MINI Cooper MINI Cooper specs
MINI Cooper MINI Cooper Forums MINI Cooper Pictures
Mark Forums Read MINI Cooper radio MINI Cooper latest news
Go Back   North American Motoring > Vendor Talk > Drivetrain Products
Sign in using an external account
Register Forgot Password?
Welcome to North American Motoring !
Welcome to North American Motoring,
» Latest Main Topics
Go to first new post Best FMIC
2 Replies, 77 Views
Go to first new post "Those Waiting for a 2012"...
by Vapok
1,980 Replies, 54,238 Views
Go to first new post Hot or Not (Fuses)
by oPossum
64 Replies, 17,518 Views
Advertisement
Thread Tools Search this Thread
Old 03-10-2008, 05:29 PM
MotoringSpeed_gnat's Avatar
MotoringSpeed_gnat MotoringSpeed_gnat is offline
Gallery
MotoringSpeed and RMW Create 230 HP MINI
Stage 1 of MotoringSpeeds 1st Project Car has been successfully completed. With only 3 hours of tuning on AutoScope's DynaPack dyno Jan of Revolution MINI Works found quite a bit of power. The MINI, a bone stock 04 example with ~ 24K miles on the clock was transformed into a tire smoking Chesire Cat sized grin producer. Three weeks from concept to reality with Will of Bob's Tire and Auto in Lewisville, TX deftly handling the mechanical end in a scant 6 days.
A baseline dyno at the beginning of the project in cooler weather netted 147.7WHP at 6307RPM with 148.5Ft/lb at 4051. A quick base flash was installed to scale the 440cc injecters to prevent fouling of sensors during the trip to the dyno. The first pull returned 207WHP and 162Ft/lb. Capable tuning yeilded a final result of 230.5WHP at 7414RPM and 184.1Ft/lb at 4872RPM. What the numbers, as impressive as they are, do not show is the 170+ft/lb available form 3200-7100RPM. See the scan below.
Mods:
RMW Head
RMW Cam
RMW Adjustable Cam Gear
RMW Header
RMW Exhaust
ARP Head Studs
440 Injectors
CravenSpeed CAI
CravenSpeed 15% Pulley
Quaife
ClutchMasters Stage 3 Clutch
Old 03-10-2008, 05:50 PM
PGT's Avatar
PGT PGT is offline
Gallery
nice numbers. what's the benefit of the cam gear? that's teh one thing we didn't do on my (besides the clutch).
Old 03-10-2008, 05:55 PM
Forcefeed Forcefeed is offline
Gallery
Can all this be done to a MCSA. Has it been done? Minus the Quaife &
Old 03-10-2008, 06:26 PM
gnatster gnatster is offline
Gallery
Quote:
Retarding the camshaft timing will generally shift the powerband upward, increasing top-end power. Conversely advancing the camshaft timing will shift the powerband downward, allowing for increased torque at lower RPMs. However since we are supercharger speed dependent and the S/C does not really come into play until around 3K RPM advancing the camshaft is somewhat useless on an MCS.
Old 03-10-2008, 06:37 PM
jhiggs26 jhiggs26 is offline
Send a message via MSN to jhiggs26
Gallery
Benefit=precise custom cam timing and ability to alter cam timing(advanced or retard) fairly quickly. With no adjustable cam gear we are limited to rotating cam/timing chain from sprocket to sprocket right? The adjustable cam gear will allow infinite adjustments between sprockets.
Jeremy
2004 Liquid Yellow MCS Sport/Chrome Pkg, 17% Alta SC Pulley, Alta Intake, Alta IC Diverter, Ultrik Cam, CM Flywheel/FX200, OBX ATB Diff, JCW Fuel Injectors and Software, Edge Racing Sport Header with Magnaflow Cat, 1 Ball Exhaust, JCW Plugs, Powerflex Front Subframe Bushings, Powerflex Motor Mount Inserts, Alta Springs, Alta Lower Control Arms, Alta 19mm Rear Sway Bar, Rear Seat Deleted, 17 by 7 O.Z. Ultraleggeras, Auto Meter Boost/Vacuum And Oil Pressure Gauges.
