Drivetrain MINI N14 JCW with Manic Tune Stage 1 Dyno test result
Old 06-29-2015, 08:50 AM
johnso56's Avatar
johnso56
johnso56 is offline
OK before surprise you with my number, let me list out my mods
NM charge and discharge pipe
Wagner Competition Intercooler
K & N hi-flow filter
Quicksilver exhaust
NM Short Shift adaptor
NM torque arm mount insert
Alta blow off valve spring upgrade (with stock BOV)
I have the Manic Tuning Stage 1+ after all these mods and my result is
147ps (flywheel)
I don't get it, even I calculate the power lost, either 25% or 60HP, it's still lower than my stock HP which is 208HP, how is that? My car only have ~15000miles on it and I change my oil every 5000miles. Can anyone explain this to me? Thank you
p.s. The place I did in Dyno is different than the place I did the manic tune (I thought that way I can have a non-bias result)
Old 06-29-2015, 11:12 AM
oldbrokenwind's Avatar
oldbrokenwind
oldbrokenwind is offline
All dyno's are NOT the same! Besides measuring either Wheel HP or Crank (flywheel) HP, they have different load and measurement techniques. It's always best to use the same machine when comparing performance mods. This minimizes the variations in different machines, leaving only normal environmental and calibration variations.
Old 07-01-2015, 05:36 PM
johntotah94's Avatar
johntotah94
johntotah94 is offline
Does the car feel faster after the tune? or slower?
Old 07-01-2015, 07:41 PM
Dr. Spade's Avatar
Dr. Spade
Dr. Spade is offline
What does your butt dyno say?
Old 07-01-2015, 08:25 PM
johnso56's Avatar
johnso56
johnso56 is offline
My car feel more linear than before, and the pop sound is more loud in sport mod. However I not sure if I feel faster. My manic tuning people say it's not going to change a lot since i am not replacing my turbo nor downpipe. My dyno guy says they don't know (there are not many JCW around my town).
Old 07-02-2015, 07:22 AM
johnso56's Avatar
johnso56
johnso56 is offline
Oh and one more thing, it's definitely slower than chipped my car with race chip pro (but without any mod support back then, chipping my car caused malfunction of my spark plug)
Old 07-03-2015, 02:38 PM
johntotah94
Getting any misfires or anything?
Manic tunes recommend NGK 1422 or NGK 91448 Spark Plugs
Old 07-03-2015, 05:22 PM
johnso56's Avatar
johnso56
johnso56 is offline
Yes I got the NGK spark plug when I do the manic tune
Old 07-10-2015, 10:43 AM
sk8terboy's Avatar
sk8terboy
sk8terboy is offline
Did you contact your manic dealer?
Old 07-10-2015, 10:54 AM
IQRaceworks's Avatar
IQRaceworks
IQRaceworks is offline
This! To really see what kind of power you could have gained, or lost...you need to test before and after on the SAME dyno. A dyno could easily be off 40-50hp.
Old 07-10-2015, 08:45 PM
johnso56's Avatar
johnso56
johnso56 is offline
Ya.....now I know, the manic dealer didn't tell me I need to test before and after on the same dyno.
Old 07-11-2015, 04:40 AM
Indimanic's Avatar
Indimanic
Indimanic is offline
If you have the SRS switch you should have done a run in stock mode then switch to the A,B,C tunes to see the difference. Also you should monitor and compare boost.
Old 07-12-2015, 09:20 AM
johnso56's Avatar
johnso56
johnso56 is offline
But I don't have the switch
Old 07-12-2015, 12:54 PM
Ovrclck's Avatar
Ovrclck
Ovrclck is offline
The switch is just $200 bucks. Definitely worth the price.
07-16-2020 12:54 PM
GregoryK
08-09-2015 09:02 PM
08-07-2015 08:02 AM
sungjk
08-05-2015 08:23 PM
mini pooper
RSR Motorsports Coverage
08-05-2015 02:56 PM
Quick Reply: Drivetrain MINI N14 JCW with Manic Tune Stage 1 Dyno test result
