MINI Cooper MINI Cooper specs
MINI Cooper MINI Cooper Forums MINI Cooper Pictures
Mark Forums Read MINI Cooper radio MINI Cooper latest news
Go Back   North American Motoring > 2nd Generation MINIs > Modifications > Electrical
Sign in using an external account
Register Forgot Password?
Welcome to North American Motoring !
Welcome to North American Motoring,
» Latest Main Topics
Advertisement
Thread Tools Search this Thread
Old 09-27-2009, 07:44 AM
TRL TRL is offline
Gallery
Higher Amp Driving Lights on EOM Kit?
I understand the EOM Driving Lights have 55-watt bulbs. I suspect that is because it is the US limit for on-road Legal power.
Most of the after-market lights I am concidering are 100, or even 130-watt bulbs. I am leaning toward 100-watt KC's. While I would really like to use the OEM wiring kit (at $52 it doesn't seem outrageously priced) I naturally would like to avoid burning wires, relay and the car up.
I suspect the OEM wiring kit can actually handle more that the 55-watt bulbs as I doubt they have a different Euro kit for more powerfull lights. Anyone know? Does any one have there EOM wiring hooked up to anything more than 55-watts?
Old 09-27-2009, 07:52 AM
-=gRay rAvEn=-'s Avatar
-=gRay rAvEn=- -=gRay rAvEn=- is offline
Modder-ator
Gallery
Garage
The additional wattage will produce added heat inside the housing and sometimes subject the bulb to shorter than expected life span.
2003 R53 - DS - 135K + Miles
Parts of MINI NOT Modded ( A Shorter List ) Block/Head/HK Stereo.
Old 09-27-2009, 08:54 AM
TRL TRL is offline
Gallery
Should have mentioned, I am not going to put higher wattage bulbs in OEM lights. Will be using new lights designed for the heat, just want to use OEM wiring.
Old 09-28-2009, 01:58 PM
schatzy62's Avatar
schatzy62 schatzy62 is offline
Gallery
Garage
The OEM wiring kit is not made for that kind of wattage and would probably burn up as it is barely rated for what it is drive as factory standard.
I would recommend NOT using the OEM wiring kit.
08MCCS, HC/HC/Blk, 6 SPD, Premium, Sport, Cold Weather, Convenience, HiFi, HC L/C - Steering Wheel - Shift Knob-Boot, - E Brake Handle-Boot, English Oak - 17" Web Spoke (R98) Painted H/C, H/C Club Member #42.
Old 09-28-2009, 09:48 PM
tintman718 tintman718 is offline
Gallery
I'm not very familiar with driving lights, but why not drop in a 35W HID kit instead of using a 100W bulb?
Need maintenance or mods installed? Taillights tinted? I'm an ASE Master Tech.
tintman718@gmail.com
[Alta FMIC, Alta Hot & Cold Tubes, Ragazzon DP (heat-wrapped), BSH Boost Port, eBay Catch Can, Custom Air-Ride Suspension w/ Airlift Easystreet Management, Custom Stealth Hitch, Momo Shift Knob, LO-JAck, Viper Alarm]
Old 09-29-2009, 01:03 PM
celiborgy celiborgy is offline
Gallery
^^ I think that would make alot more sense instead of re-wiring the whole thing.
2007 R56m Pepper White: Alta ● Unichip ● Magnaflow Plasti-Dip ● Lamin-x
Old 02-21-2010, 08:41 AM
second to none second to none is offline
Gallery
Do the high wattage lights. Why not just tap an in-line fuse between your power source (factory lights) and your upgraded driving lights? Blow a fuse if anything. I have the alta light kit on my R53 tapped in the stock HID's, running 2 55W and 2 100W bulbs, no issues after 3 years and a few hundred hours on them
It should be okay
Old 02-24-2010, 09:24 AM
djam43's Avatar
djam43 djam43 is offline
Gallery
I agree with Schatzy about the OEM wireing and relay. It will NOT handle the extra amperage.
[Guinness--- Its A Mans Drink ]
Old 02-26-2010, 11:07 AM
Gallery
Quote:
Where do you drive with those lights? Do you live in the mountains?
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
MINI CooperMINI Cooper PrivacyMINI Cooper Terms of UseMINI Cooper Guidelines MINI Cooper Advertising The North American MINI Cooper Community
  MINI Cooper news, forums, FAQs, and reviews for enthusiasts and owners of the North American MINI Cooper
 Copyright © 2002-2008 North American Motoring. All Rights Reserved.     Powered by vBulletin and vBulletin Plugins by Drive Thru Online, Inc.
North American Motoring is an independently operated web site supporting MINI owners and enthusiastsworldwide. As such it has no official relationship with MINI USA, BMW AG, or BMW of North America.All original artwork and design is Copyright © 2002-2004 North American Motoring.
Admin Account Passwords
Search Engine Friendly URLs by vBSEO 3.5.2
