Drivetrain K04 Turbos and diverter/blow off valves
Hey folks
I'm starting to research bigger turbo's and I see there are more and more people running them these days. I couldn't find any specifics on this but am curious. Those that have the bigger turbo's installed are you all using diverter/recirc valves or straight up atmpospheric blow offs? I'm concerned mostly with the N18 but interested in what people are doing with their N14's as well. Is Forge the only thing going or are others making something useful?
Thanks Gents that's good to know. That wasn't mentioned when I discussed the issue with the JM TURBO folks. If I can get away without buying an aftermarket DV/BOV that would be nice. The option is always there if the stock valve fails.
The nice thing about the Forge DV is it doesn't dump as much boost as all the others, so when you go to up-shift your boost is almost right where is was before your shift. That's the best way I can describe how it feels, not sure if you can run one on a larger turbo though. Best performance updade for the money period!
That's kinda my thinking but now knowing the JM turbos come with an upgraded DV I'll probably stick with that to save a few bucks until if/when that DV fails or fails to hold boost as planned. At that point I'll go with the Forge. Unless I'm wrong, and I could easily be, Forge is the only aftermarket option as far as I know.
There's been a lot of argument for and against using BOV's in these cars vs. DV's. I don't really see an advantage of one over the other unless some of you guys have any knowledge on this?
Like I said earlier I'm unsure about whether using the Forge DV is appropriate for these big turbos.
The difference between the upgraded DV and Forge DV is the speed with which they operate. The standard DV has a large electrical solenoid that directly actuates the DV. The Forge unit uses a much smaller and therefor faster solenoid that controls pneumatic pressure / vacuum to actuate the DV. Because the Forge unit opens faster, less aerodynamic braking occurs. In addition since it closes more quickly less boost is lost while the turbo spools up. The Forge unit also will not suffer from a torn diaphragm or cracked retaining ring as sometimes happens with the stock DV. The only downside to the Forge unit is the pneumatic piston becomes dirty over time and requires cleaning to function properly.
the 710D-series DV solenoid we use on our products is tested to hold in excess of 30psi. It's the same unit we use in our hybrid turbochargers for VW/Audi 2.0L engines. On those cars we're seeing 400bhp using that diverter valve. It holds just fine.
joshuatrost
R60 :: Countryman Talk (2010-2015)
09-05-2015 02:58 PM
09-02-2015 09:05 AM
