MINI Cooper MINI Cooper specs
MINI Cooper MINI Cooper Forums MINI Cooper Pictures
Mark Forums Read MINI Cooper radio MINI Cooper latest news
Go Back   North American Motoring > 2nd Generation MINIs > Modifications > Electrical
Sign in using an external account
Register Forgot Password?
Welcome to North American Motoring !
Welcome to North American Motoring,
» Latest Main Topics
Go to first new post Show us your mods!
by ADAM244
19 Replies, 1,174 Views
Advertisement
Thread Tools Search this Thread
Old 04-27-2009, 08:58 AM
hardingsan's Avatar
hardingsan hardingsan is offline
Gallery
Tapping the sport button?
hey all,
i've recently gotten a shifter with a light up shift pattern on the knob. (sounds cheesy, but it'll look good, i promise). anyways the led's match the buttons pretty well and i'd like it hook it up so the display only lights up when i have running or headlights on. i've noticed that the sport and DSC buttons light up when the running/headlights and was wondering if it were possible to tap into those to supply power to the shifter. i looked under the shifter boot and noticed far to many wires for me to start splicing. anyone know what wires i should be looking for to accomplish my goal?
thanks!
Old 04-28-2009, 07:45 AM
schatzy62's Avatar
schatzy62 schatzy62 is offline
Gallery
Garage
Check out the Fuse block and find one that only has power when the lights are on. Use that one to tap from.
08MCCS, HC/HC/Blk, 6 SPD, Premium, Sport, Cold Weather, Convenience, HiFi, HC L/C - Steering Wheel - Shift Knob-Boot, - E Brake Handle-Boot, English Oak - 17" Web Spoke (R98) Painted H/C, H/C Club Member #42.
Old 04-28-2009, 08:19 AM
hardingsan's Avatar
Gallery
schatzy, thanks for getting back to me. a few more questions, if you don't mind.
is the fuse block different from the fuses in the footwell/under the hood? can i unhook the harness to those buttons and check amperage on those pins?
also, once i find the wire i want, do i have to disconnect the battery? i know for the bigger jobs it's a good idea to have that unhooked, but i wasn't sure since i was going to tap into a wire that shouldn't even be on all the time. i've heard stories / rumors that disconnecting batteries on newer cars is like wiping the memory.
Old 04-28-2009, 08:36 AM
uggbird uggbird is offline
Gallery
go to Alta's website and pull up the install PDF for boost gauge install
it shows which wire to tap for dashlights. If memory serves me it is a
gray wire with a red stripe.
RR Catless Exhaust, DOS Intake, Alta Bov, M7 Stainless Grilles, Auto Meter Gauges, Craven Speed Pods
Old 04-28-2009, 09:08 AM
hardingsan's Avatar
Gallery
thanks for the help. it looks like grey with red stripe will get the shifter to light up only when other lighting is on.
now if someone can confirm that to disconnect the battery will not be the end of the world i should be able to get this done after work...
Old 04-28-2009, 10:32 AM
schatzy62's Avatar
Gallery
Garage
For safety sake it would be best to disconnect the battery, But for what you are doing it should not be required.
Old 04-29-2009, 07:05 AM
hardingsan's Avatar
Gallery
and the results are in! truths:
  • red/gray wire is the illumination to the sport and DCS buttons.
  • brown is ground for the same buttons -you don't need to disconnect the battery
  • disconnecting the battery resets the time, alarm, and trip functions (trip odometer, average mpg, average speed)
  • this would have been a much easier task if i could have unplugged the wiring harness or taken the ebrake handle off.
Old 04-29-2009, 12:49 PM
torobud torobud is offline
Gallery
OK - I will admit it... it is cheesy but it is COOL...
'10 MCSC IY - Cold, H/K, Blue/USB and the top goes DOWN!!
'07 MCS - GONE
Old 04-29-2009, 02:03 PM
hardingsan's Avatar
Gallery
might be slightly cheesy; and i'm sure it cost a little more than a non-performance part should, but i wanted a more unique knob and the install is really stealth. i think since the LED matches the factory it doesn't scream AFTERMARKET to me. i like it, and it was fun to tear apart my car a little bit...
