MINI Cooper MINI Cooper specs
MINI Cooper MINI Cooper Forums MINI Cooper Pictures
Mark Forums Read MINI Cooper radio MINI Cooper latest news
Go Back   North American Motoring > 2nd Generation MINIs > Modifications > Electrical
Sign in using an external account
Register Forgot Password?
Welcome to North American Motoring !
Welcome to North American Motoring,
» Latest Main Topics
Go to first new post R53 issues
11 Replies, 472 Views
Go to first new post SHOW us your MINI stripes
586 Replies, 114,802 Views
Advertisement
Thread Tools Search this Thread
  #51
Old 11-01-2009, 01:08 AM
pilotart's Avatar
pilotart pilotart is offline
Gallery
From Google (Knows All )
Reads good.
http://www.northamericanmotoring.com/gallery/data/500/Rt-Rear_Thumbnail_Web_view1.jpg28April2008, 'Trixy' Cooper Automatic+Sunroof+AutoAir+HiFi+CruiseControl+15" Rotator Six Spoke
Mods: European Center Armrest+Wet Okole w/Lumbars over 4" Memory Foam(see Gallery)+XM-Radio+ScanGauge II
  #52
Old 11-01-2009, 01:27 AM
Robin Casady's Avatar
Robin Casady Robin Casady is offline
Gallery
Sounds like the relay latches so it doesn't require power to stay on.
"Under normal conditions, the relay is always switched on."
I don't know how that relates to this:
"Cutout conditions:
* Reception of the message ”Signal off”.
After 5 minutes, relay terminal 30g-f is switched off.
* The battery status is continuously read out and evaluated in the engine control module. If the starting capability of the vehicle battery is insufficient, the relay is also switched off.
* Data interchange on the buses for 10 minutes after deactivation of terminal 30g without a switch-on condition.
* Vehicle is 'wakened' 20 times after deactivation of terminal 30g without a switch-on condition.
Switch-on conditions:
When the relay terminal 30g-f is switched off, it can only by switched on again with defined conditions required for switch-on.
Conditions required for switch-on for relay terminal 30g-f:
* Unlock vehicle
* Opening the luggage compartment lid / bonnet or door
* Switching on terminal R
The junction box electronics (JBE) monitor the closed-circuit current when the vehicle is at a standstill. The following faults can be detected:
* Unauthorized waking operations on the bus systems
* Control modules that keep the bus systems continuously active (inhibit ”sleep”)"
When is this getting power, and when is it off?
Robin Casady
Bombadil: 2007 MINI Cooper S, R56, Pure Silver, LSD, Wood Shift Knob, Rota Slipstream 16x7, NAV, HIFI...
  #53
Old 11-01-2009, 06:07 AM
pilotart's Avatar
Gallery
I would just set up a temporary 'test' light to see what happens.
Fuse F20 is a mini ATM 30G_F Circuit, so you could use the small Add-A-Circuit that you have already.
Just connect a 12V bulb in a location that you can see (not touching anything to burn or melt) and then watch the bulb to see when it turns off.
It should turn on with unlock (or door/boot open) and then (with no activity from lock/door) turn itself off,
the hope would be to see it turn off in 5 minutes instead of the 30 ? minutes of Fuse 11's 30G Circuit.
I like the idea of its battery condition protection, I have had to jump mine twice, first time in first week and one more time, over a year later. I think it may have been PL left on, but don't know.
For many months before the second incident, I had noticed morning ScanGauge voltage reading 11.7> 11.6V.
The battery was never totally dead, but wouldnt start and I charged it 24 hours with a 2amp trickle charger (sealed battery can be damaged by a high rate, unless using a special "13.8V" controled charger).
I do too many short (as mentioned in OM) trips and have watched my morning voltage decrease from 12.5V down to 12.2V in past four months,
if it gets below 12, I will trickel charge again.
  #54
Old 11-01-2009, 07:02 AM
Gallery
Sounds like a good idea. Thanks.
Robin Casady
  #55
Old 04-01-2010, 06:27 PM
Xeraux Xeraux is offline
Villian
Gallery
Just a heads up...
It looks like on my 2010 Clubman S that if you don't have an option, that circuit isn't powered.
For instance, the I don't have the Park Distance Control (F30 in this thread, F32 on my Clubman) nor the CD changer (F12 in this thread, F14 on my Clubman) and neither of those circuits are powered regardless of the state of the car.
  #56
Old 05-10-2010, 10:27 AM
jtpryan jtpryan is offline
Gallery
So, if I want to set up my Sat radio to stay on for awhile (like the on board radio) after turning the car on I want to tap into F11? Would that be correct?
-jtpr
'02 S with 202k just traded in for 2010 S, Premium, Cold Weather Chili/Black.
  #57
Old 05-11-2010, 03:44 AM
swooshmac's Avatar
swooshmac swooshmac is offline
Gallery
thanks for showing me this thread- Robin.
anyone know where the fuse is for the interior lights? trying to hook up some LEDs under the car to come on when i unlock the car and when i start the car they can fade out like the interior lights do.
i have read this thread and is it Fuse F20 that might work? or F2 or F10?
thanks for the help.
  #58
Old 07-27-2010, 03:46 AM
burgerdog burgerdog is offline
Gallery
Can I just pull the fuse (F26) for the alarm siren/ tilt sensor to silence the alarm without affecting anything else ?
