How To Drivetrain :: Clutch, Flywheel, and Quaife Install Overview
With the amount of time required to remove and install the transmission I didn’t have enough extra for a complete Quaife, clutch & flywheel how-to, but I still wanted to share some of the experience so here is a general overview for the procedure.
Refer to the front swaybar install for the first stage of this task. https://www.northamericanmotoring.co...23#post1420223
I didn’t want to forget the small stuff so I started with something that is sure to be overlooked, the gear case sensor.
I was prepared to remove the starter with the heat shield intact but discovered improper routing for the power steering cable which had caused some damage to the sheath.
The cables were squished in this crack between the heat shield and the oil pipe mount.
Either during manufacture or when the engine harness was replaced locally, the installer had become impatient with the heat shield and forced it in place, bending the shield, missing the grommet mounts, and abrading a starter wire & powersteering cables.
So out came the heat shield, followed by the starter, the passenger’s side drive & mid shafts, the driver’s side drive shaft and steering knuckle.
I labeled the wiring so I would know what they attached to during reassembly and took photos of the routing both from below and above for a reference.
The shift cables had to be disconnected; shown is the nifty BMW/MINI tool for the job.
The radiator support was put in service mode and every thing attached to the transmission or in the way had to be removed.
In addition to an automotive jack I used the OEM engine support bracket suspended by an upper engine support. This provided more control during removal and the difficult realigning of the transmission input shaft with the clutch disc after the install. The passenger’s side hydraulic engine mount remained in place and only the brace (03 model) and nut were removed.
Out came the transmission. Some of the bolts were incredibly tight and in inconvenient locations so be prepared. I recommend a 15mm impact swivel socket and powerful impact wrench, although all the bolts can be done (and one had to be) with a standard socket, short extension, and long breaker bar.
The pressure plate bolts require a Torx E8 socket; as with all the bolt removal and installs, loosen in a cross pattern.
Here is the ill fated aluminum flywheel that I couldn’t use. This had to be removed and because of time constraints I installed the latest OEM flywheel and pressure plate kit.
Some of the lower bolts on the gear case were badly rusted requiring a clean up with a thread restoration tap and die.
The split gear box and stock open differential. Oddly the shifter cable holder had threadlocker on the bolts so they also required some clean up with the restoration tap and die as well as an application of blue thread locker when reassembled (if BMW specs threadlocker on the bolt, I do it).
Here are metal shavings captured by the transmission magnet. The magnet is about the size of a half-dollar coin; this is not very bad and does not mean damage has been done; most came from the open differential gears. An analysis of the OEM fluid (the second change interval) showed very little wear residues.
Here are the early and late model Quaife ATB differentials. The one on the left is the newest version which had 2lb-6oz trimmed away. The early version has very close tolerances and the Quaife on a diet rattles like a maraca when shaken. The original plan was to install a lightweight flywheel; I wanted lower reciprocal mass in as many places as possible while putting this package together so the newer model was installed. I’m told by Autotech here is no functional difference between the two and only machining of the outer surfaces was performed; the manufacturing die is identical.
My apologies for the lack of photos on the next steps since this is the part not covered by the Bentley Service Manual, I felt the need to stay focused (although I wish I had pictures for extra QC/QA) but here it is in a nutshell; the differential ring gear has to be removed and fastened to the Quaife. Again, loosen in a cross pattern. Degrease the ring gear bolts and clean the threads with a wire brush. There is more than one approach to the ring gear fastening step; here is the procedure I performed. Tighten the bolts in a cross pattern in 10 ft-lb increments up to 30 ft-lb, remove each bolt in the same cross pattern one at a time, degrease, forced air dry, apply red threadlocker and torque to 70 ft-lb (final torque value sources – LuckyDogGarage and Hubie Fuh). With ten bolts to tighten on this critical component it’s easy to get lost; quality control measures are necessary. I used sticky page markers to number label each bolt, removed the appropriate number, applied torque and marked with Whiteout, for the next round applied the number and marked, and followed with remove the number and marked, and so on, in the end all bolts had the same number of marks. Applying 70 ft-lb on this small component was not easy, requiring a method of securing the differential; I used a large centering tool/round pry bar, braced one end of it against a stop, and the other round end wedged in one of the Quaife’s oil holes, I put every ounce of personal energy on keeping it all together, in place without moving, and applying torque, there must be a better way. New carrier bearings should be installed on the new differential. I first tried and failed baking the bearing and dropping it on; the bearing stuck on the oven mitt, got cocked on the end shaft and cooled quickly, others had better luck with that method. A local shop corrected my mistake and pressed on the other bearing (I baked them some cookies). All exposed bearings (the differential in particular), races, and gear teeth were lubricated with fresh transmission fluid. Blot up as much fluid as you can in the outboard gear case half before the next step, so when turned over to cap the case, none will drip down and spoil the sealant application. The mating surfaces of both gear case edges are thoroughly cleaned, anaerobic surface prep is applied to one side (use masking shields to keep the surface prep off the gear box internals), a thin bead of anaerobic sealant is applied to the other mating surface and the two halves carefully put together. Once again it’s important to monitor the torque applied (30 ft-lb) to all the gear case bolts because it’s easy to forget your place and miss one of them.
