Electrical Retrofitting the factory self dimming rearview mirror + Homelink
#101
Think its the inner section, where the pin goes , the head size looks the same on most and the insert pin is a different size. Measure both if you have them. Then I can figure it out.
its like 0.2mm to 0.5mm squared and then 0.75mm squared, and 1mm squared sizes. Some pins are even bigger then that. I guess measure the male pin also width.
#103
We were waiting for someone who bought that wire kit so I can source the parts through the BMW / MINI hardware section and make a kit so people can continue to do this mod.
#104
Thanks again.
#105
Hopefully one of the people who bought the cable will chime in with the specs.
#106
so...
undid my factory manual dim rear view mirror, which had the plug, and plugged in the autodimming and tested it with a flashlight lol, didn't autodim. was hoping it'd be that simple.
what do i need to use the wires and and all that stuff for...?
#107
I have attached a scan of the autodim mirror retrofit instructions from MINI. It has a few part numbers here and there, not sure if it's enough for @ECSTuning to identify the needed parts.
autodim mirror retrofit instructions (306kb PDF)
Quarky42 (05-30-2023)
#108
That helps bratling , i needed the plug end size and the range for the box end with the length of the wire , I found this which covers female box end ply with clip that takes a range from 0.2-0.5mm2 pin. The range from the diagram looks like 0.35mm2 to 0.50mm2 , so the box head is within range.
The wires already have the box end plug clipped on. So 4 of these wires ( 61130005197 ), 2 of each wire doubling the length when connected end to end.
https://www.ecstuning.com/Search/SiteSearch/61130005197/ES2674650/ x 4
Then to wrap the wires.
Here is the cloth webbed tape in 7.5meters , plenty to do it and tape up other harnesses.
https://www.ecstuning.com/Search/Sit.../cloth_webbed/
Thanks and worth a shot.
#109
The wires already have the box end plug clipped on. So 4 of the these wires , 2 of each wire doubling the length when connected end to end.
Just took delivery of a '12 S w/o autodimming or homelink, first DIY mod to break her in
#111
Pretty long, about 2 foot , but I don't have the length of the originals. With some simple gauge wire form a electronic store you could connect the ends , then measure and cut a piece to splice in the middle , guessing about 4 foot total from end to end but I would get more just to be sure.
#112
Side note: how can you tell which mirror is right for your key fob frequency???
#113
Update: I have successfully completed this retrofit!
Notes:
- I bought a used homelink autodimming mirror off ebay, great condition.
- My key fobs worked afterwards when testing
- I bought the wire leads ECS recommended (you need four total). I had to solder wire extensions in between to get the proper length. I also used the OEM cloth tape to create a harness and colored electrical tape to identify wires.
- Running the wire down there is tedious but I have done it many times for hardwiring radar detectors. Trim tool is helpful.
- Removing and reinstalling the mirror takes some muscle, that sucker is on there!
- I followed the OEM retrofit PDF for the pin outs. The mirror connection wasn't bad. The fuse block is a huge PITA. You have to remove most of the lower door well plastic molding to access the lower connector.
- All pin outs require you to pop up flaps or remove the connector from it's socket so to be speak to insert the pins. A jeweler's screwdriver set is very handy.
I tested by first making sure the fobs worked before I put all panels back on etc. I then waiting until the evening, and pulled our Acadia behind the car with the high beams on. The photocell sensor faces reward, if you hold your finger over it, you can see it "un-dim" and then expose it to the headlights, it dims itself.
Overall, I'm very pleased and so is my wife who drives the car. She goes into work early and the headlights in her eyes on her 30 minute commute were obnoxious. She didn't care about the homelink but I wanted it to get back the spare garage door opener.
Notes:
#114
Thanks for the update , glad the parts I mentioned above worked.
#115
Notes:
Notes:
#116
Sounds like there was plenty of wire in the part.
#117
#118
#119
You are welcome
#120
This is great! I'm hoping to get mine done soon as well. I have a mirror that will hopefully work and was just waiting on the wiring. In fact, I just got 4 sets of wires (that ECSTuning linked above) in the mail today but looking at them, they will definitely need the extension in the middle as you added. The wires out of the package are about 20 inches long each. What kind of wire did you splice in?
#121
Thanks for the order. I would use the same gauges wire if your splice to add line. Measure it with a wire gauge. Then you can get additional wire at any electrical store.
#122
#123
Great, there we go.
#125
Welcome.
