Drivetrain CravenSpeed short shifter FAIL! Help!!??
I just finished up the install of the cravenspeed short shifter for my 2011 MCS. I installed everything from the actual kit to the shift well cover and dust cover and I must say it looks spot on. I did run into an issue with the dreaded white clip that houses the shift ball ( I broke it..) but replaced it with an up rated piece that way sells. Here's my issues. I buttoned everything up ( actually installed my invidia exhaust at the same time ) took it for a test drive and everything felt great. Superb throws, awesome adjustability and just overall improved from stock. I parked for a while and when I got back in my car and clicked up through gears it seems as if I am locked out of 5th and 6th??? I can hit 1st through 4th no problem, but when i shift into 5th or 6th it takes me back to 3rd?. the only thing I can think of is the shift linkage being disconnected but I don't see how thats possible because 1st through 4th is ok. The shifter seems to have alot of play to the right when in neutral and when I shift to 5th or 6th seems to go way past. Any Ideas? its a nightmare trying to undo the dust cover from underneath and I really don't want to have to go under there again.
Yes I have the Nm Cover and have tried adjusting it up and down. At this point The only thing I can think of is the shifter box assembly itself. Possibly the plastic piece the arm rests in was stressed during the installation or possibly the linkage cables having lack of play due to the solid bushings NM supplies with their new cover is the issue. Either way Im tearing everything back apart sunday
Im Looking for the entire shifter box if thats what your referring too. If you could tell me how to disconnect the cables from the box on the underside that would be great too.
And yes, the whole box. Even has the stock arm in there still.
This helped a lot when it came to prying off the ball joints from linkage. and it also helped in wedging off the cables from the box. You just need to find something to put under it to give it leverage.
Amazon.com: Lisle 35260 Plastic Fastener Remover: Automotive
I plan to use this and the other tool r2 had mentioned. Thanks for the quick input, ill post updates after I tackle it. Wish me luck
I know this by now irrelevant but Im going to make an effort to be more active on the forum. The issue ended up being in the plastic bushing with the three clips that everyone. It wasn't properly supporting the shift rod so every time I would shift to 5th it would pop out. I remedied it with a CNC aftermarket bushing from WAYMOTORWORKS. Unfortunately the aftermarket bushing is quite rough and does not offer stock feel. I have now ordered a brand new OEM shifter base from ECS so I can get a stock bushing.
Moderator
I also installed the CravenSpeed retainer clip - I'll check to see if it's popping out when I get home tonight. I was going crazy trying to figure this out....might not be my issue, but at least I can focus on work now!
wildwestrider
12-27-2015 08:20 PM
67morris
12-01-2015 12:53 PM
Sc00terbum
09-11-2015 09:07 AM
