatar
Vendor
Gallery
I'm betting...
that the module wants power all the time for it's little digital brain. The white is probably to hook up to the brake light wire to tell the little digital brain when to think.
There are tons of electronics in the rear passenger quarter panel. You could poke around there for a hot lead.
But before you get that far, just run a really long wire to something hot (battery or whatever) to test. Do you have the cig lighter socket in the back of your car? If so, you can test here with the key on. Make sure everything still works like we think it should before going to the trouble of routing all the wires. I hate it when I do a complicated wire routing job, knowing everything will work fine, and it doesn't. Test, test, test. Takes a bit of time on the front end, but saves tons of time overall!
Matt
Old 10-10-2009, 11:42 AM
Dr Obnxs's Avatar
Vendor
Gallery
OK
I just read the install manual here. You're right. The black wire should go to the brown ground on the Mini. The white to the LED and the Red to the Black/Yellow wire.
Set it in mode 1 for testing, and press the brake pedal. If nothing happens make sure you're getting 12 to the Black/yellow (see if it works with the stock light). If it works with the stock light but not when wired correctly, it may have been damaged by reverse powering (if so it's a crappy design. There's no excuse for that!)
Matt
Old 10-10-2009, 11:47 AM
DMBFan2's Avatar
Gallery
I figured it out...and I am an IDIOT.
The red lead goes to the black/yellow from the vehicle. The white goes to the black/yellow wire going to the LED and of course the brown goes to the black. Works just fine. Looks cool too.
I would like to hook all of my brake lights up to this now that I know how to do it. Maybe this will get people to see that I am coming to a stop and they won't get so close. Then again, some are just born to be jerks.
thanks again for your help. and your right, the video is annoying.
Old 10-10-2009, 11:50 AM
Dr Obnxs's Avatar
Vendor
Gallery
Glad it all works....
have fun with it!
Matt
Old 10-10-2009, 11:51 AM
Stig One Stig One is offline
Gallery
Quote:
Originally Posted by Dr Obnxs View Post
have fun with it!
Matt
I love the autosport dtc dsc module that you offer,works like oem .
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
MINI CooperMINI Cooper PrivacyMINI Cooper Terms of UseMINI Cooper Guidelines MINI Cooper Advertising The North American MINI Cooper Community
  MINI Cooper news, forums, FAQs, and reviews for enthusiasts and owners of the North American MINI Cooper
 Copyright © 2002-2008 North American Motoring. All Rights Reserved.     Powered by vBulletin and vBulletin Plugins by Drive Thru Online, Inc.
North American Motoring is an independently operated web site supporting MINI owners and enthusiastsworldwide. As such it has no official relationship with MINI USA, BMW AG, or BMW of North America.All original artwork and design is Copyright © 2002-2004 North American Motoring.
Admin Account Passwords
Search Engine Friendly URLs by vBSEO 3.5.2
