I have an extra switch in my MCS, which is obviously for some function I didn't get.
I was wondering If I could somehow wire my sport button (on) and DSG (off) to such a switch.
Example is:
push up; DSG off, Sport On
push down; DSG on, Sport Off
I saw the auto-on sport circuit, but I have to turn off DSG as well, any of those units handle both?
2009 R56 PW/PW "Jeremy"...6 Speed, Sport, Cold, Hi-Fi, Piano Black, Stubby Antenna, Alta Intake, Alta Hot Side Boost Tube, Functional hood Scoop, Alta Exhaust, Alta Rear Endlinks, Scangauge II, Cooper Side Scuttles, 22mm Alta Rear Sway Bar, KW Variant 1 Coilovers, CravenSpeed Adjustable Short Shifter, NM-Engineering Torque Arm Insert, S.P.E.C. Stage 2.5 Clutch and Pressure Plate.
Unfortunately these are single momentary switches so what you want is not possible with just a push button near the other two. The switch will just toggle between the tow states on or off.
If you want to drive in the same mode all the time what you can do is get two of the sport button modules from KP Technologies and that will remember the last settings and keep them that way.
08MCCS, HC/HC/Blk, 6 SPD, Premium, Sport, Cold Weather, Convenience, HiFi, HC L/C - Steering Wheel - Shift Knob-Boot, - E Brake Handle-Boot, English Oak - 17" Web Spoke (R98) Painted H/C, H/C Club Member #42.
