Drivetrain Stuck caliper issue and question.
So I have a stuck caliper that's worn down my passenger rotor and pad more than the drivers side. I swapped the pads and rotors out last spring so they are fairly new. (Akebonos and Zimmerman rotors) my question is, can I replace the calipers and just one rotor and pad set? Or, should I replace everything to keep it even? I'm thinking if I have to replace everything again I'll upgrade to the r56 setup. Hit me with your opinions please.
Always, always, always replace in pairs because by doing so you avoid the near death experience during a full on slam of a panic stop. By doing your own work you can upgrade to cross drilled, slotted rotors AND pads on all corners for around a nickel. The G2 paint system really works and has an excellent guarantee. I did this on my old R53 and ,not only looking killer, provided excellent results.
ISAMIN
ISAMIN
Depending on miles. Do both calipers. Your already have to bleed brakes and you already have rotors off on both sides as you MUST do both side pads and rotors.
How much more is a caliper gonna add to the bill. And not worth running the risk of damaging the new rotors and pads again.
Just my .02 on cheap insurance. Penny wise dollar foolish.
Sent from my iPad using NAMotoring
If you mean "basic" r56 s/ r53 jcw replacement rotor, yes...I like high carbon, painted top rotors (bought "centric" brand last, many folks favorite....about an extra $1 over the standard..lol..if you look around, free shipping...(rock, amazon, etc).
And check....you need the caliper brackets....that is not included in all kits....along with hoses and pads...
And if you post on ma, lots of folks there too have done this mod...
Gen1 sensor if you want to run them...electrically it is STILL a gen1....so same sensor as the gen1 JCW, so same as any gen1 car...
Design not sure about the guidepins, but the caliper is a different design from the stock s...very different....so not so sure it makes sense...
I would suggest you jureyrig up a benchbleed setup to flush the calipers before install....
Gen1 sensor if you want to run them...electrically it is STILL a gen1....so same sensor as the gen1 JCW, so same as any gen1 car... Design not sure about the guidepins, but the caliper is a different design from the stock s...very different....so not so sure it makes sense... I would suggest you jureyrig up a benchbleed setup to flush the calipers before install....
