MINI Cooper MINI Cooper specs
MINI Cooper MINI Cooper Forums MINI Cooper Pictures
Mark Forums Read MINI Cooper radio MINI Cooper latest news
Go Back   North American Motoring > 2nd Generation MINIs > Modifications > Electrical
Sign in using an external account
Register Forgot Password?
Welcome to North American Motoring !
Welcome to North American Motoring,
» Latest Main Topics
Go to first new post Hot or Not (Fuses)
by oPossum
65 Replies, 17,518 Views
Go to first new post Problem coding FRM/FRM2
19 Replies, 598 Views
Go to first new post MINI's on TV!!!
134 Replies, 4,451 Views
Go to first new post Best FMIC
2 Replies, 77 Views
Advertisement
Thread Tools Search this Thread
Old 08-18-2009, 02:22 PM
sunman's Avatar
sunman sunman is offline
Gallery
Installed a Boost Guage Using Add a Circuit
Hello,
I've installed an Autometer Boost Gauge using a "add a circuit" by tapping fuse #42 (Cigar Lighter, Rear Charging Socket), but the light in the meter is constantly on. Which fuse number should I tap into so that the boost gauge light only comes on when the headlights are on??? Searching the forum, some suggest F30 or F33, which will use the smaller add a circuit kit, correct? Thanks.
30% Ceramic tint | Stratmosphere Turbo-back exhaust | H&R Springs | Team Dynamics Pro Race 1 - Matte Black w/Hankook Ventus V12 evo Tires 205/45/17 | DoS CAI | JCW Intake Tube | Autometer Boost Gauge | HKS SSQV BOV Kit | Helix IC (next mod) | Whalen Custom Knob | Cravenspeed Shift Well Cover | Aeroforce Interceptor Scan Gauge | FES Auto Sport
Old 08-18-2009, 02:48 PM
quikmni quikmni is offline
Gallery
From what I remember when installing my gauges, you need two power wires. One for all the time power, such as your fuse #42, to run the gauge and one for light power. I initially connected my light wire (I think to a red and white wire but there are two in the harness and only one of the two works correctly) to the instrument panel lights so that it would come on with the lights and be dimable (I might have just made up a word). However, I found out the gauge light would dim too low too quickly and was pretty much off at the level I liked the instruments (pretty low). I then connected the gauge light wire to the parking lights so the gauge light would come on with the lights but not be controlled by the dimmer. I had to use the Bentley manual elec diagram to determine the correct color wire and it took a lot of searching in the harness to find the correct wire. I connected to about six wrong wires before I found the correct wire. Sorry but I do not have the manual with me right now so I cannot tell you the color I ended up using.
2006 MCS JCW GP #1405: Adj Front Camber Plates, 19mm Rear Sway Bar, MM Front Lower Brace, Milltek Cat-Back, TCE 13" Front/11.75" Rear BBK, 15mm Spacers, Wheel Studs, JCM Modified Intake, MM Filter, Gauges
Old 08-18-2009, 02:56 PM
sunman's Avatar
Gallery
Thanks Quickmni ... I probably should clarify that I had some one install the meter for me, which is why I did not know there were two power lines ... If it's not too much trouble, I would be interested in knowing which color line you used in your set-up, so that I can try to do the same. Are the wires located in the steering column underneath the tach? Cheers.
Old 08-19-2009, 08:46 AM
schatzy62's Avatar
schatzy62 schatzy62 is offline
Gallery
Garage
Be aware that quikmini has a 2006 (gen1 car) and all the wiring is completely different for lighting and interior control.
08MCCS, HC/HC/Blk, 6 SPD, Premium, Sport, Cold Weather, Convenience, HiFi, HC L/C - Steering Wheel - Shift Knob-Boot, - E Brake Handle-Boot, English Oak - 17" Web Spoke (R98) Painted H/C, H/C Club Member #42.
Old 08-19-2009, 10:26 AM
Gallery
As schatzy62 points out, it might not be very useful for me to tell you specific wires that I used because they may not match your Gen2 wiring. You will need to verify wire colors using a wiring diagram such as one available in a Bentley manual.
I looked back at my notes so see what I wired to. For the ignition power (basci power for the gauge) I wired to the brake light switch power line. You can trace the wire up from the brake pedal. It was a purple (violet) wire with a black stripe and yellow bands (wire gauge was 0.75 mm2). I wired the ground to a bolt under the dash. For the light dimmer control, I wired to a gray/red stripe wire located in a harness under the dash on the left side of the drivers side (wire gauge was 0.35 mm2). There were two gray/red stripe wires that I found in the harness but only one worked correctly. I later removed the connection to the gray/red stripe wire because I did not want the dimmer controlled light. I then used front parking light wire (green and purple stripe) that is in the large harness that runs along the door sill and to the fuse panel at the drivers side foot well. It was a lot of trial and error to find the correct wire because there are so many wires in the harness.
Old 08-19-2009, 11:20 AM
sunman's Avatar
Gallery
Thanks Quickmni and Schatzy62 for your comments. Next purchase - Bentley Manual...
Old 08-21-2009, 05:30 AM
schatzy62's Avatar
Gallery
Garage
Quote:
Unfortunatley they do not make manuals for the Gen 2 cars yet. They are working on them but expect it to be at least another 9-12 months before production begins.
Old 08-24-2009, 07:07 PM
sunman's Avatar
Gallery
Old 10-14-2009, 11:29 PM
danielo danielo is offline
Gallery
Hi, is there any constant 12v power on the left side (inside) the vehicle?
http://i138.photobucket.com/albums/q273/jinkeong/danielo006.jpg
Old 10-15-2009, 09:54 AM
Gallery
I am not sure if the R56 is the same as the R53 but for my R53, I used the the brake light switch power line. You can trace the wire up from the brake pedal. For the R53 it was a purple (violet) wire with a black stripe and yellow bands (wire gauge was 0.75 mm2).
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
MINI CooperMINI Cooper PrivacyMINI Cooper Terms of UseMINI Cooper Guidelines MINI Cooper Advertising The North American MINI Cooper Community
  MINI Cooper news, forums, FAQs, and reviews for enthusiasts and owners of the North American MINI Cooper
 Copyright © 2002-2008 North American Motoring. All Rights Reserved.     Powered by vBulletin and vBulletin Plugins by Drive Thru Online, Inc.
North American Motoring is an independently operated web site supporting MINI owners and enthusiastsworldwide. As such it has no official relationship with MINI USA, BMW AG, or BMW of North America.All original artwork and design is Copyright © 2002-2004 North American Motoring.
Admin Account Passwords
Search Engine Friendly URLs by vBSEO 3.5.2
