ATI Super Damper for R53
#51
Since we're back on this subject...
What are the pros/cons with these 3 choices vs the ATI ???
I'm married with 2 teenage boys and don't have funds to feed them and buy race quality components.
She's my daily driver and I do plan on doing an occasional track day or autocross event.
116k on the odometer so I'm pretty sure I have a ticking time bomb !?
http://www.waymotorworks.com/fluid-c...ulley-r53.html
http://www.waymotorworks.com/cravens...nk-pulley.html
http://store.speedmaster79.com/p-393...FQcOaQodG9QPPw
#52
#53
#54
Just got my car back. Installed the 15%sc and 2%ati and I love this combo. This is how my mini should have come from the factory, smooth power through the whole rpm range. Car is noticeably louder as well combined with JCW air intake. If you have a 15% definitely go with the 2% ati...if you have a 17% then go with the 0%.
#55
Ati +2%
I have an 06 R53 with Airtec Intercooler, 15% pulley, cold air intake, PTO gear delete and electric water pump and I've just fitted the ATI +2% damper in the last hour.
My R53 had a ticking sound from the front of the engine from about 3500rpm and I'd heard of other people with a similar noise that they'd tied down to the damper. I'd also heard of a lot of cases of dampers self destructing so thought it might be a good idea to replace the OEM damper before it blew up.
Straight up, the ATI does feel a bit smoother when cruising and it feels a bit snappier from 3000 with the +2%. There is no more ticking noise above 3500rpm either.
I'd recommend replacing your EOM with one!
#56
I put an ATI Super damper on my 04 Cooper S (255000 miles) to replace the second failed stock damper a month or two ago, and now I have to pull it back off to get into the timing chain cover. Anyone have to pull one of these ATI super dampers? I need to know which of the bolts to remove to use to attach the puller to, and what size threads are they. My inclination is to remove the three 12 point head bolts...
#57
It's been an issue with all R52 or R53 Cooper S Crank pulleys.
I've taken apart engines that had lightweight crank pulleys and found the bearing to look like they had 500k on them. So I don't use or recommend them.
Many times they just fail without warning. Sometimes you can get belt noise from them before they fail.
#58
im in the process of buying an 06 mini S with 111k on it and the owner has only had the car for 5k but installed an alta lightweight crank pulley at some point says its 0% id like to replace it with this ATI instead of an oem. but are the bearings already ruined??? please help i need this car to be reliable
ebowling
90
08-04-2019 09:15 AM