Here are some of the extras needed when splitting the gear case and replacing the flywheel; threadlocker, anaerobic sealant (plus anaerobic surface prep not shown), special grease for the clutch shaft splines & release bearing, and two new bearings.
The rear main seal had been weeping; at first I didn’t think it warranted attention when the aluminum flywheel was installed. When I pulled the lightweight flywheel I could see the areas I’d cleaned were moist again; this combined with advice from a couple of local MINI techs prompted me to order a new seal to install. BTW, none of the local MINI techs had replaced one before so they couldn’t provide any guidance. The old seal was very difficult to remove unlike one I had removed from a Cooper motor. After trying to be extra careful and destroying one of the special fabricated tools I made, I was getting no where. It took a smooth flat blade screwdriver to chisel some pressure relief, then one of my fabricated do-dads to pry it out.
The only OEM MINI installation tool available was a seal protector sleeve which I was glad to have during the install. I used some PVC fittings to drive the seal and this was not easy either. Only time will tell whether the replacement seal will be any better because the hole was not round which is probably why the original seal was weeping.
It was a successful seal install in the end.
Here’s a tip learned from one of the local MINI techs in order to hold the crankshaft while tightening any bolts; use a transmission bolt as a brace against a large screwdriver with the blade indexing a starter gear tooth (this pry bar fit perfect). That’s the most resent version of the stock dual mass flywheel and it is much quieter than the original on my vehicle.
The entire kit installed. Clutch engagement is now right in the middle of travel instead of an inch off the floor like the old one and pedal pressure is effortless. The difference is so pronounced there must have been a problem with the old flywheel & pressure plate/clutch.
I was pressed for time to complete the job before the weather turned bad again and I had a few difficulties (new strut install/fat Bilstein) that put me way behind so once again no photos for the rest of the install. Very lightly grease the transmission shaft splines and clutch pressure release bearing ID. Right before positioning the transmission for install, check to make sure the pressure release bearing is where it’s supposed to be and clicked on the actuator fingers/fork. The transmission housing required some wiggling & wrangling to re-fit, this is where the transmission dolly and two engine supports came in handy for a solo install. I had a breaker bar and socket on the end of the crankshaft damper bolt to move the crankshaft for clutch spline alignment, an elbow on the jack handle, a hand guiding the gearbox, a knee on the transmission lift, and sometimes looked like one of those break dancers spinning around on their head. I corrected the improper routing of the engine harness, fixed the heat shield, and put all the brackets where they should have been in the first place. Bleeding the clutch slave after this job is a must; plenty of bubbles could be seen in the catch bottle hose.
All of the torque values except for those involving the gear case can be found in the Bentley Service Manual.
Although this job can be performed “by-the-numbers” it does require a little more than average mechanical skills. I recommend contracting a professional for this install, but money savings can be substantial for the do-it-yourselfer.
Special thanks goes out to Chad http://www.detroittuned.com/ , Dan http://www.grassrootsgarage.com/ , Jan (El Diablito), Joe http://www.jgcycles.com/jagindex.html , and Mike (drmike@txwerks.com), http://engr.smu.edu/rcam/cpm3v/minic...niclutch01.htm
on
Keith, you don't post much, but when you do... it's usually good. And this qualifies as exceptional!!! Thank you very much.
I wonder if that power steering cable issue is somewhat chronic as I recall a few losing their steering, namely racers...
And I see a better photo of the infamous blue bucket you got some grief about . Thanks again!
Weeping...
...is what I would have in common with your seal if I ever tried to perform this operation.
All I can say is "Wow."
Thanks for all the astounding effort. If nothing else, this convinced me that I will give up any thought of doing it myself.
So, you ended up going to an OEM flywheel AND clutch? So the only mod was actually the Quaife?
If you don't mind my asking:
> how many hours did this take?
> did I read correctly that you only had to purchase one special BMW/MINI tool?
> how do you like the Quaife?
> why not a badder FW and clutch (other than the time element)?
Again, thanks for everything!! and
YES THIS MUST BECOME A STICKY.
markldriskill,
>It took more hours than I can count but I also had multiple projects going on.
>The shift cables can be removed with a pry bar or screwdriver but the OEM tool makes it quick & easy.
>I like to think I’m smooth with the brake & accelerator pedal so in normal driving it isn’t noticeable but of course I have to see what it can do, in those situations, steering control and grip have improved.
