Drivetrain Code P2885 really pi$$ing me off
Old 05-02-2015, 07:10 PM
Ladybug-S's Avatar
Ladybug-S
Ladybug-S is offline
I have a 2009 Cooper S with many mods and a tune since around 15K miles (now at 75K miles) and over the last year or two I have been getting the P2885 code. It has recently got to the point that I can't even spool the turbo without the car going into limp mode and throwing the P2885. Early on I really had to be gunning it to throw the code so over time something has been progressively getting worse.
I have a rebuilt turbo via G-pop. I had the vacuum pump and pipes recently replaced by the dealer, who also smoke tested for boost leaks and found nothing.
My mods include alta CAI, tubing and intercooler, wmw exhaust manifold, JCW exhaust, RMW tune, OCC and some other minor stuff.
Can anyone give me an idea of what the F might be going on with my car?
I am at the point where I don't want to drive it anymore which is sad as hell. I don't want to sell it either but I am at the end of my rope.
Old 05-02-2015, 08:11 PM
nine5raptor's Avatar
nine5raptor
nine5raptor is offline
could be a leaking/broken wastegate valve or the line going to it. the valve runs off vacuum so a leak check would not identify a crack in the line. could also be a torn diaphragm in the blow off valve itself or a sticking valve. take it off and inspect it/clean it and try it again. could just be gummed up with oil from the intake.
Old 05-02-2015, 08:19 PM
cerenkov's Avatar
cerenkov
cerenkov is offline
Old 05-03-2015, 05:34 PM
Ladybug-S's Avatar
Ladybug-S
Thanks, Cerenkov. That was an interesting read, if a little tough to follow.
I have been suspecting the HPFP for some time now. Wondering if there is a way to get the dealer to replace given my car is in the 2007-2009 model years where the HPFP's were causing issues.
I put my stock BOV back on today after taking my Alta BOV off. All the vacuum lines I can see and touch seem fine.
I may check the waste gate lines next. I had the turbo rebuilt and they looked at the wastage itself as part of that so I am assuming that is fine.
Old 05-03-2015, 07:43 PM
cerenkov's Avatar
cerenkov
cerenkov is offline
MINI has an extended warranty for the HPFP for some model years. It's worth asking.
Old 05-04-2015, 06:55 AM
Z06C5R's Avatar
Z06C5R
Z06C5R is offline
Your '09 should be covered on the HPFP out to 100k. Mine failed recently and I was advised my Jan '10-build JCW missed the cut-off for warranty coverage by a month or two (the literature on it covers all '07-'09 models). Even 100% out-of-pocket it was only $600, which is not bad for these cars.
FWIW, mine drove fine and did not throw any codes while the pump was failing but had a helluva hard time starting and idling for the first minute or two.
Old 05-20-2015, 11:10 AM
sk8terboy's Avatar
sk8terboy
sk8terboy is offline
Were you getting the codes, before or after the turbo?
Old 05-21-2015, 04:27 PM
Ladybug-S's Avatar
Ladybug-S
I have been getting the code for ages now, both before and after my turbo rebuild.
Old 05-22-2015, 06:11 AM
Dr. Spade's Avatar
Dr. Spade
Dr. Spade is offline
For me that code was the wastegate actuator. It kept it open too long and/or wouldn't open it quick enough.
So the ECU would just pull boost to be safe. Was fixed under warranty.
Old 05-22-2015, 06:55 AM
damncajun's Avatar
damncajun
damncajun is offline
I have a 2010, August or sepetmber 2009 build. Is mine covered under that, and if so where are you guys getting this information? Every time I ask mini about something they just look at the VIN for open campaigns.
Old 07-01-2015, 12:44 PM
Indimanic's Avatar
Indimanic
Indimanic is offline
Had same issue, The ALTA diverter was the culprit. Also never vent to atmosphere or use that Forge junk spacer. Causes same codes.
Old 07-10-2015, 10:47 AM
sk8terboy's Avatar
sk8terboy
Any updates?
Old 07-10-2015, 02:23 PM
Systemlord's Avatar
Systemlord
Systemlord is offline
I will admit the Forge spacer is any good for our Mini's, the Forge DV is another story for a different thread.
Here's a thread with exactly the same issue you're having.
Steffen.Johnson
71
01-26-2021 09:11 AM
Enjoytheride
09-17-2015 12:10 PM
thebombardier
09-15-2015 02:53 PM
IrishMCS
09-15-2015 05:43 AM
Quick Reply: Drivetrain Code P2885 really pi$$ing me off
