I will have 'Money-Penny' inside a building for a car show this weekend...
I have to have the ignition circuit powered to have the amplifier on during the show. The show requires, however, that I disable the starter. Is there a relay or fuse I can pull to keep it from cranking?
2007 MCS with all four packages, including Comfort Access keyless go system.
Battery will be disconnected, but an external power supply will be connected to the car battery cables to power it during the show.
You could also try looking around the clutch pedal pivot to find the "clutch-in" microswitch. If you disconnect the harness from that switch, the starter won't turn over.