  #59
Old 08-02-2010, 11:04 AM
OldTimer OldTimer is offline
Gallery
I posted this elsewhere, probably the wrong place so I'll ask it here since this seems to be the "Fuse Thread" LOL.
Where is the fuse that controls the Cruise Control, and secondarily... where is the cruise control module itself? I have the MFSW, heated seats, stereo controls, no bluetooth (arghhh!), and nothing happens when I try the CC buttons. I assume a light would pop on in the dash modules. And I've tried it in various gears (3rd/4th/5th/6th) with no response. Would the position of the sport suspension button have any effect? Now, I bought my car used and never checked the MFSW, so is there a chance that I _don't_ have CC?
And boy... I have never see so many fuses in one car.
Daily Driver: 2008 MCS in Sparkling Silver with White Roof/Mirrors/Stripes - Fun to Drive.
The RIDE: 2001 Ford SVT Lightning F150 Supercharged Black - Fast, Noisy & Very Modded.
  #60
Old 08-02-2010, 12:55 PM
schatzy62's Avatar
schatzy62 schatzy62 is offline
Gallery
Garage
The Multi Function Steering Wheel (MFSW) has all the controls whether they are used or not.
In other words if the car was ordered with cruse but bot bluetooth the bluetooth controls would still be there
or
if the car woas ordered with bluetooth control and not with CC then the CC controls would still be there but the actual module that controls the CC would not.
So what you need to do is find out if the car is equiped with CC. You can call you dealer or MINI USA with the VIN and they can tell you if it is installed or not. If it is not then the controls will not work.
08MCCS, HC/HC/Blk, 6 SPD, Premium, Sport, Cold Weather, Convenience, HiFi, HC L/C - Steering Wheel - Shift Knob-Boot, - E Brake Handle-Boot, English Oak - 17" Web Spoke (R98) Painted H/C, H/C Club Member #42.
  #61
Old 08-02-2010, 01:26 PM
schatzy62's Avatar
Gallery
Garage
For got to answer yoru actual question.
It is F15 in the footwell.
F15 is power for the Steerign Column Switch Cluster (SZL Module).
If this Fuse is bad then many ohter items would not work as well such as
1. head lights
2. signal lights
3. high beam control
4. windshild washers
Just aboaut anything that has a switch function on the steering column.
So if all of that is working then most likely the car does not have CC installed.
  #62
Old 09-03-2011, 12:52 PM
Gil-galad's Avatar
Gil-galad Gil-galad is offline
Gallery
Garage
I can't seem to find a single fuse to tap into at the passenger side foot fuse panel of my '11 R56 that has 12v switched power associated with inserting/removing the key fob (i.e., a true ACC circuit).
I was getting frustrated testing circuits at the fuse panel with the multimeter, as it seemed like fuse after fuse was hot even with no key fob inserted. Then I studied Posts #1 and #2 in this thread and, if I'm interpreting them correctly, all of the switched circuits are activated by the Car Access System (CAS) and not the key fob! This won't work for me -- I don't want my aftermarket gauges to power up when I unlock the doors and stay on for 30 minutes after I lock.
And another thing: if the sunroof and seat heater fuses are activated by the CAS (and my multimeter agrees that they're hot without the fob inserted), why don't the sunroof and seat heater switches operate their respective functions unless the key fob is inserted?
I'm no EE, so any guidance/education appreciated.
ROHERYN -- 2011 MCS SO/W -- Garage
"...indeed the love that the horses of the Rangers bore for their riders was so great that they were willing to face even the terror of the Door, if their masters' hearts were steady..." --- J.R.R. Tolkien
  #63
Old 09-03-2011, 02:23 PM
fishbert fishbert is offline
Gallery
Probably because they don't want the high current draw to drain the battery.
  #64
Old 11-10-2011, 09:16 PM
9erminiturbo's Avatar
9erminiturbo 9erminiturbo is offline
Send a message via Skype™ to 9erminiturbo
Gallery
I have installed an aftermarket radio and spliced to center cigar lighter (terminal 15). Obviously this is not a good power source because all the presets on the new radio RESET themselves like installing for the first time everytime I start the car after 30 minutes.
My question is, should I choose a switched continuous + line or a continuous line for power?
2009 Mini Cooper S Hatch Laser Blue; Carbon Fiber Interior and Fenders; Kyowa Racing Rims with 215/45/17; Custom PIAA Yellow Rally Lights & Yellow PIAA Fogs. Forge Blowoff Valve & Aftermarket HID's. Metra Double Din Install with touchscreen Navigation. Retrofittted Rear fogs and integrated to brake light.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
MINI CooperMINI Cooper PrivacyMINI Cooper Terms of UseMINI Cooper Guidelines MINI Cooper Advertising The North American MINI Cooper Community
  MINI Cooper news, forums, FAQs, and reviews for enthusiasts and owners of the North American MINI Cooper
 Copyright © 2002-2008 North American Motoring. All Rights Reserved.     Powered by vBulletin and vBulletin Plugins by Drive Thru Online, Inc.
North American Motoring is an independently operated web site supporting MINI owners and enthusiastsworldwide. As such it has no official relationship with MINI USA, BMW AG, or BMW of North America.All original artwork and design is Copyright © 2002-2004 North American Motoring.
Admin Account Passwords
Search Engine Friendly URLs by vBSEO 3.5.2