Old 04-29-2009, 03:37 PM
MrPinkFloyd MrPinkFloyd is offline
Gallery
it looks pretty cool to me. i like the way it matches the rest of the dash lights.
Old 04-30-2009, 05:57 AM
schatzy62's Avatar
Gallery
Garage
Okay, I like it enough to ask the question. Where did you get it?
Old 04-30-2009, 06:35 AM
hardingsan's Avatar
Gallery
Quote:
hahaha, www.bimmian.com.
they have great shipping and customer service by the way. quick delivery and answered all my questions within an hour or so of me sending them emails.
Old 04-30-2009, 06:37 AM
hardingsan's Avatar
Gallery
btw - don't worry, the white plug in the cigarette lighter is for my ipod, not the shifter...
Old 04-30-2009, 07:53 AM
dtsoccer6's Avatar
dtsoccer6 dtsoccer6 is offline
Send a message via AIM to dtsoccer6
Gallery
Dude, very cool!
Hey remember when people were mad because the JCW MINI had red writing on the knob, but it didn't light up? Here you go, solved that problem...I would think this is uber cheesy, however, you matched the stock setup and that looks totally OEM, even better than the JCW Red would of been...
Well done!
07 Astro Black/Black MCS 208whp/248wtq
Mods::Joey Mod::AGS-R::m7 Vortex::Alta Turbo Inlet, TurboBack, FMIC, Endlinks, 22mm Sway, + 4 Control Arms::17"OZ Alleggerita HLT::m7 Strut Bar::2 Whalens::Body Colored Everything::Gloss Black Painted Beltline::Cravenspeed SSK+Shift Well::Detroit Tuned BBK::DBA Rear Rotors::NM Eng Springs::NM Eng Torque Arm::Hawk HPS/DTC Pads::NM Eng IC Pipe::EDepot Throttle Body Pipe::RMW TUNE 1.5::
Old 04-30-2009, 08:03 AM
hardingsan's Avatar
Gallery
Quote:
Originally Posted by dtsoccer6 View Post
Dude, very cool! I would think this is uber cheesy, however, you matched the stock setup and that looks totally OEM...
Well done!
thanks! that's exactly what i was going for. i'm glad i pleased the masses in the process...
Old 05-28-2009, 09:57 PM
simpsonsofadown simpsonsofadown is offline
Gallery
Thats really pretty cool looking im not gonna lie. good job
Old 05-29-2009, 06:02 AM
hardingsan's Avatar
Gallery
thanks!
Old 05-29-2009, 08:17 AM
Jeremy1026's Avatar
Jeremy1026 Jeremy1026 is offline
Moderator
Send a message via AIM to Jeremy1026 Send a message via Yahoo to Jeremy1026
Gallery
Quote:
+1
Past - 2003 BRG/W MCa. Custom Bonnet Stripes/Roof Numbers, K&N Typhoon Intake, Aux Input, Clear 3rd Brake Light, Clear Tail Lights
Present - 2009 Interchange Yellow/B MCSC. JCW Tuning Kit, Factory Aero Kit, Sport Package, Cold Weather Package, Sport Suspension, Rear Fog Lamps, Interchange Yellow Interior Surface, Leather Wrapped MFSW, 10 Speaker Hi-Fi Sound System, Driving Lights (Hella 500)
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
MINI CooperMINI Cooper PrivacyMINI Cooper Terms of UseMINI Cooper Guidelines MINI Cooper Advertising The North American MINI Cooper Community
  MINI Cooper news, forums, FAQs, and reviews for enthusiasts and owners of the North American MINI Cooper
 Copyright © 2002-2008 North American Motoring. All Rights Reserved.     Powered by vBulletin and vBulletin Plugins by Drive Thru Online, Inc.
North American Motoring is an independently operated web site supporting MINI owners and enthusiastsworldwide. As such it has no official relationship with MINI USA, BMW AG, or BMW of North America.All original artwork and design is Copyright © 2002-2004 North American Motoring.
Admin Account Passwords
Search Engine Friendly URLs by vBSEO 3.5.2