Old 03-10-2008, 06:57 PM
Chappy Chappy is offline
Gallery
Nice, very nice.
Hey, I live in Texas... can I get one of these???
CROC #158 / MMC #471
"If you're not living on the edge, you're taking up space!"
Nitrominis's Avatar
Nitrominis Nitrominis is offline
Gallery
Nice thoughts about cams jhiggs I have read a couple of your comments around...you have a MINI now not a Detriot Hot Rod !
I may be wrong but having an adjustable cam gear is great if Jan is going to be around to re tune after making any cam timing adjustments. I would think the purpose on the MINI engine is during Dyno/Tunes to play around with adjustments to find the optimum cam timing for a given RPM operating range. It is kinda like changing cams only not. Any changes in that area effects the final tune I believe. At least on every other engine out there. I used them on DETROIT steel long ago before ECU's
Old 04-01-2008, 02:14 PM
70spop's Avatar
70spop 70spop is offline
Gallery
Quote:
Regarding advancing the cam for more low-end power, I was just wondering if a faster closing bypass valve, ie the Detroit Tuned one, would make any difference in the equation. Obviously it doesn't affect the s/c speed, but would the fact that it closes faster and therefor helps the s/c start producing boost faster help with an advanced camshaft making more torque down low?
2003 MCS JCW/ LY/W W-stripes/stuff
Old 04-02-2008, 11:46 AM
checkers checkers is offline
Gallery
Forcefeed yes. I have every thing in my car, but I have a 17% pulley & a 2% crank pulley. I'm running 380 injectors. The problem is getting the car to stay in gear long enough. Mine has been upshifting at 6500 rpm's, so the numbers are a little low. Jan's working on it.
05 MCSa
With a little of everything
Old 09-11-2009, 06:51 PM
flatlander_48's Avatar
flatlander_48 flatlander_48 is offline
Gallery
Quote:
Obviously people think differently about this than I do, but I would question the idea of doing all of this work with an automatic behind it. If they beefed up the 6sp manual in the JCW for a 36 horsepower difference, I would have to wonder about the life of the Aisin automatic when backing up big power...
2009 John Cooper Works Clubman: Pure Silver over Horizon Blue, Pure Silver C-Pillars, Mirrors, Hood Stripes, Cold Weather, Premium, Rear Spoiler, Front & Rear Fog Lamps, Bluetooth/USB/iPod
nm Engineering: Short Shift Adapter and Assembly Cover (06/11)
MiniDoMore: Hitch, Drawbar, Cargo Platform and Box (06/11)
Old 03-29-2011, 01:05 PM
thebestbear's Avatar
thebestbear thebestbear is offline
Gallery
Quote:
Our auto S was pushing 201 whp and I think that's all that I would be willing to put to that transmission. Not to mention there is no posi in it, so you can't use the power low end anyways.
Old 09-09-2011, 09:33 AM
jakesulivan's Avatar
jakesulivan jakesulivan is offline
Gallery
Thats a nice suggestion. You have got real knowledge for these things.
Jake's World
Audi Headlights
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
MINI CooperMINI Cooper PrivacyMINI Cooper Terms of UseMINI Cooper Guidelines MINI Cooper Advertising The North American MINI Cooper Community
  MINI Cooper news, forums, FAQs, and reviews for enthusiasts and owners of the North American MINI Cooper
 Copyright © 2002-2008 North American Motoring. All Rights Reserved.     Powered by vBulletin and vBulletin Plugins by Drive Thru Online, Inc.
North American Motoring is an independently operated web site supporting MINI owners and enthusiastsworldwide. As such it has no official relationship with MINI USA, BMW AG, or BMW of North America.All original artwork and design is Copyright © 2002-2004 North American Motoring.
Admin Account Passwords
Search Engine Friendly URLs by vBSEO 3.5.2
