Drivetrain Performace Cam... Fuel Injectors
950's!
jk. just for me
For big cam, go ahead and go with the bosch EV14 550's. much better spray pattern than the deka's. Make sure to get oe units and not re-drilled 550's
(main reasoning is cost is not that different for the extra protection of future proofing it... unless you go nuts like me and even 550's are not nearly enough... )
jk. just for me
If I recall right, there are two different 550's...
One of them has a better spray pattern....better atomization...it is a newer design. Check with you tuner Jan/RMW? ) ..they will have an opinion...but if I recall, the idle with the better 550s are fine and they are actually BETTER due to the spray pattern than the 450's....more "headroom" too if you keep modding!!
950's! jk. just for me For big cam, go ahead and go with the bosch EV14 550's. much better spray pattern than the deka's. Make sure to get oe units and not re-drilled 550's (main reasoning is cost is not that different for the extra protection of future proofing it... unless you go nuts like me and even 550's are not nearly enough... )
I went with shorter ones and built my fuel rail, so I actually cannot remember. I think our factory ones are 45mm, but you should pull one and measure it with some calipers first.
Make sure you are getting bosch OE units and not aftermarket redrills / ebay crap.
If you are going aftermarket re-drills make sure they are top-shelf flow matched units by someone like FIC (fuel injector clinic) or ID (injector dynamics)
(i still prefer bosch OE over those though)
Jan will recommend that you buy his and only his 550's. Though, Jan is just another guy who simply resells OEM injectors from other cars, marketed as something special to those without the interest in researching.
Ebay some Bosch 0280158117. That's what Mynes sells. You'll need harness adapters.
Say whaaaa?!
seriously though. I hardly buy any of my stuff from automotive markets. Only things like radiator fans and such. All my nuts, bolts, grommets, seals, etc etc are from industrial part suppliers.
Hell, McMaster is expensive (yet super convenient) by industrial standards, yet it is still half the cost of an automotive warehouse for the same crap (fittings and hose). AND I get CAD drawings and technical data on service use up front! amazing...
IQRaceworks
51
10-10-2015 03:54 PM
HK_MCS
R58 :: Coupé Talk (2012+)
10-04-2015 08:03 PM
dutchhome
09-30-2015 07:17 AM