>The OEM flywheel and clutch were plan B; there was a fitment problem with the “badder” kit and no replacement was available. I couldn’t afford a rental car for an indefinite period of time and the OEM kit was on the shelf at the local parts department.
Tony, Norm, Justin, and Billie, thanks for the positive comments.
The only concern is to be sure the bearing is fully seated on the shaft. As long as the correct bearing part number is used there will be no change in relationship with the race. Starting with Tony Nuzzo and echoed by more than one installer including a local transmission expert; cautions were issued against bearings made in China and Taiwan. The stock bearing is manufactured in Germany by SKF, one of the best made. Japanese bearings have been given high marks also along with the U.S. made Timken. There was a question raised about setting lash to keep noise down on the Quaife and improve shifting. I showed pictures of the split case and gears to someone who blueprints racing transmissions and he told me I didn’t have anything to be concerned about so I didn’t pursue that any further.
There is no noise from this Quaife; I am using a higher viscosity transmission lube (Silkolene SYN5 75W90) at the moment which may have something to do with that, and since it’s a new clutch, I’ve been avoiding engine braking. I’ll be going back to the stock MTF-94 in another week so we’ll see.
I had backlash before the install especially after a downshift and hard throttle on, but I thought that was a function of the clutch. In that regard the only change has been to a silky smooth clutch engagement. I’ve not hammered this thing yet (maybe just a little) so a thorough evaluation will have to wait.
on
This is just awesome info! I have never done something like this before, and with this information, and considering my current situation regarding the lack of a garage, I might not anytime soon.
With the projects I have done, I must say that it does take a conscious effort to document steps and take photos along they way, especially when tired, frustrated, and with dirty hands... I appreciate those who do this for the Community!
K-huevo,
Thanks. I have the obx (yeah yeah I know it's cheap, but I felt like gambling) and I was going to use the bearing number you gave me for napa. I took the lsd apart to look inside and check out the machining. It's pretty rough, but I think it will do. I still can't quite understand how it works though. I'll have to find a theory of operation document.
Some how today I got an itch to install a cam as one of my last power mods (until I rebuild the old beast) so that may come first. I want to be able to hammer it after the install and not wait for the clutch to break in.
Not long after the install, fluid appeared at the transmission weep hole. My first thought was a failure of the rear main seal again; as fate would have it the OEM seal driver I ordered over two months ago finally arrived and I had a new approach for removing the old seal, so it felt like I was prepared this time. Well, the leak was coming from the transmission input shaft seal instead and it was a big mess. Enough had pooled to be picked up by the starter ring gear and slung around the clutch housing contaminating the clutch disc as well.
The rub with this seal is a bearing located behind it so extra care is required during removal to avoid damaging the bearing retainer. After a couple of pros gave me a cavalier suggestion to “just use a screw driver” I gave it a try. I used a nut driver for a fulcrum and a screw driver as the lever to pry open a space, then an angled needle nose to pull it out; there is a shoulder on the input shaft that provided perfect leverage for the pliers’ elbow. That’s plastic from a water bottle protecting the shaft.
This is the prophylactic method I used when sliding the seal over the shaft splines.
The seal was driven flush using a PVC sink fitting, first using the flange side to drive it flush, then the smaller diameter side to take it a little further like the way the stock seal fit.
While I was in there, it was a good opportunity to freshen up the clutch release mechanisms. The latest guide tube has a polished surface to reduce friction with the clutch release bearing; the older model has a course Parkerized finish.
The new version of the clutch release bearing has a self-lubricating nylon sleeve for the sliding surface.
The older bearing is all metal in the interior diameter.
Since the clutch release parts had to be removed to degrease the clutch housing, the clutch release shaft’s nylon bushings were also replaced along with new threadlocker equipped OEM bolts. Before replacing the bushings, the shaft had play in all directions, after the new bushings the shaft would no longer wiggle. BTW, there was no wear on the clutch release fork’s contact pads so need for that part to be replaced.
The Bentley Service Manual calls for a light film of ESSO Unirex S2 grease on the guide tube and the directions with the pressure plate kit extend that recommendation to the transmission input shaft splines. It requires only a very small amount of this special tenacious grease.
A final inspection to make sure the clutch release bearing is in its place before bolting up the gear box.
In all the clutch & flywheel install threads I’ve read it’s only mentioned to replace the clutch release bearing, but I think it makes sense to replace the other wearing parts in the mechanism also; the clutch release bearing and guide tube as a pair would seem a must.
on
GREAT writeup - I'm going over it many times before digging in
Any idea what the pn was for the OEM clutch tool as well as the seal protector? I can't seem to find them...
Aside from that, I'm taking your approach and replacing the wear items you did as well. Better safe than sorry!
Do you have the torque specs for all the bolts?
Lastly, if you don't disconnect the slave cylinder, do you need to bleed the clutch system? I always thought if the system wasn't opened no bleeding was necessary....
