Electrical Retrofitting the factory self dimming rearview mirror + Homelink
Old 03-23-2015, 06:01 AM
ECSTuning is online now
Received 1,966 Likes on 1,766 Posts
Welcome.
Glad it worked for you and on the newer Countryman.
Originally Posted by fishbulb
Just completed the factory retrofit on our late 2013 MCS Hardtop. Here are a few thoughts.
Purchased the following from ECS Tuning. They were great to work with, sales rep and techs were very helpful.
Rearview Mirror - 315MHZ Fequency - Autodim & Homelink & Compass
51169302886
Retrofit Wire - Int Mirrror EC And GTO
61120416436
General
- The MINI connectors are numbered on the face to show you what pin number you are dealing with. They are tiny, make sure you have plenty of light!
- Use a small, thin awl to carefully seat the pins into the connectors.
Mirror
- The mirror comes off by turning it 90° in either direction. It feels like you might break something the first time you do it, but then you see how it attaches and its no big deal.
Wiring Harness
- Run the wire along the front side of the A-Pillar. There is enough wire to go this way, and it looks like it should not interfere with the A-pillar airbag.
- Do not leave much slack, you will need everything to go from the mirror to the fuse block.
- Pop the side cover of the passengers side vent to run the wires down to the box. Open the door to access.
- Pull back the plastic surround around the fuse panel, you will need to install one of the wires into a connector that is located at the very bottom of the box.
- The connectors at the fuse box are two piece - the part holding the pins slides out of the main part. Carefully pry the release tab and the center block with the pins slides out. It is MUCH easier to insert the pins this way.
Wrapping it up
- My mirror had a 'C' in the compass area which means the mirror needs to be calibrated. The procedure is in your owners manual. Short story: Press the button on the back of the mirror (the hole closest to the top of the mirror) has to be depresses with a thin tool (use your awl from before). Based on the manual, you first select your map zone. Then slowly drive the car in a circle until it picks up the directions. Took my car less than half a circle to pick it up.
  #77
Old 03-24-2015, 10:33 AM
komet155's Avatar
komet155
komet155 is offline
Does anyone have a current link to the instructions pdf file? It doesnt seem to be working.
  #78
Old 03-24-2015, 10:53 AM
Fixed the install PDF link on post #57
https://www.northamericanmotoring.co...omelink-3.html
  #79
Old 03-24-2015, 12:22 PM
komet155's Avatar
komet155
komet155 is offline
^ Thanks!
Does anyone know if there's any coding needed after such an install on late model (2013) R56?
  #80
Old 03-25-2015, 04:24 PM
bmrguy03's Avatar
bmrguy03
bmrguy03 is offline
Originally Posted by komet155
^ Thanks!
Yes and no. There is coding available but it's not really necessary. It's something that can be added through NCSEXPERT. I say it's not too important because the computer will tell the mirror not to dim when in reverse.
  #81
Old 03-25-2015, 04:54 PM
komet155's Avatar
komet155
komet155 is offline
Thanks. Just out of curiosity, what functionality would I be missing by not having the coding added?
  #82
Old 03-26-2015, 02:00 PM
bmrguy03's Avatar
bmrguy03
bmrguy03 is offline
From my understanding, the auto dim feature will not turn off when going in reverse.
  #83
Old 03-26-2015, 03:35 PM
komet155's Avatar
komet155
komet155 is offline
^ I can live with that. I had retrofitted an Audi Allroad autodimming mirror w/ compass into my mkIV GTi over 10 years ago and never bothered to tap into the reverse light circuit to enable that feature either. It was never a problem.
  #84
Old 03-30-2015, 07:15 AM
^ Thanks!
You are welcome, that's all the info I could dig up.
  #85
Old 03-30-2015, 12:29 PM
komet155's Avatar
komet155
komet155 is offline
Does anyone know if this connector needs to be opened up or otherwise "unblocked" before sliding in the additional terminal pins?
Originally Posted by SVDave
  • The 10-pin wiring harness plug has all 5 pins filled on one side, and three filled in on the other. I'd assume one could quickly confirm a car was pre-wired for this mirror by popping off the existing mirror and looking at the pins in the connector.
  #86
Old 03-30-2015, 07:11 PM
bmrguy03's Avatar
bmrguy03
bmrguy03 is offline
I can't quite remember but if you don't see something easy to pop up then I wouldn't worry about it.
  #87
Old 03-31-2015, 03:18 PM
komet155's Avatar
komet155
komet155 is offline
I can't quite seem to get the tip of my jeweler's screwdriver under the tab to pop it out.
  #88
Old 04-01-2015, 03:42 AM
bmrguy03's Avatar
bmrguy03
bmrguy03 is offline
Hmmm...ok. Let me take a look and I will get back to you.
  #89
Old 05-04-2015, 04:11 AM
bmrguy03's Avatar
bmrguy03
bmrguy03 is offline
I'm sorry I completely forgot about this post. Did you get everything situated?
  #90
Old 05-04-2015, 04:23 AM
komet155's Avatar
komet155
komet155 is offline
Yes, it's installed and everything works fine. Didn't even need to go through the calibration procedure, it was working fine within an hour of driving around.
  #91
Old 05-04-2015, 06:47 AM
Just wanted to let you know the wires set on the first page is now NLA, Its two wires and some pin ends which could be made with OEM parts , anyone have a close up of those pin ends so I can link the repair wires for people to make there own harness in the future.
  #92
Old 05-04-2015, 08:47 AM
komet155's Avatar
komet155
komet155 is offline
I picked mine up almost a year ago....I wonder if I got one of the last ones out there?
  #93
Old 05-04-2015, 08:51 AM
They just went NLA, think someone just bought the last couple left.
  #94
Old 05-07-2015, 12:06 PM
cvittas's Avatar
cvittas
cvittas is offline
Are the pins available from BMW?
  #95
Old 05-07-2015, 12:32 PM
I just need to know someone who bought this and installed the size of the female box end pins then I can find the size from MINI , they sell the pin end and wires. Make a kit and people can still get it.
  #96
Old 05-07-2015, 04:50 PM
bmrguy03's Avatar
bmrguy03
bmrguy03 is offline
I will see if I can get some part numbers for you.
  #97
Old 05-08-2015, 05:39 AM
Yea, just need the size of the box end pin , then i can look up and find the parts.
  #98
Old 05-09-2015, 10:49 AM
cvittas's Avatar
cvittas
cvittas is offline
When the mirror is installed, need to coding ? I mean only for the self dimming feature..
  #99
Old 05-09-2015, 02:03 PM
bmrguy03's Avatar
bmrguy03
bmrguy03 is offline
Nope
  #100
Old 05-10-2015, 07:00 AM
bratling's Avatar
bratling
bratling is offline
Super Moderator
How are they sized/measured? Cross section thickness?
Quick Reply: Electrical Retrofitting the factory self dimming rearview mirror + Homelink
